Installing Linux CNC on Spinner lathe
07 Mar 2026 09:47 #343981 by elkhan039
Installing Linux CNC on Spinner lathe was created by elkhan039
Hi everyone,
i have 2006 Spinner TC65MC lathe machine with Sinumerik810D, i cant use this machine becaus i dont know Shopturn and only CAM progrmming with small using . Can i change it to Linux CNC ? If yes how i can do this ?
07 Mar 2026 15:08 #343990 by tommylight
Replied by tommylight on topic Installing Linux CNC on Spinner lathe
Yes, but not easy as it does require changing the PC and controllers and IO boards if any.
You can not just install LinuxCNC as the existing PC is probably to old and the controller will most probably not be able to communicate with LinuxCNC.
