"file ./live/filesystem.squashfs failed the MDS checksum"
- unknown
- Thank you received: 323
06 Nov 2025 17:12 #337986
by unknown
Replied by unknown on topic "file ./live/filesystem.squashfs failed the MDS checksum"
Look honestly unless there is some feature you absolutely must have that is the later versions I would stick with what you have. Even more so if you are using the parallel port. As the later installs do not use an RTAI kernel, which is best for parallel ports.
I think JT runs a lathe that is still on a version of Linuxcnc that runs on Ubuntu 8 or something like that back when the project was called emc2.
Unless you have a download of the image file that passes the md5sum test you are on the road to nowhere. Get that sorted first if you want to proceed.
Before anything back up your Linuxcnc folder that is in your home folder so you don't lose any of your Configs if things go bad.
It may help if you can give some info regarding the machine, are you using a parallel port or not, the CPU on the computer you wish to use, I don't want to look up the specs of the computer you are using as the same model can have different CPU, memory HDD and so forth.
- clayton2ndtry
- Thank you received: 5
06 Nov 2025 17:33 #337988
by clayton2ndtry
Replied by clayton2ndtry on topic "file ./live/filesystem.squashfs failed the MDS checksum"
Thank you. I will attempt to make the USB on my 2.7.15 Linux box.
- clayton2ndtry
06 Nov 2025 17:39 #337989
by clayton2ndtry
I think I have identified my USB drive from dmesg
[ 0.000000] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-3.4-9-rtai-686-pae
root=UUID=d6024873-2470-49d1-992d-a484c0ca8fdf ro initrd=/install/gtk/initrd.gz
lapic quiet rootdelay=5
[ 2.660091] usb usb1: Product: EHCI Host Controller
[ 2.660093] usb usb1: Manufacturer: Linux 3.4-9-rtai-686-pae ehci_hcd
- clayton2ndtry
06 Nov 2025 17:46 #337990
by clayton2ndtry
Dell Optiplex 960. /proc/cpuinfo
Intel(R) Core(TM)2 Duo CPU E8400 @ 3.00GHz
Parallel port. The md5sum test passes.
I have backed up everything.
/proc/meminfo MemTotal: 3071164 kB
Are you telling me that upgrading past 2.7.15 may not work?
- Thank you received: 7478
06 Nov 2025 17:57 #337993
Replied by tommylight on topic "file ./live/filesystem.squashfs failed the MDS checksum"
Yes he is, do not upgrade unless there is something you absolutely need.
If the machine is working properly, NEVER upgrade. This is not MS windows.
I have several (roughly 10) machines using Ubuntu 8.04 and 10.04, all over 15 years old, all still working every day.
- clayton2ndtry
07 Nov 2025 15:46 #338032
by clayton2ndtry
It appears the core problem is that 2.9 requires a 64 bit processor and my antique is a 686. I guess I will be staying in the past untilll I buy a new desktop.
- unknown
07 Nov 2025 16:57 #338036
by unknown
- unknown
07 Nov 2025 17:06 #338037
by unknown
If you really want to upgrade, first thing I would do is boot the latest Linuxcnc image, run latency-histogram --nobase if you get under 100ns latency, rather than upgrade your PC get a mesa 7i92, it will plug into your existing breakout board and start making chips.
Time to create page: 0.133 seconds
