Experimental raspios Linuxcnc Trixie images.
- unknown
- Thank you received: 323
11 Nov 2025 09:06 - 09 Dec 2025 04:31 #338181
by unknown
Experimental raspios Linuxcnc Trixie images. was created by unknown
I've been working on using a new build system for Raspberry images based on the utilities that are used on the official images. No custom kernel as RPi does provide pre-built RT kernels, but the 6.12.47 version has had reports of crashing. And yes raspi-config is included.
Benefits include being able to use Raspberry Pi Imager to preconfigure user name & password, local, all other things Raspberry Imager enable you to configure. There is now a single image for the 4 & 5 models. These are the only models supported. No there is no wayland, so don't try to changes this via raspi-config. The desktop environment is xfce.
I haven't included vnc as that brings in all the CUPS (printing) software and the associated services.
Only one browser is included, Firefox-esr.
Some simple screensver & power management items have been configured.
There is a network applet near the clock to simplify configuring a wired network. Please take note that the Raspberry's network address should not be that same as your mesa card, ie the last number in the address should differ. (sorry for those that are aware, but it pops up from time to time)
I have also included a fix for the CNC items appearing under multiple categories. This will survive upgrades. Due to the way Debian runs these "hooks" it will run after every time apt, apt-get or dpkg is run. Changes will only be made when it is required. No isolcpus has been added to the commandline, but this can be added by the usual methods.
Downloads are here - currently waiting to be updated 09 Dec 2025;
Please note the image on the Linuxcnc downloads page is missing a browser and a pdf reader, but will still run Linuxcnc itself fine. I apologise but so far I've been "on my own" building and testing.
If anyone is willing to test and point out any glaring errors it would be most welcome.
Rob
Any issues please raise here
github.com/ozzyrob/linuxcnc-rpi-2.9.7-image-issues/tree/main
Rob
Last edit: 09 Dec 2025 04:31 by unknown.
The following user(s) said Thank You: lumberjack_jeff, rodw, COFHAL, Aciera
- unknown
12 Nov 2025 05:44 #338236
by unknown
Replied by unknown on topic Experimental raspios Linuxcnc Trixie images.
See above post to links for rc3 downloads.
Stupid things fixed:
Firefox-ESR installed
evince (pdf reader) installed
default kernel is aarch64 6.12.34+rpt-rpi-v8-rt (Raspberry Pi built RT_PREEMPT kernel)
The following user(s) said Thank You: lumberjack_jeff, COFHAL
- COFHAL
- Thank you received: 62
14 Nov 2025 20:35 #338383
by COFHAL
Replied by COFHAL on topic Experimental raspios Linuxcnc Trixie images.
What is the password to log in as a superuser?
- unknown
14 Nov 2025 20:46 #338384
by unknown
The password you setup for your user name.
- COFHAL
14 Nov 2025 21:11 #338389
by COFHAL
I installed probe basic and tried to run it, but it gives an error.
- unknown
14 Nov 2025 21:33 #338402
by unknown
Well I'm not a mind reader, but I think if you fix the error it will work.
- unknown
14 Nov 2025 23:51 #338413
by unknown
This is what pisses me off.
I've spent quite a few weeks working on this, with no input from anyone, no one bothering to lend a hand (testing when I gave links and requested some one to test), and when an issue does come up all I get " I installed probe basic and tried to run it, but it gives an error." with no description of the error.
Can you understand why I may be a little bit terse. If you can't be bothered to give any indication of what the error is or anything like that I'm not going to waster time trying to pull information out of you bit by bit.
- Thank you received: 4149
15 Nov 2025 00:24 #338421
Replied by rodw on topic Experimental raspios Linuxcnc Trixie images.
I'm not even sure that the probe basic/qtpyvcp team even support distributions for the Pi. They never used to.This is what pisses me off.
- COFHAL
15 Nov 2025 01:35 #338426
by COFHAL
I haven't set up any user name.
- COFHAL
15 Nov 2025 01:37 #338427
by COFHAL
If they do it now, I use it on several PIs with Debian 12.
Time to create page: 0.207 seconds
