Installation v2.9.7 linuxcnc in November 2025.
  • abs32
  • Topic Author
  • Senior Member
  • Senior Member
11 months 2 weeks ago - 11 months 2 weeks ago #338564 by abs32
I downloaded the image of disk 2.9 and allowed network connection during installation. After installation, it was loaded normally, everything is working, linuxcnc-uspace.
We follow the instructions -
apt-get update
apt-get install linuxcnc
linuxcnc.org/docs/2.9/html/getting-start...#cha:Installing-RTAI
He swears, there is no such package! The list of sources indicates -
deb linuxcnc.org bookworm base
I run synaptic, the kernel is 5.4.258-rtai
I order it to be installed and heads -
Last edit: 11 months 2 weeks ago by abs32.
  • abs32
  • Topic Author
  • Senior Member
  • Senior Member
11 months 2 weeks ago - 11 months 2 weeks ago #338573 by abs32
Error in published instruction. It should actually be -
vi sources.list.d/linuxcnc-uspace.list
deb [arch=amd64,arm64 signed-by=/etc/apt/trusted.gpg.d/linuxcnc.gpg.key.binary.gpg] www.linuxcnc.org/ bookworm base 2.9-uspace 2.9-rt
  • abs32
  • Topic Author
  • Senior Member
  • Senior Member
11 months 2 weeks ago - 11 months 2 weeks ago #338619 by abs32
So, it doesn't work.
To begin with, we had to solve the problems of inaccuracy of the installation description instructions. The downloaded attribute immediately after installation shows us v2.9.7 userspace. In order to install 2.9.2 rt you had to -
1. Overcome the distribution configuration error by removing the file stub for the raspberry -
forum.linuxcnc.org/38-general-linuxcnc-q...d-apt-problem#332403
sudo rm /etc/{initramfs/post-update.d/,kernel/{postinst.d/,postrm.d/}}z50-raspi-firmware
2.then you need to fix the first line of the file by adding 2.9-rt to its end
vi /etc/apt/sources.list.d/linuxcnc-uspace.list
3. then you need to completely remove version 2.9.7
forum.linuxcnc.org/9-installing-linuxcnc...tall-rtai-got-errors
apt-get purge linuxcnc-uspace
apt-get purge linuxcnc-doc*
4. then you need to put the kernel (and only the kernel!)
wget www.linuxcnc.org/dists/bookworm/base/bin...ai-amd64-2_amd64.deb
dpkg -i linux-image-5.4.258-rtai-amd64_5.4.258-rtai-amd64-2_amd64.deb
5. This new kernel will now appear in boot options, you need to reboot the computer by selecting this particular kernel 5. And only now supply additional components -
wget www.linuxcnc.org/dists/bookworm/base/bin...xcnc-delta_amd64.deb
dpkg -i rtai-modules-5.4.258_5.3.3-linuxcnc-delta_amd64.deb
Now you can apt-get update + apt-get update
A running real-time kernel will always show 100% CPU load and does not need a swap. latensy-test starts and shows normal numbers.
An attempt to start the existing machine configuration leads to a system crash and reboot. Okay, stepconf and I create a new configuration, extremely simple. I launch it and also get a reboot.
Debug file information:
/usr/bin/linuxcnc: line 977:913 Segmentation error $EMCDISPLAY -ini "$INIFILE" $EMCDISPLAYARGS $EXTRA_ARGS
/usr/bin/milltask exiting
How to overcome this problem?
A discussion of the problem has been initiated here, but there is no solution
forum.linuxcnc.org/18-computer/51070-fro...-kernel-rtai-5-4-258
Time to create page: 0.047 seconds
