Parallel port access is not allowed
07 Jul 2026 10:14 #347578 by aaron
I am trying to install LCNC (debian12) onto a new second hand Dell desktop. I have copied configuration files across. but when I try to start the software I am getting this error:
iopl() failed: Operation not permitted
cannot gain I/O privileges - forgot 'sudo make setuid' or using secure boot? -parallel port access is not allowed
Note: Using POSIX realtime
Linux parallel port 0 not found
hal_parport: rtapi_app_main: No such file or directory (-2)
./4_Axis_Mill.hal:6: waitpid failed /usr/bin/rtapi_app hal_parport
./4_Axis_Mill.hal:6: /usr/bin/rtapi_app exited without becoming ready
./4_Axis_Mill.hal:6: insmod for hal_parport failed, returned -1
4976
Stopping realtime threads
Unloading hal components
Any Help gratefully received
07 Jul 2026 13:10 - 07 Jul 2026 16:47 #347583 by tommylight
Replied by tommylight on topic Parallel port access is not allowed
Check the BIOS, disable "secure boot" if enabled.
Might also need to enable "CMS" as the PC might refuse to boot.
Edit:
Should be CSM, not CMS.
Last edit: 07 Jul 2026 16:47 by tommylight.
07 Jul 2026 14:09 #347584 by aaron
Replied by aaron on topic Parallel port access is not allowed
Thanks for your reply. I will try it in the morning. Can you tell me what CMS is?
07 Jul 2026 14:48 #347585 by MikkelRS
Replied by MikkelRS on topic Parallel port access is not allowed
CSM, Compatibility Support Module, which helps newer bios's boot older styles of OSs.
07 Jul 2026 16:49 #347589 by tommylight
Thank you, MikkelRS, edited my previous post to reflect the correction.
15 Jul 2026 03:03 #347783 by aaron
Thanks, everybody.  Turns out the parallel port card was a cheap one that, wouldn't work anyway.
Got a new one and everything seems okay.
Cheers
Time to create page: 0.799 seconds
