LinuxCNC 2.9 Live image won't boot with MBR
03 Jun 2026 22:42 #346884 by Warxcell
Hello, I've been running LinuxCNC 2.7 for 8 years now and I've decided to upgrade to LinuxCNC 2.9 because it's a 32bit installation, and software support is no longer a thing, browser is barely working, no modern SSH keys support (cannot use github anymore) - so I decided to upgrade to LinuxCNC 2.9 by doing fresh installation.
The problem is that PC won't boot from USB. I used dd to copy ISO to USB - and it boots on my modern desktop, but it won't boot on that old PC.
Is it because ISO contains only UEFI and not MBR ? What is the solution here?
04 Jun 2026 00:23 #346886 by tommylight
Replied by tommylight on topic LinuxCNC 2.9 Live image won't boot with MBR
Probably, but how old is that PC?
04 Jun 2026 08:05 #346891 by Warxcell
Replied by Warxcell on topic LinuxCNC 2.9 Live image won't boot with MBR
2009.
I managed to boot - the issue was "Legacy USB Support" option in BIOS - it was turned off.
With this option turned on - USB storage is emulated as Hard Disk Drive - and I was able to boot.
But now I'm testing jitter - and it's waaay to high.
With LinuxCNC 2.7 - max jitter was 25k.
With LinuxCNC 2.9 - max jitter is 3 million.
I installed RTAI kernel - but it cannot boot at all (it says give up on waiting root device). PREEMPT-RT works fine.
Any ideas?
04 Jun 2026 11:27 #346893 by rodw
What are PC specs. cpu, number of cores,  RAM.
04 Jun 2026 17:13 #346904 by Warxcell
MB: P5g41t-m lx
CPU: Intel Core2Duo E7600
Memory: 4GB Ram.
04 Jun 2026 19:11 #346907 by tommylight
Definitely 2.7.
05 Jun 2026 07:00 #346909 by rodw
MB: P5g41t-m lx
Memory: 4GB Ram.
2 cores is not enough anymore. You need 4 cores, 8 gb might be better but 4 gb will work.
06 Jun 2026 23:06 #346943 by Warxcell
Yeah I guess I will stay with 2.7 forever now (or until PC dies). :)
Meantime I will start experimenting with ESP32 + FluidNC or grblHAL.
Thanks for answers.
Time to create page: 0.876 seconds
