loading debian 10 on a very old compaq Presario dual boot
- 858PSJ
- Thank you received: 9
16 Sep 2026 08:10 #349677
by 858PSJ
loading debian 10 on a very old compaq Presario dual boot was created by 858PSJ
Had three problems loading the Debian 10 iso (from a dvd I made)
1. the download script would not get past the step where it partitioned the disk until I used the menu option to format partition #3.
(I even waited whilst the script wrote 90 GB of zeroes on that drive, before discovering the format fix)
2. The UUIDS in the grub .cfg file were changed (somehow) to where they were incorrct for my other linux kernel, although the UUIDS for debian were correct. the /etc/fstab file for my other OS was adjusted to where the UUID entry were removed from that file, /etc/fstab for debian were correct and included swap)
3. Debian would crash on booting until I removed the boot=plainroot option from the debian vmlinux line in grub.cfg. (I also removed the quiet option)
- tuxcnc
- Thank you received: 59
16 Sep 2026 09:58 #349678
by tuxcnc
Replied by tuxcnc on topic loading debian 10 on a very old compaq Presario dual boot
It's hard to help you when we don't know what you're doing, how you're doing it and why you're doing it.
It happens that the installer has a problem using a partition formatted in a different operating system or with specific programs. Then the actual solution is to tell him to format the partition in his own way.
The rest of your post has no sense and difficult to respond to.
- 858PSJ
16 Sep 2026 14:07 #349684
by 858PSJ
Replied by 858PSJ on topic loading debian 10 on a very old compaq Presario dual boot
Worse than what you describe, apparently I've gotten a pre-release version? The grub.config line says its booting vmlinuz6-12.95+deb13-rt-amd64
the words debian 13 show on my screen after boot for awhile then go away, I got the iso file by searching the linuxcnc site because the link to download wouldn't work for me .
on the other hand, linuxcnc says its axis.ngc - Axes 2.9.10 on LinuxCNC-HAL-SIM-AXIS
and it will simulate some parts, I'm still checking. It seems to be working very good so far, internet works, playing mp3's work, terminal works, selecting applications seems to work, usb drives seem to work.
probably too early to submit bug report here but thanks for the reply.
The following user(s) said Thank You: NWE
- Thank you received: 4155
17 Sep 2026 01:47 #349694
Replied by rodw on topic loading debian 10 on a very old compaq Presario dual boot
2.9.10 is the current release so that is all good. Iwould expect you are therefore running Debian 13 if you used the LinuxCNC ISO
Time to create page: 0.560 seconds
