installing an older version
- johns00056
- Topic Author
1 year 2 months ago #334090
by johns00056
installing an older version was created by johns00056
I am putting together a complete,new, backup computer for my machine. (after a lightning storm took out my previous computer.)
I downloaded Linux-2.7.14 wheezy.iso and used rufus.ie to make a usb image.
The new computer won't go past the boot screen. I fiddled around with the boot order etc but still no go.
I downloaded the latest version Debian 12 bookworm preempt-rt iso, made a usb image, and it starts right up to the install screen.
Is there something I need to do to make the older version start? I don't want to upgrade to the current version.because I would have to change a lot of things in my configuration.
I am running my previous backup computer currently. I suppose that I could clone the hard drive , or something like that.
1 year 2 months ago #334101
Replied by andypugh on topic installing an older version
You can just try loading the existing configuration files onto the Bookworm setup. It ought to just work (I spent a lot of effort on the automatic conversion scripts)
If it doesn't work you are no worse off (if you keep a backup of the LinuxCNC folder)
1 year 2 months ago #334120
Replied by tommylight on topic installing an older version
You have to disable "secure boot: and UEFI in BIOS for it to work, UEFI is usually disabled by choosing Legacy mode in BIOS for boot devices/order.
- johns00056
- Topic Author
1 year 2 months ago #334174
by johns00056
I tried this but the new computer will still not boot from the thumb drive.
The old computer will boot from the thumb drive.
The new motherboard does not have have CSM (compatibility support module) when using the integrated graphics on the processor .
The internet says something about if I add a graphics card that supports VBIOS display, I might be able to gain CSM functionality.
Replied by johns00056 on topic installing an older version
Thanks for the help.
- johns00056
- Topic Author
1 year 2 months ago #334175
by johns00056
The script to automatically re configure configuration files did not work.
missing [KINS]KINEMATICS=
[KINS]JOINTS=
From looking at an example , it looks like I will have to change the ini file joints and axes.
It also looks like I will have to add loadrt [KINS]KINEMATICS to the HAL file.
Thanks for the help.You can just try loading the existing configuration files onto the Bookworm setup. It ought to just work (I spent a lot of effort on the automatic conversion scripts)
[KINS]JOINTS=
1 year 2 months ago #334177
by JT
Replied by JT on topic installing an older version
My Hardinge CHNC is still running Ubuntu 10 with EMC 2.7 with no issues at all. I doubt that Debian 12 would even install on that pc but if it ain't broke don't fix it is my motto.
JT
JT
The following user(s) said Thank You: tommylight, unknown
Time to create page: 0.080 seconds
