how to start emc2 from Applications menu
02 Jan 2011 13:56 #6363
by pazh
how to start emc2 from Applications menu was created by pazh
I install emc by myself on ubuntu10.04,
But every time it needs to start from terminal, and also needs sudo permission.
How can I bring it to Application menu like when it installed from emc2_install.sh??
thanks in advance.
shafagh
thanks in advance.
shafagh
02 Jan 2011 14:23 #6367
Replied by andypugh on topic Re:how to start emc2 from Applications menu
scripts/emcmkdesktop might do what you need.
02 Jan 2011 14:23 - 02 Jan 2011 14:24 #6368
by BigJohnT
Replied by BigJohnT on topic Re:how to start emc2 from Applications menu
The simplest way is to use the LiveCD to install EMC. Was there some reason to not use the LiveCD?
How did you install EMC?
Last edit: 02 Jan 2011 14:24 by BigJohnT.
02 Jan 2011 21:21 - 02 Jan 2011 21:21 #6380
by pazh
Replied by pazh on topic Re:how to start emc2 from Applications menu
Because I want to change the language and need to work with its codes. So I need to install it this way.
I installed it from source package.
to andy; thanks, I'll try that, but I think it won't work.
I successfully put it in Application menu, but still when running emc2, it start terminal first and need the permission.
How can I run it without terminal like when installed from live cd??
Last edit: 02 Jan 2011 21:21 by pazh.
02 Jan 2011 21:49 #6382
Did you do:
sudo make setuid
after compiling?
sudo make setuid
after compiling?
02 Jan 2011 23:00 #6384
by pazh
Yes,
I think it supposed to be something like what I want, but nothing happened.
02 Jan 2011 23:06 #6386
by BigJohnT
Just to recap did you install EMC on a stock Ubuntu 10.04 install following these instructions
wiki.linuxcnc.org/cgi-bin/emcinfo.pl?Ins...EMC2#On_Stock_Ubuntu
Or did you get the source with git?
02 Jan 2011 23:15 #6387
by pazh
No, I didn't use emc2-install.sh as it described in that wiki.
First I downloaded the 15mb source, I think from git, then installed all the required myself.
02 Jan 2011 23:34 #6388
by BigJohnT
Then you should be able to build following these instructions
wiki.linuxcnc.org/cgi-bin/emcinfo.pl?Ins...ilding_emc2_realtime
and run following these instructions
wiki.linuxcnc.org/cgi-bin/emcinfo.pl?Ins...ng_EMC2#Running_emc2
Also you need to run emc once and pick a config to set up the directories on your computer.
03 Jan 2011 10:39 - 03 Jan 2011 10:40 #6402
by pazh
Yeah, I've done that part before and it worked just fine,
But what I wanted was to run it from a kind of shortcut, which I could not do before.
By the way, now it's solved and run from menu without terminal.
But I don't know what happened exactly:unsure:
I just try what Andy pointed to, and then put emc2 in menu like before.
Thanks all.
Thanks all.
Last edit: 03 Jan 2011 10:40 by pazh.
Time to create page: 0.090 seconds
