Installed on Ubuntu 10.04 tries to start and then
- hondaman900
26 Dec 2010 07:31 #6250
by hondaman900
Installed on Ubuntu 10.04 tries to start and then was created by hondaman900
I installed EMC2 on my existing Ubuntu 10.04 system. I configured to sim-axis, and then starting EMC2 I get the following error. Not sure what to do next. Any suggestions?
Print file information:
RUN_IN_PLACE=no
EMC2_DIR=
EMC2_BIN_DIR=/usr/bin
EMC2_TCL_DIR=/usr/share/emc/tcl
EMC2_SCRIPT_DIR=
EMC2_RTLIB_DIR=/usr/realtime-2.6.32-122-rtai/modules/emc2
EMC2_CONFIG_DIR=
EMC2_LANG_DIR=/usr/share/emc/tcl/msgs
INIVAR=inivar
HALCMD=halcmd
EMC2_EMCSH=/usr/bin/wish8.5
EMC2 - 2.4.6
Machine configuration directory is '/home/stephen/emc2/configs/sim'
Machine configuration file is 'axis.ini'
INIFILE=/home/stephen/emc2/configs/sim/axis.ini
PARAMETER_FILE=sim.var
EMCMOT=motmod
EMCIO=io
TASK=milltask
HALUI=halui
DISPLAY=axis
NML_FILE=
Starting EMC2...
Starting EMC2 server program: emcsvr
Starting EMC2 IO program: io
Starting EMC2 TASK program: milltask
Starting EMC2 DISPLAY program: axis
Shutting down and cleaning up EMC2...
Killing task emcsvr, PID=1595
Killing task milltask, PID=1649
Cleanup done
Debug file information:
/usr/bin/emc: line 654: 1650 Segmentation fault $EMCDISPLAY -ini "$INIFILE" $EMCDISPLAYARGS $EXTRA_ARGS
1595
PID TTY STAT TIME COMMAND
1649
Stopping realtime threads
Unloading hal components
Kernel message information:
[ 638.932135] I-pipe: Domain RTAI registered.
[ 638.932165] RTAI[hal]: <3.8.1> mounted over IPIPE-NOTHREADS 2.6-03.
[ 638.932172] RTAI[hal]: compiled with gcc version 4.4.3 (Ubuntu 4.4.3-4ubuntu5) .
[ 638.932190] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 638.932198] PIPELINE layers:
[ 638.932207] e1314e20 9ac15d93 RTAI 200
[ 638.932215] c085cb20 0 Linux 100
[ 639.029326] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 639.030014] RTAI[sched]: IMMEDIATE, MP, USER/KERNEL SPACE: <with RTAI OWN KTASKs>, kstacks pool size = 524288 bytes.
[ 639.030032] RTAI[sched]: hard timer type/freq = APIC/8306320(Hz); default timing: periodic; linear timed lists.
[ 639.030043] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 863830000 hz.
[ 639.030052] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[ 639.035267] RTAI[usi]: enabled.
[ 639.377914] RTAI[math]: loaded.
[ 644.874892] axis[1650]: segfault at 0 ip (null) sp bface17c error 4 in libnsl-2.11.1.so[110000+13000]
[ 649.084597] RTAI[math]: unloaded.
[ 649.296235] SCHED releases registered named ALIEN RTGLBH
[ 649.312909] RTAI[malloc]: unloaded.
[ 649.412054] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 649.427105] I-pipe: Domain RTAI unregistered.
[ 649.427136] RTAI[hal]: unmounted.
26 Dec 2010 15:29 - 26 Dec 2010 15:30 #6252
by BigJohnT
Replied by BigJohnT on topic Re:Installed on Ubuntu 10.04 tries to start and then
Did you install it using the instructions located
here
Did you boot up with the real time kernel? Installing on a stock 10.04 system will leave you with two or more kernels...
Last edit: 26 Dec 2010 15:30 by BigJohnT.
- hondaman900
26 Dec 2010 17:46 - 26 Dec 2010 17:48 #6253
by hondaman900
Replied by hondaman900 on topic Re:Installed on Ubuntu 10.04 tries to start and then
Thanks for the reply John.
Yes, I followed those instructions for installing on an existing Ubuntu 10.04 system. I ran into the RTAPI real time kernel issue right away and then followed these instructions: hart.sourceforge.net/rtai_installation_10_04_woc.html just down to the line "Reboot in the new installed RTAI-kernel." The linedidn't work (couldn't find xaw3dg-dev), which brings me to where I am now (i.e. lost)
I should add that the issue seems to be with the sim-axis setup. If I choose sim-tkemc it appears to run.
xaw3dg-dev libpvm3 pvm-dev libgtkhtml2-dev libvte-dev ocaml-native-compilers
Last edit: 26 Dec 2010 17:48 by hondaman900.
27 Dec 2010 06:22 #6258
by psha
Replied by psha on topic Re:Installed on Ubuntu 10.04 tries to start and then
Usually this is caused by OpenGL - RTAI incompatibilities on some hardware.
Look into wiki.linuxcnc.org/emcinfo.pl?TroubleShooting#Display_Issues for possible solutions.
- hondaman900
27 Dec 2010 08:05 #6259
by hondaman900
Thank you Psha! I installed the software OpenGL drivers (point 4.2 in the document you linked to) and ti did the trick. Now works like a champ.
Thank you!
Thank you!
- billtrondsen
04 Jul 2011 16:51 #11148
by billtrondsen
Replied by billtrondsen on topic Re:Installed on Ubuntu 10.04 tries to start and then
I have used the Ubuntu 8.04 installed from live CD for about one year with no problems - my first use of Linux.
I upgraded from a CRT to a flat panel LCD - Ubuntu works fine, but Axis messes up the display.
Tried upgrading to 10.04 from Live CD (full install) and got the same "1650 Segmentation Fault" as you - pointing to a similar Video driver issue.
From the EMC Trouble Shooting documentation:
5.1 - install "vesa" driver.
- my system doesnt have Xorg.conf file
- used sudo X -configure in Terminal Emulator, but it gives me an error: X-window Server is being used for session 0 - remove /tmp/.X0.lock file.
- tried closing all windows and using ctrl-alt-F1 for text mode entry of this function - still the same error.
Second option was:
5.2 - install new OpenGL driver
- I downloaded and tried installing libgl1-mesa-swx11 using the package manager (my CNC computer in the garage does not have internet)
- gives an error - conflict with libgl1-mesa-gwx and will not allow the install
Probably either of these if allowed could fix my video issue.
Any basic linux tips would be greatly appreciated!
Thanks - BillT
Second option was:
Thanks - BillT
04 Jul 2011 21:55 #11162
by psha
Let's try 5.2 first.
It's normal that libgl1-mesa-swx11 conflicts with libgl1-mesa-glx - both packages provide same functionality. So by installing libgl1-mesa-swx11 you are
replacing GLX. Another "error" you may see - deletion of ubuntu-desktop package. Don't be afraid, it's empty metapackage.
- billtrondsen
07 Jul 2011 01:36 #11202
by billtrondsen
Thanks for the response.
The synaptic package manager does not allow me to install the swx11 - the install button is grayed-out due to the conflict with gcx.
I started to remove gcx, but it gives me a long list of dependent packages that will be removed, including EMC2 and Win-X.
Does this mean that these would be deleted and would need to be installed after installing swx11?
Should I make a list of the packages and be prepared to reinstall them all?
Or, is there another option, for instance using command-line interface for bypassing the conflict?
Thanks - BillT
Thanks - BillT
10 Jul 2011 16:34 #11357
by Andrey_L
Replied by Andrey_L on topic Re:Installed on Ubuntu 10.04 tries to start and then
Hello gentlemen!
I decided to try EMC2 on Ubuntu 10.04 installed from live CD.I ran EMC with sim. config and received the following message:
EMC2 - 2.4.6
Machine configuration directory is '/home/andrey/emc2/configs/sim'
Machine configuration file is 'axis_mm.ini'
Starting EMC2...
waiting for s.axes
waiting for s.axes
waiting for s.axes
waiting for s.axes
waiting for s.axes
USRMOT: ERROR: command timeout
waiting for s.axes
waiting for s.axes
waiting for s.axes
waiting for s.axes
A configuration error is preventing emc2 from starting.
More information may be available when running from a terminal.
/usr/bin/emc: line 358: 2273 Killed $EMCTASK -ini "$INIFILE"
Cleanup done
I will appreciate any thoughts on this subject
P.S.EMC2-2.4.6 runs perfect with Ubuntu 8.04 on the same computer...
EMC2 - 2.4.6
Starting EMC2...
waiting for s.axes
waiting for s.axes
waiting for s.axes
waiting for s.axes
waiting for s.axes
waiting for s.axes
waiting for s.axes
waiting for s.axes
waiting for s.axes
Cleanup done
10 Jul 2011 17:30 #11359
by Rick G
Replied by Rick G on topic Re:Installed on Ubuntu 10.04 tries to start and then
Have you looked here?
www.linuxcnc.org/component/option,com_ku...tart,0/lang,english/
Have you run the latency test with 10.04?
Rick G
Rick G
Time to create page: 0.098 seconds
