Installing LAN driver for RealTek 8111H
1 year 4 weeks ago #335749 by Digger011
Hello,
my first post here. I am completely new to Linux.
I was able to install LinuxCNC and connect it to WiFi via USB dongle. Unfortunately I am not able to use integrated LAN adapter from Ausus N305m-e mother board. LAN chipset should be 8111H. When I open the Network manager and want to add ethernet connection, I don't get any device name from drop down manu to chose from. I would think that OS doesn't see it. If driver is missing, where should I get it and now to install it?
All of this is very new to me. To run my machine I used UCCNC but decided learn something new and to switch to LinuxCNC.
Thanks,
Milos
1 year 4 weeks ago #335755 by tommylight
Download this
www.linuxmint.com/download_lmde.php
write it to USB and boot the PC from it, do not install, just check if the network works with it.
1 year 4 weeks ago #335757 by unknown
sudo apt-get install r8168-dkms
This package covers the RT8111H as well
See this page below.
packages.debian.org/sid/r8168-dkms
1 year 4 weeks ago #335819 by Digger011
Hi Tommy,
I did it, and there was no Lan card reported. Even, if I tried to add new connection, didn't work. :(
1 year 4 weeks ago #335820 by Digger011
I've got this replay and I don't understand what is going on.
milos@debian:~$ sudo apt-get install r8168-dkms
Reading package lists... Done
Building dependency tree... Done
Reading state information... Done
r8168-dkms is already the newest version (8.048.03-3).
0 upgraded, 0 newly installed, 0 to remove and 6 not upgraded.
2 not fully installed or removed.
After this operation, 0 B of additional disk space will be used.
Do you want to continue? [Y/n] y
Setting up initramfs-tools (0.142+deb12u1) ...
update-initramfs: deferring update (trigger activated)
Setting up r8168-dkms (8.048.03-3) ...
Removing old r8168-8.048.03 DKMS files...
Deleting module r8168-8.048.03 completely from the DKMS tree.
Loading new r8168-8.048.03 DKMS files...
Deprecated feature: REMAKE_INITRD (/usr/src/r8168-8.048.03/dkms.conf)
Building for 6.1.0-30-rt-amd64
Building initial module for 6.1.0-30-rt-amd64
Deprecated feature: REMAKE_INITRD (/var/lib/dkms/r8168/8.048.03/source/dkms.conf)
Error! Bad return status for module build on kernel: 6.1.0-30-rt-amd64 (x86_64)
Consult /var/lib/dkms/r8168/8.048.03/build/make.log for more information.
dpkg: error processing package r8168-dkms (--configure):
installed r8168-dkms package post-installation script subprocess returned error exit status 10
Processing triggers for initramfs-tools (0.142+deb12u1) ...
update-initramfs: Generating /boot/initrd.img-6.1.0-30-rt-amd64
raspi-firmware: missing /boot/firmware, did you forget to mount it?
run-parts: /etc/initramfs/post-update.d//z50-raspi-firmware exited with return code 1
dpkg: error processing package initramfs-tools (--configure):
installed initramfs-tools package post-installation script subprocess returned error exit status 1
Errors were encountered while processing:
r8168-dkms
initramfs-tools
E: Sub-process /usr/bin/dpkg returned an error code (1)
1 year 4 weeks ago #335823 by Digger011
I did some research and it looks like something is wrong with installation. I have no problem of reinstalling it from scratch, if it makes sense.
Time to create page: 0.064 seconds
