Cloning LinuxCNC - Axis and Mesa 7196s
- slowpoke
- Thank you received: 28
16 Jan 2026 11:18 #341455
by slowpoke
Cloning LinuxCNC - Axis and Mesa 7196s was created by slowpoke
I'm putting together my third LinuxCNC system. Using Axis and a Mesa 7i96s
This one will be an almost direct copy of a previous installation I did for my small lathe, this time for a new lathe.
To get started I ran the PCNConf wizard skipping over some of the configuration just to get to the point where LinuxCNC will launch.
Now I'm hoping to simply substitute in a copy of the hal files from my old installation (basically replace the hal files PcnConf made with my old tried and true hal files).
Does this sound like a viable plan?
Possible wrinkles:
One possible wrinkle is that I needed more I/O on the previous 7i96s and I did some sort of "firmware upgrade" to the 7i96s to get more encoders via the expansion port so I will need to do that again. need to see if I can find my notes for that. Also not sure if the old upgrade file is still viable?
Both setups use a Lenovo Yoga, however the latest oneĀ (Chromebook C340) requires a USB-C to dock to get an Ethernet connection. I picked up a dock from Amazon (UGREEN) and have managed to get the Mesa card recognized by LinuxCNC but the mouse (also connected to the dock) seems to go to sleep (often) and I have changed the power saving setting to stop this, but they don't seem to be preventing mouse sleeps. My concern is that the entire dock might be going to sleep including the Ethernet port.
Any advice is welcome.
Possible wrinkles:
- Thank you received: 1482
16 Jan 2026 13:02 #341457
Replied by Todd Zuercher on topic Cloning LinuxCNC - Axis and Mesa 7196s
There was no need to even run PNCconfig. You can simply copy the whole config directory from the old machine to the new machine.
The following user(s) said Thank You: rreddy2go, slowpoke
- Thank you received: 4154
17 Jan 2026 01:11 #341468
Replied by rodw on topic Cloning LinuxCNC - Axis and Mesa 7196s
Sometimes, I have set up a basic working machine ignoring the motion parameters. Once I have any motion working, I cut and past the tried and proven motion from the old config to the new one.
But if they are the same, just copy the folder.
The following user(s) said Thank You: slowpoke
Time to create page: 0.212 seconds
