- Thank you received: 3
Mesa 7i97T & LinuxCNC setup struggles
- BlownCorona
- Topic Author
1 year 5 months ago - 1 year 5 months ago #329496
by BlownCorona
Mesa 7i97T & LinuxCNC setup struggles was created by BlownCorona
Good evening all
I was really holding off on asking for help as i much prefer to figure things out for myself but i'm running up against a few specific struggles and i'm starting to get the feeling that i'm just missing something that perhaps you experienced folk may know about due to experience.
I have setup a nice pc with Linux Mint 22.1 using the ISO Tommylight provides. the LinuxCNC included in this was 2.1 which seems old and this is however the first detail i might be missing the mark on, in hindsight 2.1 seems to old to be logical so perhaps its a different variant? Regardless, i uninstalled that and installed 2.9.4 which went without a hitch, but did not make anything work any better.
I then came across MesaCT as pnfconf doesnt support this card. I set the card jumpers as per instructions in MesaCT and i can ping it on 10.10.10.10 but i cannot connect to it.
MesaCT reports that the LinuxCNC version is "version error" - my gut feeling is that the linuxcnc version is newer than the latest update for mesaCT and its just not able to report on it correctly - can anyone confirm if this is preventing operation?
Finally, the detail that i believe is actually stopping MesaCT connecting to the 7i97T - the mesaflash version is reporting (correctly) as 3.4.6, MesaCT notes that for the 7i97T connect, Mesaflash 3.5.3 is required, however i cannot for the life of me find where this is to be obtained, or even any reference to a mesaflash above 3.4.6 other than a few posts on this forum where users mention they are setup with 3.5.x and don't seem to suggest that this was at all difficult. Those posts were all a couple of years ago, has something changed with the version numbering?
I am not at all new to computers but i dont have a large amount of experience with linux, happy to do the learning but it looks like i need a swift kick in the correct direction!
Any help greatly appreciated
p.s. i couldnt decide if this should go under "installing" or "general" apologies if i picked wrong.
Last edit: 1 year 5 months ago by BlownCorona.
1 year 5 months ago #329501
by unknown
Replied by unknown on topic Mesa 7i97T & LinuxCNC setup struggles
You can build from source by following the instructions here:
github.com/LinuxCNC/mesaflash
As for the Linuxcnc version I doubt whether 2.1 could be built on a recent linux distro due to python issues.
- BlownCorona
- Topic Author
1 year 5 months ago #329504
by BlownCorona
Replied by BlownCorona on topic Mesa 7i97T & LinuxCNC setup struggles
That is were i built mesaflash from, however it only nets version 3.4.6 (unless im doing something wrong)
however, this evening i have discovered that you dont actually need to be able to connect to the card with MesaCT in order to build a config. ive had some positive progress with getting one servo&encoder wired in. the encoder shows movement and the servo blips when trying to turn the machine on before it errors out due to following error.
the tricky thing now, is i cant find the specs for these encoders to verify the PPR.
i would still love to know the answers to the original questions ofcourse, as im sure i may need to sort those errors sooner rather than later
1 year 5 months ago #329506
by unknown
Yeah I forgot about mesaflash reporting the wrong version.
I dunno why it does that, might be worth raising an issue.
Pcnconf doesn't let you build a config ?
It's been a while since I've actually had to build a config from scratch.
A following error is usually preceded by a latency error, so check that out, also ethernet latency can be an issue as well. Hopefully PCW might chime in.
1 year 5 months ago #329507
by unknown
Might wanna have a quick look here re network latency
forum.linuxcnc.org/18-computer/56109-lin...l-pc?start=20#329476
1 year 5 months ago #329510
Replied by tommylight on topic Mesa 7i97T & LinuxCNC setup struggles
The following user(s) said Thank You: BlownCorona
Time to create page: 0.170 seconds
