emc2-sim crash after splash on 10.04
- deadbear
- Topic Author
- Visitor
05 Jan 2011 20:23 #6453
by deadbear
emc2-sim crash after splash on 10.04 was created by deadbear
I couldn't find a previous thread that would help.
I just want to be able to verify generated Gcode on my laptop, but I get the following error with any configuration I choose.
Here's the error dump for the axis config. The only difference is that for some configs I dont ever get the error report, just silence.
It looks like a memory access problem.... but I wouldn't know what to do with it and I wouldn't want to try super using it until I here from an expert.
Many thanks.
Print file information:
RUN_IN_PLACE=no
EMC2_DIR=
EMC2_BIN_DIR=/usr/bin
EMC2_TCL_DIR=/usr/share/emc/tcl
EMC2_SCRIPT_DIR=
EMC2_RTLIB_DIR=/usr/lib/emc2/modules
EMC2_CONFIG_DIR=
EMC2_LANG_DIR=/usr/share/emc/tcl/msgs
INIVAR=inivar
HALCMD=halcmd
EMC2_EMCSH=/usr/bin/wish8.5
EMC2 - 2.4.6
Machine configuration directory is '/home/deadbear/emc2/configs/sim'
Machine configuration file is 'axis.ini'
INIFILE=/home/deadbear/emc2/configs/sim/axis.ini
PARAMETER_FILE=sim.var
EMCMOT=motmod
EMCIO=io
TASK=milltask
HALUI=halui
DISPLAY=axis
NML_FILE=emc.nml
Starting EMC2...
Starting EMC2 server program: emcsvr
Starting EMC2 IO program: io
Starting EMC2 TASK program: milltask
Starting EMC2 DISPLAY program: axis
libnml/buffer/physmem.cc 143: PHYSMEM_HANDLE: Can't write 10748 bytes at offset 60 from buffer of size 10208.
libnml/cms/cms_in.cc 1383: CMS:(emcStatus) Error writing 10748 bytes to global memory at offset 8C3D538
(See libnml/cms/cms_in.cc line 1386.)
* Current Directory = /home/deadbear/emc2/configs/sim
* BufferName = emcStatus
* BufferType = 0
* ProcessName = emc
* Configuration File = emc.nml
* CMS Status = -3 (CMS_INTERNAL_ACCESS_ERROR: An error occured during an internal access function. )
* Recent errors repeated:
* BufferLine: B emcStatus SHMEM localhost 10240 0 0 2 16 1002 TCP=5005 xdr
* ProcessLine: P emc emcStatus LOCAL localhost W 0 1.0 0 0
* error_type = 5 (NML_INTERNAL_CMS_ERROR)
libnml/cms/cms_in.cc 1082: CMS:(emcStatus) Message size of 10748 exceeds maximum of 10180
* BufferType = 0
* ProcessName = xemc
* ProcessLine: P xemc emcStatus LOCAL localhost R 0 10.0 0 10
Maximum number of errors to print exceeded!
waiting for s.axes
waiting for s.axes
waiting for s.axes
waiting for s.axes
waiting for s.axes
waiting for s.axes
waiting for s.axes
waiting for s.axes
waiting for s.axes
Shutting down and cleaning up EMC2...
Killing task emcsvr, PID=6957
Killing task milltask, PID=6987
Cleanup done
Debug file information:
Unrecognized line skipped: POC FMS LEN DIAM COMMENT
A configuration error is preventing emc2 from starting.
More information may be available when running from a terminal.
6957
PID TTY STAT TIME COMMAND
6987
Stopping realtime threads
Unloading hal components
Many thanks.
RUN_IN_PLACE=no
EMC2_DIR=
EMC2_SCRIPT_DIR=
EMC2_CONFIG_DIR=
INIVAR=inivar
HALCMD=halcmd
EMC2 - 2.4.6
EMCMOT=motmod
EMCIO=io
TASK=milltask
HALUI=halui
DISPLAY=axis
NML_FILE=emc.nml
Starting EMC2...
* BufferType = 0
* ProcessName = emc
* BufferType = 0
waiting for s.axes
waiting for s.axes
waiting for s.axes
waiting for s.axes
waiting for s.axes
waiting for s.axes
waiting for s.axes
waiting for s.axes
waiting for s.axes
Cleanup done
6957
6987
05 Jan 2011 23:19 #6454
by BigJohnT
Replied by BigJohnT on topic Re:emc2-sim crash after splash on 10.04
- deadbear
- Topic Author
- Visitor
05 Jan 2011 23:45 #6457
by deadbear
Replied by deadbear on topic Re:emc2-sim crash after splash on 10.04
Thats it!
Didn't know the configuration files were left when I upgraded from 8.04.
Many Thanks.
Many Thanks.
Time to create page: 0.070 seconds
