GRUB bootloader failed
5 months 2 weeks ago #346333 by tommylight
Replied by tommylight on topic GRUB bootloader failed
Do you have another PC that you can use to install?
You can put the hard drive from this PC into another PC, install it there, then move it back to this PC.
Usually it works first try, granted it does install on the other PC.
Make sure to disconnect the hard drives on the other PC before all this to prevent accidentally wiping it.
5 months 2 weeks ago #346334 by Twitchy88
Replied by Twitchy88 on topic GRUB bootloader failed
I guess I could try. Little bit harder as im using a m.2 ssd
5 months 2 weeks ago #346338 by Twitchy88
Thanks for the help.
Installing it on another computer worked. At first it gave the same error because it didnt have the drivers for the wireless card. Plugged it in and it installed no problem.  Im wondering if I wasnt getting internet on the cnc, it said it connected successfully and internet worked when I booted live.
Time to create page: 0.054 seconds
