Strugling with installation
06 Oct 2025 22:36 #335957 by Digger011
Strugling with installation was created by Digger011
After the initial hick-ups with Lan connection, I hoped everything will be smooth sail, but it looks like no luck.
I tried a couple of times to install it from scratch, but same problem is there initramfs tools error code 1. Wondering why it looks for raspi when I am not running Rospi?
What can I do to properly finish with installation?
Thanks,
M
dkms: running auto installation service for kernel 6.1.0-40-amd64.
dkms: autoinstall for kernel: 6.1.0-40-amd64.
Setting up libqt5opengl5:amd64 (5.15.8+dfsg-11+deb12u3) ...
Setting up linux-headers-rt-amd64 (6.1.153-1) ...
Setting up libgimp2.0:amd64 (2.10.34-1+deb12u3) ...
Setting up libpoppler-qt5-1:amd64 (22.12.0-2+deb12u1) ...
Setting up linux-headers-amd64 (6.1.153-1) ...
Processing triggers for systemd (252.39-1~deb12u1) ...
Processing triggers for man-db (2.11.2-2) ...
Processing triggers for dbus (1.14.10-1~deb12u1) ...
Processing triggers for shared-mime-info (2.2-1) ...
Processing triggers for debianutils (5.7-0.5~deb12u1) ...
Processing triggers for mailcap (3.70+nmu1) ...
Processing triggers for desktop-file-utils (0.26-1) ...
Processing triggers for hicolor-icon-theme (0.17-2) ...
Processing triggers for libc-bin (2.36-9+deb12u13) ...
Processing triggers for initramfs-tools (0.142+deb12u3) ...
update-initramfs: Generating /boot/initrd.img-6.1.0-40-rt-amd64
raspi-firmware: missing /boot/firmware, did you forget to mount it?
run-parts: /etc/initramfs/post-update.d//z50-raspi-firmware exited with return c
ode 1
dpkg: error processing package initramfs-tools (--configure):
 installed initramfs-tools package post-installation script subprocess returned
error exit status 1
Processing triggers for ca-certificates (20230311+deb12u1) ...
Updating certificates in /etc/ssl/certs...
0 added, 0 removed; done.
Running hooks in /etc/ca-certificates/update.d...
done.
Errors were encountered while processing:
 linux-image-6.1.0-40-rt-amd64
 linux-image-rt-amd64
 initramfs-tools
E: Sub-process /usr/bin/dpkg returned an error code (1)
07 Oct 2025 00:35 - 07 Oct 2025 00:38 #335963 by Digger011
Replied by Digger011 on topic Strugling with installation
After running sudo apt-get install -f I've got this:
dpkg: error processing package linux-image-rt-amd64 (--configure):
dependency problems - leaving unconfigured
run-parts: /etc/initramfs/post-update.d//z50-raspi-firmware exited with return code 1
installed initramfs-tools package post-installation script subprocess returned error exit status 1
initramfs-tools
Then went with
sudo apt-get check
apt-cache depends
I got this:
milos@cnc:~$ apt-cache depends linux-image-rt-amd64
Depends: linux-image-6.1.0-40-rt-amd64
milos@cnc:~$ apt-cache depends linux-image-6.1.0-40-rt-amd64
Depends: kmod
Depends: linux-base
|Depends: initramfs-tools
Depends: <linux-initramfs-tool>
dracut
initramfs-tools
tiny-initramfs
Conflicts: linux-image-6.1.0-40-rt-amd64-unsigned
Breaks: fwupdate
Breaks: initramfs-tools
Breaks: wireless-regdb
Recommends: firmware-linux-free
Recommends: apparmor
Suggests: linux-doc-6.1
Suggests: debian-kernel-handbook
|Suggests: grub-pc
|Suggests: grub-efi-amd64
Suggests: extlinux
Replaces: linux-image-6.1.0-40-rt-amd64-unsigned
what should I do next? I don't understand this.:(
Last edit: 07 Oct 2025 00:38 by Digger011.
  • Moderator
  • Moderator
07 Oct 2025 00:42 #335965 by tommylight
Replied by tommylight on topic Strugling with installation
10 Oct 2025 18:45 #336210 by Digger011
I believe you referred to this to run
# rm /etc/{initramfs/post-update.d/,kernel/{postinst.d/,postrm.d/}}z50-raspi-firmware
# apt purge raspi-firmware
What should I do after that? I apologize Tommy, but I have no idea what should I do.
Thanks.
10 Oct 2025 20:06 #336222 by andypugh
Replied by andypugh on topic Strugling with installation
Is this with the LinuxCNC install image?
10 Oct 2025 21:05 #336235 by Digger011
This is what I have a problem with after installing from LinuxCNC install image linux_2.9.4-amd64.hybrid
Is this correct?
  • Moderator
  • Moderator
10 Oct 2025 21:41 #336240 by tommylight
Did you do this
sudo apt purge raspi-firmware
After you do
sudo apt update
then you can upgrade if you want to
[sudo apt upgrade[/code]
Then you can install whatever you want as usual.
10 Oct 2025 22:50 #336245 by Digger011
Tommy, thanks for the instructions.
milos@cnc:~$ apt list --upgradable
Listing... Done
libtiff-dev/oldstable-security 4.5.0-6+deb12u3 amd64 [upgradable from: 4.5.0-6+deb12u2]
libtiff6/oldstable-security 4.5.0-6+deb12u3 amd64 [upgradable from: 4.5.0-6+deb12u2]
libtiffxx6/oldstable-security 4.5.0-6+deb12u3 amd64 [upgradable from: 4.5.0-6+deb12u2]
milos@cnc:~$ sudo apt upgrade libtiff-dev/oldstable-security 4.5.0-6+deb12u3 amd64
Reading package lists... Done
Building dependency tree... Done
Reading state information... Done
E: Unable to locate package 4.5.0-6+deb12u3
E: Couldn't find any package by glob '4.5.0-6+deb12u3'
E: Unable to locate package amd64
Calculating upgrade... Done
The following packages will be upgraded:
  libtiff-dev libtiff6 libtiffxx6
3 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
3 not fully installed or removed.
Need to get 916 kB of archives.
After this operation, 0 B of additional disk space will be used.
Do you want to continue? [Y/n] y
Get:1 security.debian.org/debian-security bookworm-security/main amd64 libtiff-dev amd64 4.5.0-6+deb12u3 [456 kB]
Get:2 security.debian.org/debian-security bookworm-security/main amd64 libtiff6 amd64 4.5.0-6+deb12u3 [316 kB]
Get:3 security.debian.org/debian-security bookworm-security/main amd64 libtiffxx6 amd64 4.5.0-6+deb12u3 [144 kB]
Fetched 916 kB in 0s (2,671 kB/s)
(Reading database ... 180636 files and directories currently installed.)
Preparing to unpack .../libtiff-dev_4.5.0-6+deb12u3_amd64.deb ...
Unpacking libtiff-dev:amd64 (4.5.0-6+deb12u3) over (4.5.0-6+deb12u2) ...
Preparing to unpack .../libtiff6_4.5.0-6+deb12u3_amd64.deb ...
Unpacking libtiff6:amd64 (4.5.0-6+deb12u3) over (4.5.0-6+deb12u2) ...
Preparing to unpack .../libtiffxx6_4.5.0-6+deb12u3_amd64.deb ...
Unpacking libtiffxx6:amd64 (4.5.0-6+deb12u3) over (4.5.0-6+deb12u2) ...
Setting up initramfs-tools (0.142+deb12u3) ...
update-initramfs: deferring update (trigger activated)
Setting up libtiff6:amd64 (4.5.0-6+deb12u3) ...
Setting up libtiffxx6:amd64 (4.5.0-6+deb12u3) ...
Setting up linux-image-6.1.0-40-rt-amd64 (6.1.153-1) ...
/etc/kernel/postinst.d/dkms:
dkms: running auto installation service for kernel 6.1.0-40-rt-amd64.
dkms: autoinstall for kernel: 6.1.0-40-rt-amd64.
/etc/kernel/postinst.d/initramfs-tools:
run-parts: /etc/kernel/postinst.d/initramfs-tools exited with return code 1
dpkg: error processing package linux-image-6.1.0-40-rt-amd64 (--configure):
 installed linux-image-6.1.0-40-rt-amd64 package post-installation script subprocess returned error exit status 1
Setting up libtiff-dev:amd64 (4.5.0-6+deb12u3) ...
dpkg: dependency problems prevent configuration of linux-image-rt-amd64:
 linux-image-rt-amd64 depends on linux-image-6.1.0-40-rt-amd64 (= 6.1.153-1); however:
  Package linux-image-6.1.0-40-rt-amd64 is not configured yet.
 initramfs-tools
Wonering what am I doing wrong.
M
  • Moderator
  • Moderator
10 Oct 2025 22:57 #336246 by tommylight
Try
sudo apt purge *raspi*
then sudo apt update
Sorry, i copied and pasted that line from the post i linked and now i noticed that line will not work as was written there, dang, now i have to find all the posts about it and fix them.
Not my mess, luckily, but i hate dealing with it as it's been dragging for over a year now, all because someone did not clean the build environment before building the ISO.
10 Oct 2025 23:28 #336250 by Digger011
No problem Tommy, I should be sorry to bug you for all of this.
Here is what is going on:
milos@cnc:~$ sudo apt purge *raspi*
[sudo] password for milos:
Note, selecting 'linux-firmware-raspi3' for glob '*raspi*'
Note, selecting 'raspi-firmware' for glob '*raspi*'
Note, selecting 'raspi3-firmware' for glob '*raspi*'
Package 'linux-firmware-raspi3' is not installed, so not removed
Package 'raspi3-firmware' is not installed, so not removed
The following packages will be REMOVED:
  raspi-firmware*
0 upgraded, 0 newly installed, 1 to remove and 0 not upgraded.
milos@cnc:~$ sudo apt update
Hit:1 deb.debian.org/debian bookworm InRelease
Hit:2 deb.debian.org/debian bookworm-updates InRelease
Hit:3 security.debian.org/debian-security bookworm-security InRelease
Hit:4 www.linuxcnc.org bookworm InRelease
Hit:5 repository.qtpyvcp.com/apt develop InRelease
Hit:6 download.opensuse.org/repositories/science:/EtherLab/Debian_12 ./ InRelease
All packages are up to date.
Does it mean that everything is ok now? There was an error, but after update it looks ok.
M
Time to create page: 0.465 seconds
