Installing 2.10 master
30 Sep 2026 16:12 #350011 by bentiggin
Installing 2.10 master was created by bentiggin
I have decided to try another computer my plasma.
I tried to update to 2.10 on my old setup, but somehow failed.
Since my linux skills are so bad, I decided I should have a linux expert at my side with my newest attempt.
Problem is, I don't have the words to explain to them what exactly I need help with, so I'm asking for help I what directions I should give them.
First off, since it's a fresh install, am I better off installing linuxcnc 2.9.8 and then updating to 2.10, or just start with 2.10?
I assume I use the linuxcnc github to source the correct files?
Basically, what should I tell someone familiar with linux, but not linuxcnc, to get them started on the right path to helping me get linuxcnc 2.10?
In case your curious, I want to use 2.10 for some of the plasmac updates and so I can use pnccomf for my 7i97t.
Thanks in advance, I know there is a lot of information on how to do this on this forum, but when I tried, lunuxcnc would still open to the previous version. Hopefully with a little help, I'll get it this time.
  • grandixximo
  • grandixximo's Avatar
  • Online
  • Platinum Member
  • Platinum Member
01 Oct 2026 04:13 #350028 by grandixximo
Replied by grandixximo on topic Installing 2.10 master
There are installable artefacts in the GitHub actions, get a GitHub account, download those for your system, and install, I would reccomend to use a system for which the CI already builds, you'll have yourself way less headaches :-)
  • grandixximo
  • Online
  • Platinum Member
  • Platinum Member
01 Oct 2026 04:14 #350029 by grandixximo
2.10 is currently transitioning to the a new hal API, so mind that is still somewhat work in progress, there is no 2.10 finished release
01 Oct 2026 06:56 #350031 by tuxcnc
Replied by tuxcnc on topic Installing 2.10 master
2.10 only partially supports Debian 13.
I can't check everything, but it looks like any qtvcp based gui won't work.
Changes in Python traditionally cause the problem.
A new version of numpy, but maybe something else too.
You can work around the problem by installing LinuxCNC on Debian 12, or downgrading some Python packages on Debian 13.
This is of course not a solution to the problem, the solution will be to repair the LinuxCNC sources, but so far no one wants to do that...
  • grandixximo
  • Online
  • Platinum Member
  • Platinum Member
01 Oct 2026 08:25 #350033 by grandixximo
All qtvcp UI work on Debian 13, I'm not sure what python problem you are referring to, is this on the latest master?
01 Oct 2026 08:39 #350035 by rodw
Replied by rodw on topic Installing 2.10 master
Tuxcnc had some python package version issues when using Debian 13.7 which was only released on 12 September. Just try upgrading debian and see if master branch  breaks now.
  • grandixximo
  • Online
  • Platinum Member
  • Platinum Member
01 Oct 2026 09:22 #350036 by grandixximo
No, nothing breaks for me, I am on 13.7 I will investigate the other thread...
  • grandixximo
  • Online
  • Platinum Member
  • Platinum Member
01 Oct 2026 11:12 #350039 by grandixximo
Already replied about the issue in your other post, as far as I can tell the issue is not with the LinuxCNC sources as Chris Morley tried to explain (maybe poorly) in the other thread... Anyhow, if you want the devs to take action on issues you find, you should post an issue in github, or mail the dev mailing list This email address is being protected from spambots. You need JavaScript enabled to view it. if you'd rather do that, we are much more active there. This turn I think it is not a LinuxCNC issue, but next one might, so if you find anything you think is related to the LinuxCNC sources, please report to the channels where the devs are most active...
01 Oct 2026 13:42 #350044 by tuxcnc
The matter became clear.
The problem I described was caused by installing the bcnc program.
So you can use LinuxCNC 2.10 with Debian 13.
At least until you install something that breaks Python's dependencies...
Time to create page: 0.151 seconds
