How to install kernel patch? (Moschip 9900)
- Thank you received: 7504
23 Jul 2025 19:00 #332246
Replied by tommylight on topic How to install kernel patch? (Moschip 9900)
Disconnect the power form all but one drive and do some tests, then connect another one and test...
I am pretty sure it is an interference issue with bad wiring and/or bad grounding, so u7pload some pictures of the wiring here so we can have a look.
- jor
24 Jul 2025 19:44 #332282
by jor
Replied by jor on topic How to install kernel patch? (Moschip 9900)
I've tested both drivers separately and same issues. I've attached a picture and also a schematic, since I only had yellow wire lol...My grounds seem good, and the pairs from the motor are correct (unless it matters which pair go to direction and which to pulse?)
drive.google.com/drive/folders/1hJbKoC8d...PaQxFqQY?usp=sharing
I attached all files in google drive since they are too big; .hal, .ini, and the lspci info if that is helpful. Also in .ini the ferror values are at 10 but I have tried many different ranges of values.
I appreciate your time and help with this.
24 Jul 2025 19:55 #332283
Flip the drive upside down and move the motor as far from it as you can, test again.
- jor
24 Jul 2025 21:26 #332286
by jor
OK i flipped the driver and extended motor wires to 4 feet away. It is not better, in fact is seems a bit worst and stops even quicker
25 Jul 2025 07:02 #332305
What power supply is powering the drive?
2 years back i had some really bad power supplies that caused a lot of noise, so i did the humane thing and showed them the trash bin.
- Thank you received: 5336
25 Jul 2025 13:18 #332320
Replied by PCW on topic How to install kernel patch? (Moschip 9900)
I would test with the motor power off (and maybe parallel port disconnected)
to verify if this is a noise issue (noise ground path through parallel interface)
or a software issue.
- jor
26 Jul 2025 13:45 #332377
by jor
tommylight; I'm using a super cheapo amazon power supply, I will test with a better one when I am able. Do you think such noise could cause the parport to become disabled in linux?
pcw; with the parallel port unplugged from the driver, the exact same issue happens! so i guess it is software or maybe my PCIe parallel port? this is the one I have www.amazon.com/dp/B01N6MG5TM?ref=ppx_yo2ov_dt_b_fed_asin_title
- royka
- Thank you received: 135
04 Sep 2025 04:34 #334394
by royka
Replied by royka on topic How to install kernel patch? (Moschip 9900)
Only the parport gets disabled or LinuxCNC also show an error? (Not sure if the parport gets disabled after a following error?)
Perhaps a parport driver is interfering, what does lsmod show?
Is in the BIOS the parallel port set at ECP/EPP/AUTO? Try EPP or ECP
Too aggressive timing for the steppers?
Power Management in BIOS?
Time to create page: 0.451 seconds
