Mesa 7I96s - 5 AXIS
- Thank you received: 5328
27 Nov 2025 23:58 - 28 Nov 2025 00:00 #339355
Replied by PCW on topic Mesa 7I96s - 5 AXIS
Really don't see what could be different between configurations that affect basic communications.
unless there is some marginal power issue (does the 7I96S reset when starting the 5 axis configuration?)
Or maybe a memory fault of some kind in the PC, the reported error really has nothing to do with the number
of axis.
And as I said, your 5 axis hal/ini files work fine here with a 7I96S
A pncconf created configuration might be worth a try, just to see if a quite different
5 axis configuration changes the symptoms.
of axis.
Last edit: 28 Nov 2025 00:00 by PCW.
- jmp97
30 Nov 2025 10:20 #339481
by jmp97
Replied by jmp97 on topic Mesa 7I96s - 5 AXIS
It's working now. But I have no idea what was wrong. I tried so many things, one of them must have worked. Thanks for your help
Time to create page: 0.070 seconds
