How to install kernel patch? (Moschip 9900)
19 Jul 2025 21:32 #332045 by jor
Hello all! I am very new to LinuxCNC and have question about how to install a kernel patch.
I have a PCIe parallel port card with a netmos 9900. The driver that came with does not work, and I found this patch on the kernel site:
git.kernel.org/pub/scm/linux/kernel/git/...6917eeda4284ed220079
In usr/src it shows my current version is 6.1.0-30, which I assume is the latest since I just downloaded it. The patch seems to be 6.08 (?)
My question is, can anyone guide me on how to install this patch? I found some information on patches that had "patch.gz" in the file extension, whereas this one seems to be "tar.gz" and those tutorials don't work.
Otherwise, does anyone know of some kind of guide or video on how to install this particular kind of patch? I apologize for this being such a general question, but I am very new and don't really know how linux kernel works!
Thank you in advance.
19 Jul 2025 22:14 #332046 by PCW
You should not need to install any drivers.
Does
lspci -v
Show your card?
20 Jul 2025 11:48 #332067 by jor
When I boot the computer, lspci -v shows the card, and i can jog the stepper. But after a little bit the stepper stops working and lspci -v shows "(disabled)" next to the ports. The only way I've found to get it working again is to reboot.
I have the windows driver installed (dual boot), do you think that could mess it up on linux somehow? It's just weird that it works and then becomes disabled partway through working, so i figured maybe that patch would help. Unless the patch is outdated and the latest kernel already supports 9900?
Also, when the stepper does jog, it will stop for a split second intermittently, and then soon after show "joint 0 following error". It also shows "unexpected realtime delay on task 0 with period 100000... run latency test and resolve before continuing," I already ran the latency test.
20 Jul 2025 12:02 #332069 by PCW
PC latency is likely the cause of the issue , I doubt that it's driver related.
(especially it it ever worked)
Did you run a latency test?
20 Jul 2025 13:05 #332075 by jor
OK I just looked into the latency test. It's almost 70k which i assume is bad... I tried changing to isolcpus=3 with no change.
I saw in another post someone said to use RTAI kernel but I cannot figure out how to install it. Computer is Dell Optiplex 9020 which people have recommended in several other forum posts.
Do you think RTAI is the right route? do i need to reinstall linuxcnc with a different image and then install the .deb file for rtai?
20 Jul 2025 14:03 #332077 by jor
I just disabled a bunch of stuff in BIOS (another thread recommended) and latency is down to 15k, but all the same errors persist
20 Jul 2025 14:17 #332078 by tommylight
Replied by tommylight on topic How to install kernel patch? (Moschip 9900)
Try this
www.linuxcnc.org/iso/linuxcnc-2.7.14-wheezy.iso
You can boot from USB, and make a quick simple config and test with, all without installing it, then if it works better, install.
20 Jul 2025 20:10 #332095 by jor
It seems to work better while it works, but it shortly stops and the parallel port becomes disabled, and I have to reboot. The pausing problem stopped and the latency is much better, but it gets disabled pretty quickly
20 Jul 2025 20:32 #332097 by jor
I found how to "enable" the parport without reboot with
echo 1 | sudo tee /sys/bus/pci/devices/0000:03:00.0/enable
which removes the "disabled" from lspci -v
but it doesn't cause the stepper to work again unless I reboot. Also, i was jogging before at low speed. I tried with higher speeds and it still has alot of that "pausing" going on even though latency is now like 4000. Plus, on starting my configuration it still has "error : unexpected realtime delay on task 1... run the latency test..."
23 Jul 2025 18:56 #332245 by jor
Anyone have any more suggestions on what I can check/try?
I am now on 2.7.14 Wheezy, Dell optiplex 9020, Netmos9900, and latency under 6k. The stepper will jog and then quit working shortly after, regardless if there is "pausing" or not. The PCIe parport shows "disabled" in lspci -v, and even if I enable it via the terminal, the stepper still doesn't work unless I reboot.
Any ideas at all are appreciated.
Time to create page: 0.461 seconds
