EMC2 to a minimum
- maximus051172
29 Jan 2011 11:30 #6860
by maximus051172
EMC2 to a minimum was created by maximus051172
Hello everyone, I wanted to know if and 'on a PC with Ubuntu and EMC2 uninstall everything that is not needed, so as to have a more' like a CNC Fanuc or similar type.
30 Jan 2011 00:19 #6866
Replied by cmorley on topic Re:EMC2 to a minimum
What would be the point of removing everything?
What i mean is - what specifically do you want that is Fanuc and not EMC.
Do you mean you want EMC to start immediately when the computer is turned on?
- maximus051172
30 Jan 2011 17:22 #6877
by maximus051172
Replied by maximus051172 on topic Re:EMC2 to a minimum
I mean a system with only emc without any other installed program or service started so that the PC boots up quickly reduced to a kernel bone
30 Jan 2011 22:08 #6879
Ah now I understand.
I don't believe that uninstalling everything would speed up the boot process.
hopefully someone with better knowledge will chime in.
- Kirk_Wallace
- Thank you received: 7
31 Jan 2011 03:43 #6886
by Kirk_Wallace
Replied by Kirk_Wallace on topic Re:EMC2 to a minimum
I wrote a long reply, but it got lost, when I hit Submit. So this is the short version.
Try an install on Debian or Puppy Linux: wiki.linuxcnc.org/cgi-bin/emcinfo.pl?Installing_EMC2#On_Debian
Try "ps -e" to find running processes and edit the init (rc.d) scripts to keep them from loading.
Try "lsmod" to find loaded modules, and "rmmod" the ones you don't need.
Look into a Flash install: wiki.linuxcnc.org/cgi-bin/emcinfo.pl?Install_To_CompactFlash
Kirk Wallace
www.wallacecompany.com/machine_shop/
www.wallacecompany.com/E45/index.html
California, USA
Kirk Wallace
California, USA
- step4linux
- Thank you received: 5
05 Feb 2011 10:54 #7006
by step4linux
Replied by step4linux on topic Re:EMC2 to a minimum
I made a new installation on a foxconn barebone R10-D2 (Atom D510, 1 GB Mem) with Xubuntu 10.04 and the latest EMC2.
Completing the HW, and installing Xubuntu + EMC took about 4 h (without any hurry).
Boot time is < 40 sec, including BIOS, from hitting the on button to the full GUI.
I think there is not so much significant improvement possible, to justify any special Linux.
Gerd
Gerd
Time to create page: 0.121 seconds
