Debian 12 - Bookworm Live installer ISO for linuxcnc (x86_64)
  • rodw
  • rodw's Avatar Topic Author
  • Platinum Member
  • Platinum Member
29 Oct 2023 16:32 #284047 by rodw
First report of an issue. This is a fork of the Debian Live installer. At this point in the installation, it is all in Debian's hands.
It does sound like it is an issue with your USB or your hardware. It sounds like it does lose contact with your USB. At least Debian told you what to do to resolve it.
29 Oct 2023 19:42 #284068 by JohnnyCNC
Thanks Rod, When I saw it said to reinsert the CD I just thought well, I'll try that with the USB.
Now I am getting this error. My .cfg and .hal files worked with previous versions of 2.9 that I was playing with.
Found file(REL): ./custom.hal
Found file(REL): ./vc-p4s.hal
HAL: ERROR: function 'and2.vc' may only be added to one thread
./vc-p4s.hal:5: addf failed
and2: already exists
Running HAL shutdown script
hm2_eth: in hm2_eth_reset
hm2_eth: HostMot2 ethernet driver unloaded
hm2: unloading
Note: Using POSIX realtime
LinuxCNC terminated with an error. You can find more information in the log:
/home/john/linuxcnc_debug.txt
and
/home/john/linuxcnc_print.txt
as well as in the output of the shell command 'dmesg' and in the terminal
File Name: vc-postgui...0-29.hal
File Size:0 KB
File Name: vc-p4s_2023-10-29.hal
File Size:6 KB
File Name: SiegX3_2023-10-29.ini
File Size:8 KB
File Name: SiegX3_2023-10-29.hal
File Size:14 KB
File Name: custom_postgui.hal
File Size:2 KB
  • rodw
  • Platinum Member
  • Platinum Member
29 Oct 2023 20:41 #284075 by rodw
Looks like its complaining because you have added and2 twice, add and2-vc in the other hal file with the others and comment line 5 out.
The installer worked so my job is done!
The following user(s) said Thank You: JohnnyCNC
29 Oct 2023 21:09 #284078 by JohnnyCNC
Thanks Rod,
I guess I just needed another set of eyes. I must have grabbed the wrong files when I copied my backup config files to the new machine.
Running and homed. Now to start testing.
02 Nov 2023 14:19 #284331 by probotix
Still having this issue:
Errors were encountered while processing:
linux-image-6.1.0-13-rt-amd64
linux-image-rt-amd64
E: Sub-process /usr/bin/dpkg returned an error code (1)
E: An unexpected failure occurred, exiting...
Any ideas?
  • rodw
  • Platinum Member
  • Platinum Member
02 Nov 2023 19:19 #284364 by rodw
You don't say what you did to observe this error.
You could try the recently released 2.9.1 ISO on the Linuxcnc page as this should obsolete my image in the first post
linuxcnc.org/downloads/
07 Nov 2023 17:17 #284801 by 1963
Hello, how to install a package with a Ukrainian or Russian language interface?
  • rodw
  • Platinum Member
  • Platinum Member
07 Nov 2023 19:01 #284812 by rodw
I don't know sorry.
I think there are translations for axis and gmoccappy. Not sure if there are any others.
I thought it should follow your locale settings.
It would be best to ask in another thread.
All available PDF document translations have been deployed with the installer
  • rodw
  • Platinum Member
  • Platinum Member
14 Nov 2023 11:50 #285366 by rodw
The ISO in the first post  has been updated today. The live installer that built the ISO is now the official Linuxcnc one.
There were some changes today and it might take a few days to the linuxcnc downloads page.
The main change is that linuxcnc 2.9.1 is installed from the Linuxcnc repositories so normal apt-get updates are supported.
This should be the final  version.
Please read the first post as it has a few changes
25 Nov 2023 23:41 #286511 by JohnnyCNC
The download in the first post has now ben updated as a fork of the Official Linuxcnc live installer DVD.
Please reread the first post as its changed.
I have sent a pull request to linuxcnc
github.com/LinuxCNC/linuxcnc-live-build/pull/27
After installation, to get the latest 2.9 version of linuxcn just type
sudo apt update
sudo apt upgrade
Mods might like to sticky this.
I am getting an error when I run the "sudo apt upgrade"
dpkg: error processing package initramfs-tools (--configure):
 installed initramfs-tools package post-installation script subproces returned
error exit status 1
 initramfs-tools
I believe that I have installed this in the past without getting this error.   Any ideal what is going on here?
Time to create page: 0.176 seconds
