Proposal RPi Linuxcnc Image Based on Raspi OS All welcome/encoraged to comment
22 Oct 2025 21:49 #336924 by unknown
which version of LinuxCNC you're on? before 2.9.5 (I think) it required /sys/kernel/realtime to be present, which is not the case in the Pi kernels. if you're on 2.9.4, you can work around it by setting LINUXCNC_FORCE_REALTIME env var to 1 (I just do 'echo "export LINUXCNC_FORCE_REALTIME=1" >/etc/profile.d/linuxcnc-force-realtime.sh'), or update to a later version.
Just built linuxcnc-2.9.7 on trixie, still appears to need the export, no big issue really.
Don't know if XFCE is the way to go or the LXDE version that comes with raspios.
23 Oct 2025 00:26 #336934 by f355
interesting, the check was removed quite a while ago . I wonder what else does it want.
as to LXDE vs XFCE, I'd probably go with the latter, it's true and tried, and almost no one uses the former - Pi OS uses Wayland and some Wayland-based desktop environment by default, I don't think many people switch to Xorg apart from us.
23 Oct 2025 01:54 #336938 by unknown
I got pretty reasonable results on the RPi5 even with Wayland and LXDE.
Enough that software step generation might be an option for a mill. I was surprised by that.
I've had to go back to the basics with pi-gen, was having issues with it deciding to switch from the graphical target to multiuser.
I've got a bunch of images to test, so stay tuned.
But I think once this is nailed it will be easier to get reproducible results. You've convinced me regarding the kernels. So much easier. Thanks :)
The following user(s) said Thank You: f355
23 Oct 2025 13:07 #336975 by unknown
Image version Twenty Three gazillion.
Standard raspios desktops included plus XFCE, changed lightdm chooser to the gtk-greeter, auto login is enabled, easiest way to change desktop environment is to logout and select the desktop prior to logging in. Still working with Bookworm ATM. Needs a little polishing, need to add the environment variable for realtime, will include a config for XFCE terminal that had a few options setup. And yes I will keep Midnight commander in there, great clone of the old Norton commander dos file manager, the included editor is pretty good as well.
24 Oct 2025 01:41 - 24 Oct 2025 05:14 #337022 by unknown
Current state of Trixie:
Images build fine & boot, with non rt kernel.
6.12.47 kernel crashes
6.12.47 headers cant' be installed due to gcc version issues
6.12.34 kernel is good
6.12.34 headers can't be installed due to gcc version issues
Issues installing Linuxcnc built from image below wont install due to version issues with a lot of packages.
Using Trixie image downloads.raspberrypi.com/raspios_arm64/...-trixie-arm64.img.xz can have 6.12.34 kernel & headers installed.
I'll have to do some greater investigation.
Wanna know a secret, I did a big stupid, didn't realise the image was armf instead of arm64.
Current state of Bookworm.
All appears to be good, build process needs some tweaks, login screen and having xfce the default desktop plus a few little more odds and sods. Basically it works, just would like it a little more user friendly. Good thing regarding this build system is you can set your OS settings when using RPi-Imager, something that was not possible with the earlier build system.
Non necessary stuff (eyecandy), would like to have a linuxcnc themed splash screen (plymouth theming), login background (lightdm config) and desktop background. Just some Linuxcnc "branding".
Last edit: 24 Oct 2025 05:14 by unknown. Reason: Being self aware & admitting my own stupidity
The following user(s) said Thank You: rodw, f355
26 Oct 2025 06:03 #337187 by unknown
Eyecandy is proving to be as issue, especially plymouth.
When image is initially created plymouth splash dispalys.
Using plymouth-set-default -R pix causes the boot splash to disappear. pix s the default so shouldn't be an issue.
So until this can be resolved it's KISS.
26 Oct 2025 12:33 #337228 by andypugh
Just a reminder (it's way down the list of repos now) but we did previously use pi-gen to make LinuxCNC images.
github.com/LinuxCNC/pi-gen
Bitrot has probably set in, though.
26 Oct 2025 15:22 #337248 by unknown
A lot has changed in time.
What was the reason for changing, if known ?
Is it a path worth checking out again ?
In other news.
It would look like the Trixie packages have been built on Bookworm for Arm, is that correct ?
Now that I have a working Trixie image, one image will work for the 4 & 5 would it be useful for package building for Trixie ?
27 Oct 2025 05:51 #337273 by rodw
I doubt it. As of today Andy has got GitHub workflows working for all OS'es including Trixie for both AMD64 and ARM and a full complement of builds on our repo at linuxcnc.org/dists
The following user(s) said Thank You: unknown
27 Oct 2025 07:06 #337276 by unknown
I'll have a look at updating tomorrow and see how it goes.
It would appear the boot splash issue has been resolved.
Now I've looked through the threads on images and it's time for suggestions for splash, login and background images. Splash images have to be smallish PNG files.
Time to create page: 0.895 seconds
