Yesterday evening i was using chatgpt to help understand some of the nuts and bolts of what certain values mean. i made progress but perhaps you can check its homework.
i did set the following errors wider which has prevented this error occurring for the most part, though i understand this should eventually be taken right back down to the tight window it should be.
FERROR = 10
MIN_FERROR = 5
notably, it suggested changing the PWM scale from 10 to 1, claming that this would provide the expected +-10V and the voltage limits coming from the max outputs which on the surface makes sense and got me to the point where i was tuning a motor that was either violently oscillating or buzzing angrily, tuning pid values to a very low point gave a quieter (but not silent) motor but it was sluggish.
Now it could be that im not in a position to tune properly, or i could have screwed the code up much worse because i am quite aware that chatgpt is not our savior and it will be confidently wrong.
the documentation here supports the claim that the scale should = 1 however im not certain why mesaCT set that scale as = 10
www.linuxcnc.org/docs/html/man/man9/pwmgen.9.html
feels like progress, and i dont think im far off cracking it.
