LinuxCNC 2.9.8 Image with Debian Trixie
04 Jan 2026 05:13 - 19 Apr 2026 12:44 #340954 by michaeln
LinuxCNC 2.9.8 Image with Debian Trixie was created by michaeln
Hello,
i installed the new LinuxCNC 2.9.8 Image with Debian Trixie and think the installation is not "ready to use" and need work.
First add the Debian repositories:
With
sudo nano /etc/apt/sources.list
add the lines:
deb deb.debian.org/debian stable main contrib non-free-firmware
deb-src deb.debian.org/debian stable main contrib non-free-firmware
deb security.debian.org/debian-security stable-security main contrib non-free-firmware
deb-src security.debian.org/debian-security stable-security main contrib non-free-firmware
Edit on 2026-04-19
sudo nano /etc/apt/sources.list.d/trixie-updates.sources
and add the lines:
Types: deb deb-src
URIs: deb.debian.org/debian
Suites: trixie trixie-updates
Components: main contrib non-free-firmware
Signed-By: /usr/share/keyrings/debian-archive-keyring.gpg
Architectures: amd64
After that:
sudo apt update
sudo apt upgrade
sudo apt autoremove
or together in one line:
sudo apt update && sudo apt upgrade && sudo apt autoremove
Select and activate your language:
sudo dpkg-reconfigure locales
and your timezone:
sudo tzselect
Best regards
Michael
P.S.: With this Trixie-Image the old raspi-firmware bug seems to be away.
Last edit: 19 Apr 2026 12:44 by michaeln.
04 Jan 2026 05:30 #340957 by rodw
Replied by rodw on topic LinuxCNC 2.9.8 Image with Debian Trixie
Debian trixie uses the new deb822 format so sources.list is no longer used.
Instead  look in /etc/apt/sources.list.d/debian.sources for the sources in the new format
04 Jan 2026 06:19 #340958 by michaeln
Replied by michaeln on topic LinuxCNC 2.9.8 Image with Debian Trixie
Hello rody,
thank you for your input.
The old way is working too. Synaptic use the old one if you add there sources, too
04 Jan 2026 06:20 #340959 by andypugh
Replied by andypugh on topic LinuxCNC 2.9.8 Image with Debian Trixie
I did notice on a previous installation that the sources only included the CD.
Let me investigate further.
04 Jan 2026 06:35 #340961 by unknown
Replied by unknown on topic LinuxCNC 2.9.8 Image with Debian Trixie
Yeah the raspi-image thing was related to a config issue and the version of live-build being used.
04 Jan 2026 08:55 #340966 by JT
I would not use stable in the repositories because the os can change next time debian is released. Better to use trixie... to bad debian doesn't do something sensible like using numbers.
JT
04 Jan 2026 09:04 #340968 by JT
I added the mesact repository in debian 13 to synaptic package manager and it put it in sources.list... so it must still work.
JT
04 Jan 2026 11:18 #340974 by JT
Also note that there is no /etc/apt/sources.list.d/debian.sources in my Debian 13 after doing a full upgrade.
JT
05 Jan 2026 01:13 #340998 by rodw
JT
yes the old format is retained on a full upgrade from Bookworm but it will nag you on an apt update to run sudo apt modernize-sources if I got the spelling right...
Debian says the old format will be removed in time.
06 Jan 2026 09:52 #341072 by JT
JT
This was an upgrade of Debian 13 not 12.
JT
Time to create page: 0.577 seconds
