tuxcnc wrote: This is of course not a solution to the problem, the solution will be to repair the LinuxCNC sources, but so far no one wants to do that...
Already replied about the issue in your other post, as far as I can tell the issue is not with the LinuxCNC sources as Chris Morley tried to explain (maybe poorly) in the other thread... Anyhow, if you want the devs to take action on issues you find, you should post an issue in github, or mail the dev mailing list emc-users@lists.sourceforge.net if you'd rather do that, we are much more active there. This turn I think it is not a LinuxCNC issue, but next one might, so if you find anything you think is related to the LinuxCNC sources, please report to the channels where the devs are most active...
