Ubuntu 10 install Fails - Screen Goes Black
02 Feb 2011 06:19 - 02 Feb 2011 06:20 #6954
by jbraun
Replied by jbraun on topic Re:Ubuntu 10 install Fails - Screen Goes Black
andypugh wrote:
The re-enabled charge pump works as you suggested. I'll keep an eye open for any strangeness as these drives can be
sensitive beasts. For example the preset G540 timings in stepconf turned out to be a disaster with my drives.
If I don't report back assume all is good.
Okay, if you insistI would strongly suggest re-enabling it.
Last edit: 02 Feb 2011 06:20 by jbraun.
- Highlander01
05 Feb 2011 23:23 #7014
by Highlander01
Replied by Highlander01 on topic Re:Ubuntu 10 install Fails - Screen Goes Black
D525MW question.... What is it's architecture? I type in: "uname -m" and I get back "i686". Does that mean i386, x86, or x86_64?
06 Feb 2011 12:08 #7023
by disca
Replied by disca on topic Re:Ubuntu 10 install Fails - Screen Goes Black
Highlander01: 64bit - Atom D525 CPU - ark.intel.com/Product.aspx?id=49490
- Highlander01
12 Feb 2011 05:01 #7150
by Highlander01
disca noted: "Im using the latest bios - version .74 if I recall correctly."
My intel atom BIOS version is "MWPNT10N.86A.0069.2010.0913.1432"
Mine might be newer?
12 Feb 2011 09:56 #7155
by disca
Highlander01: think yours is actually older. 0069 - version 69 on yours.
latest version 74 available here - fixed an issue for me regarding shutting down the system.
downloadcenter.intel.com/Detail_Desc.asp...oard+D525MW&lang=eng
Time to create page: 0.096 seconds
