GRUB bootloader failed
- Twitchy88
- Thank you received: 4
10 May 2026 20:48 #346317
by Twitchy88
GRUB bootloader failed was created by Twitchy88
I dont know what else to try. I had linuxcnc running but decided to do a fresh install to the newest. I have spent all day enabling csm, disabling csm. made a bootable usb with rufus, then tried making it one UBUNTU. No success. UEFI says grub efi amd64 package failed. trying legacy install results in something wrong with the screen resolution and unable to read the screen so i installed a video card which fixed that problem.
legacy gives me the error grub pc package failed to install. what else can I try. B550 motherboard and ryzen 5 cpu.
- Thank you received: 7484
10 May 2026 21:38 #346318
Replied by tommylight on topic GRUB bootloader failed
Connect it to internet.
Do ask me why, i have no clue as the Debian netinstall installs just fine without internet and so do all other versions.
- Twitchy88
10 May 2026 22:18 #346320
by Twitchy88
Replied by Twitchy88 on topic GRUB bootloader failed
It is plugged in and at that part of the setup there is no issues. Maybe I will try live and make sure.
11 May 2026 00:05 #346321
Disable secure boot, enable CMS, try UEFI and/or Legacy.
All in BIOS.
While at it, disable TMP if any.
All in BIOS.
- Twitchy88
11 May 2026 01:55 #346323
by Twitchy88
just tried all that again, no luck. I did get a new message this time asking if I would like to force UEFI setup. But still failed at grub install.
- Twitchy88
12 May 2026 01:31 #346332
by Twitchy88
Any more suggestions? I've now wasted another night after work trying to do this. I've downloaded the iso again and put it on a different stick. Updated bios. Confirmed internet via live.
12 May 2026 01:57 #346333
Do you have another PC that you can use to install?
You can put the hard drive from this PC into another PC, install it there, then move it back to this PC.
Usually it works first try, granted it does install on the other PC.
Make sure to disconnect the hard drives on the other PC before all this to prevent accidentally wiping it.
- Twitchy88
12 May 2026 02:02 #346334
by Twitchy88
I guess I could try. Little bit harder as im using a m.2 ssd
- Twitchy88
12 May 2026 02:57 #346338
by Twitchy88
Thanks for the help.
Installing it on another computer worked. At first it gave the same error because it didnt have the drivers for the wireless card. Plugged it in and it installed no problem. Im wondering if I wasnt getting internet on the cnc, it said it connected successfully and internet worked when I booted live.
Time to create page: 0.820 seconds
