Debian 12 - Bookworm Live installer ISO for linuxcnc (x86_64)
19 Dec 2023 15:44 #288619 by lunada
I don't understand why this is happening. Is it a new installation?
Why has dkms been loaded? do you have any drivers (eg realtek NIC drivers) installed that requires it?
new installation. downloaded the image maybe a week ago? i dont know what a dkms is. basically i had 2.9pre installed, and it was all working but i was having issues getting glade working, so i decided to install 2.9.1
19 Dec 2023 16:57 #288623 by lunada
i did some googling and found this code, and it seems to have made it happy again.
# rm /etc/{initramfs/post-update.d/,kernel/{postinst.d/,postrm.d/}}z50-raspi-firmware
# apt purge raspi-firmware
  • Platinum Member
  • Platinum Member
19 Dec 2023 18:13 #288629 by Cant do this anymore bye all
Replied by Cant do this anymore bye all on topic Debian 12 - Bookworm Live installer ISO for linuxcnc (x86_64)
dkms is the mechanism via which debian & ubuntu based distros rebuild third party kernel modules when a new kernel is installed.
  • abdulasis12
  • Online
  • Premium Member
  • Premium Member
22 Dec 2023 05:20 #288819 by abdulasis12
From the screen dump, you have nothing to upgrade so its not an issue.
That raspberry pi bug seems to have returned to Debian core code. Its not a Linuxcnc thing
SO the error is in relation to the  rasppi firmware it thinks is installed.
try sudo apt remove z50-raspi-firmware or
sudo apt remove raspi-firmware if it errors
Hi MR.Rodw
I same problem and try to your solution , but can't solve.
have any solution ?
Thank you
Asis.
asis@192:~/Downloads$ sudo apt remove z50-raspi-firmware
Reading package lists... Done
Building dependency tree... Done
Reading state information... Done
E: Unable to locate package z50-raspi-firmware
asis@192:~/Downloads$ sudo apt remove raspi-firmware
Package 'raspi-firmware' is not installed, so not removed
The following packages were automatically installed and are no longer required:
  linux-headers-6.1.0-11-amd64 linux-headers-6.1.0-11-common linux-headers-6.1.0-11-common-rt linux-headers-6.1.0-11-rt-amd64
  linux-headers-6.1.0-13-amd64 linux-headers-6.1.0-13-common linux-image-6.1.0-11-rt-amd64
Use 'sudo apt autoremove' to remove them.
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
4 not fully installed or removed.
After this operation, 0 B of additional disk space will be used.
Setting up initramfs-tools (0.142) ...
update-initramfs: deferring update (trigger activated)
Setting up linux-image-6.1.0-13-rt-amd64 (6.1.55-1) ...
/etc/kernel/postinst.d/dkms:
dkms: running auto installation service for kernel 6.1.0-13-rt-amd64.
dkms: autoinstall for kernel: 6.1.0-13-rt-amd64.
/etc/kernel/postinst.d/initramfs-tools:
update-initramfs: Generating /boot/initrd.img-6.1.0-13-rt-amd64
live-boot: core filesystems dm-verity devices utils udev blockdev dns.
raspi-firmware: missing /boot/firmware, did you forget to mount it?
run-parts: /etc/initramfs/post-update.d//z50-raspi-firmware exited with return code 1
run-parts: /etc/kernel/postinst.d/initramfs-tools exited with return code 1
dpkg: error processing package linux-image-6.1.0-13-rt-amd64 (--configure):
 installed linux-image-6.1.0-13-rt-amd64 package post-installation script subprocess returned error exit status 1
Setting up linux-image-6.1.0-16-rt-amd64 (6.1.67-1) ...
dkms: running auto installation service for kernel 6.1.0-16-rt-amd64.
dkms: autoinstall for kernel: 6.1.0-16-rt-amd64.
update-initramfs: Generating /boot/initrd.img-6.1.0-16-rt-amd64
dpkg: error processing package linux-image-6.1.0-16-rt-amd64 (--configure):
 installed linux-image-6.1.0-16-rt-amd64 package post-installation script subprocess returned error exit status 1
dpkg: dependency problems prevent configuration of linux-image-rt-amd64:
 linux-image-rt-amd64 depends on linux-image-6.1.0-16-rt-amd64 (= 6.1.67-1); however:
  Package linux-image-6.1.0-16-rt-amd64 is not configured yet.
dpkg: error processing package linux-image-rt-amd64 (--configure):
 dependency problems - leaving unconfigured
Processing triggers for initramfs-tools (0.142) ...
dpkg: error processing package initramfs-tools (--configure):
 installed initramfs-tools package post-installation script subprocess returned error exit status 1
Errors were encountered while processing:
 initramfs-tools
E: Sub-process /usr/bin/dpkg returned an error code (1)
  • Moderator
  • Moderator
22 Dec 2023 05:54 #288820 by tommylight
The following user(s) said Thank You: abdulasis12
  • rodw
  • rodw's Avatar Topic Author
  • Platinum Member
  • Platinum Member
22 Dec 2023 13:21 #288834 by rodw
This is a very annoying regression on the debian side.
When I get out of hospital,I will try supressing the installation of   raspi-firmware in the installer.
  • Moderator
  • Moderator
22 Dec 2023 13:37 #288835 by tommylight
When I get out of hospital,...
WTH are you doing in a hospital? :)
Wishing you a fast and painless recovery, from whatever it is.
  • rodw
  • Platinum Member
  • Platinum Member
22 Dec 2023 13:54 #288839 by rodw
Thats what I said! 2 nights ago I was worried about I might have a heart thing going on and went to emergency and they diagnosed pneumonia. Really strange because I had no symptoms for asthma which I would expect from any lung condition. Hopefully I will be home today as we must have got it early.
  • Moderator
  • Moderator
22 Dec 2023 13:57 #288841 by tommylight
Oh good you caught it early, a bit of corticosteroids and it is gone, usually.
  • Platinum Member
  • Platinum Member
22 Dec 2023 20:45 #288860 by Cant do this anymore bye all
Shit Rod, that's bad.
The worst part of pneumonia is the recovery period once you get rid of it.
You were lucky, I went to a quack with all the symptoms of pneumonia and the idiot diagnosed a "sore" throat. Luckily I had the sense to get a second opinion, bacterial pneumonia, not a "sore throat".
Time to create page: 0.135 seconds
