emc2 freezes when I try to run my configuration
- wwwmthboardscom
28 Dec 2010 06:15 #6280
by wwwmthboardscom
emc2 freezes when I try to run my configuration was created by wwwmthboardscom
After setting up my xyz they all run and are perfect in setup, but then I save my setup and then try to go into it and it freezes every time. I cant do anything but turn off the power and restart it. I'm afraid I should of used mach 3 because it was working fine in demo mode but I just didnt want to pay the $$$$.
28 Dec 2010 11:28 #6284
by Rick G
Replied by Rick G on topic Re:emc2 freezes when I try to run my configuration
Could you explain what you are doing when you start EMC and what freezes? When you start are you able to toggle the Emergency stop then toggle the Machine power then home all the Axis?
Rick G
Rick G
Time to create page: 0.064 seconds
