Experimental raspios Linuxcnc Trixie images.
15 Nov 2025 01:40 - 15 Nov 2025 02:01 #338429 by COFHAL
Perhaps I wasn't more specific, but the error message indicates that it can't find the imp module.Then I send a screenshot of the error.From what I've read now, it seems to be due to something related to the Python version.
Last edit: 15 Nov 2025 02:01 by COFHAL.
15 Nov 2025 01:51 #338430 by unknown
Replied by unknown on topic Experimental raspios Linuxcnc Trixie images.
First of all I recommended to use the Rpi Imager to setup username, locale, and the other things needed.
If you didn't do this you should have gone through the setup screens to configure things.
This would have given you a user name.
This image is NOT LIKE the former images, it is based on the infrastructure that build the raspios images. The idea was to make it easier to setup the image and not have a preconfigured username and password.
The following user(s) said Thank You: lumberjack_jeff, COFHAL
15 Nov 2025 02:00 #338431 by COFHAL
I understand, but I installed GParted and Synaptic, and both require a password to log in. I use both because I have an SSD, and Synaptic for other tasks. I set a password in raspi-config, but it doesn't work to log in to these applications.
15 Nov 2025 02:30 #338433 by unknown
You've done something terribly wrong,
1; Didn't use RPi Imager to setup the settings
2: Choose to ignore the setup dialogue on the first boot.
In both instances you should have been able to setup a user name & password, the password for your account is the one that you use for sudo.
Both gparted and synaptic work when setup following the advice above.
imp can be replaced with (this module was removed from the version of python3 on trixie)
sudo apt install python3-zombie-imp
To go any further I think you will need to ask whether ProbeBasic and pyqtvcp has Trixie support.
The following user(s) said Thank You: COFHAL
15 Nov 2025 19:27 #338466 by COFHAL
I fixed the missing module with your instructions, and another one appeared related to QT5. I checked the error on the web, and it was also due to a missing module. I installed it, and PROBEBASIC worked. I also reinstalled the image with your instructions, and now everything works fine. Thank you for your support.
15 Nov 2025 21:57 #338469 by unknown
Would it be possible for you to give any information regarding the missing module and the installation process ?
16 Nov 2025 02:09 #338486 by COFHAL
I'll send you the information tomorrow because I don't have it here at my house.
16 Nov 2025 02:20 #338488 by unknown
Don't bother no longer needed.
09 Dec 2025 04:37 #339893 by unknown
Mentioned in first post but will add here, in case it catches anyone's attention.
Any issues please raise here, trying to cut back forum usage to almost nil.
github.com/ozzyrob/linuxcnc-rpi-2.9.7-image-issues/tree/main
The following user(s) said Thank You: tommylight, COFHAL
29 Jan 2026 00:56 #342115 by COFHAL
How do I create an image of the contents of one hard drive to install it on another? This is to avoid having to reinstall the additional applications I use with LCN.
Time to create page: 0.209 seconds
