Debian 12 - Bookworm Live installer ISO for linuxcnc (x86_64)
- Stefan85
07 Jan 2024 05:37 #290078
by Stefan85
Replied by Stefan85 on topic Debian 12 - Bookworm Live installer ISO for linuxcnc (x86_64)
tommylight, Thanks for the explanations.
rodw, I'll just replace my old computer.
- avakato
09 Jan 2024 10:03 - 09 Jan 2024 10:10 #290282
by avakato
Replied by avakato on topic Debian 12 - Bookworm Live installer ISO for linuxcnc (x86_64)
First I would just like to say thank you for all your work on this and am glad you are getting better.
I would just like to report that I just did a fresh install of LinuxCNC 2.9.2 from (www.linuxcnc.org/iso/LinuxCNC_2.9.2-amd64.hybrid.iso) and still experience the raspi-firmware script trying to run during an upgrade of the kernel.
The previous solution of removing it along with purging it from it from the system works and allows the upgrade to complete.
I am not sure if the scripts being in the ISO effect it? e.g.
Thank you again!
/etc/kernel/postinst.d/dkms:
dkms: running auto installation service for kernel 6.1.0-17-rt-amd64.
dkms: autoinstall for kernel: 6.1.0-17-rt-amd64.
/etc/kernel/postinst.d/initramfs-tools:
update-initramfs: Generating /boot/initrd.img-6.1.0-17-rt-amd64
raspi-firmware: missing /boot/firmware, did you forget to mount it?
run-parts: /etc/initramfs/post-update.d//z50-raspi-firmware exited with return code 1
Errors were encountered while processing:
# linux-image-6.1.0-17-rt-amd64
# linux-image-rt-amd64The previous solution of removing it along with purging it from it from the system works and allows the upgrade to complete.
# rm /etc/{initramfs/post-update.d/,kernel/{postinst.d/,postrm.d/}}z50-raspi-firmware
# apt purge raspi-firmwareI am not sure if the scripts being in the ISO effect it? e.g.
LinuxCNC_2.9.2-amd64.hybrid.iso\live\filesystem.squashfs\etc\kernel\postinst.d\z50-raspi-firmware
LinuxCNC_2.9.2-amd64.hybrid.iso\live\filesystem.squashfs\etc\initramfs\post-update.d\z50-raspi-firmwareThank you again!
Last edit: 09 Jan 2024 10:10 by avakato.
The following user(s) said Thank You: hilo90mhz
- Thank you received: 4154
09 Jan 2024 13:11 #290293
Replied by rodw on topic Debian 12 - Bookworm Live installer ISO for linuxcnc (x86_64)
This is very frustrating. It needs to be reported as a bug to Debian.
- hilo90mhz
- Thank you received: 3
17 Jan 2024 19:58 #290983
by hilo90mhz
Replied by hilo90mhz on topic Debian 12 - Bookworm Live installer ISO for linuxcnc (x86_64)
I think your line:
Installation of Ethercat - sudo apt install ethercat-master libethercat-dev
should also have:
linuxcnc-ethercat
at the end? that was missing for me.
Thanks for this image! made it wayyy easier than last time
should also have:
linuxcnc-ethercat
18 Jan 2024 01:20 #290999
I think even sudo apt install linuxcnc-ethercat wil do it.
I have not checke but the others should be dependencies
Time to create page: 0.105 seconds
