Installed, but won't run.
10 Feb 2011 23:42 #7123
by 3MTA3
Installed, but won't run. was created by 3MTA3
Hello all,
I just installed Ubuntu 10.04 with EMC2 2.4.3 onto an old laptop that meet all the requirements. i know laptops aren't the best, but i needed to transport it for school and a laptop is easier to move then a desktop.
Anyway, the install was successful, Ubuntu seems to work perfectly, but whenever I try to start EMC2, it crashes and gives me an error report. I have tried with different configurations from the start-up screen, but the same thing happens.
The error suggest I write what it says in my question, so here it is:
Print file information:
RUN_IN_PLACE=no
EMC2_DIR=
EMC2_BIN_DIR=/usr/bin
EMC2_TCL_DIR=/usr/share/emc/tcl
EMC2_SCRIPT_DIR=
EMC2_RTLIB_DIR=/usr/realtime-2.6.32-122-rtai/modules/emc2
EMC2_CONFIG_DIR=
EMC2_LANG_DIR=/usr/share/emc/tcl/msgs
INIVAR=inivar
HALCMD=halcmd
EMC2_EMCSH=/usr/bin/wish8.5
EMC2 - 2.4.3
Machine configuration directory is '/home/andrew/emc2/configs/Sherline3Axis'
Machine configuration file is 'Sherline3Axis_inch.ini'
INIFILE=/home/andrew/emc2/configs/Sherline3Axis/Sherline3Axis_inch.ini
PARAMETER_FILE=stepper.var
EMCMOT=motmod
EMCIO=io
TASK=milltask
HALUI=
DISPLAY=axis
NML_FILE=
Starting EMC2...
Starting EMC2 server program: emcsvr
Realtime system did not load
Shutting down and cleaning up EMC2...
Killing task emcsvr, PID=1428
Cleanup done
Debug file information:
insmod: error inserting '/usr/realtime-2.6.32-122-rtai/modules/rtai_hal.ko': -1 Operation not permitted
1428
PID TTY STAT TIME COMMAND
Stopping realtime threads
RTAPI: ERROR: could not open shared memory (errno=2)
HAL: ERROR: rtapi init failed
halcmd: hal_init() failed: -22
NOTE: 'rtapi' kernel module must be loaded
Unloading hal components
ERROR: Module hal_lib does not exist in /proc/modules
ERROR: Module rtapi does not exist in /proc/modules
ERROR: Module rtai_math does not exist in /proc/modules
ERROR: Module rtai_sem does not exist in /proc/modules
ERROR: Module rtai_fifos does not exist in /proc/modules
ERROR: Module rtai_sched does not exist in /proc/modules
ERROR: Module rtai_hal does not exist in /proc/modules
Kernel message information:
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Linux version 2.6.32-122-rtai (root@moses-6core) (gcc version 4.4.3 (Ubuntu 4.4.3-4ubuntu5) ) #rtai SMP Tue Jul 27 12:44:07 CDT 2010 (Ubuntu 2.6.32-122.35.rtai-rtai 2.6.32.11+drm33.2)
[ 0.000000] KERNEL supported cpus:
[ 0.000000] Intel GenuineIntel
[ 0.000000] AMD AuthenticAMD
[ 0.000000] NSC Geode by NSC
[ 0.000000] Cyrix CyrixInstead
[ 0.000000] Centaur CentaurHauls
[ 0.000000] Transmeta GenuineTMx86
[ 0.000000] Transmeta TransmetaCPU
[ 0.000000] UMC UMC UMC UMC
[ 0.000000] BIOS-provided physical RAM map:
[ 0.000000] BIOS-e820: 0000000000000000 - 000000000009fc00 (usable)
[ 0.000000] BIOS-e820: 000000000009fc00 - 00000000000a0000 (reserved)
[ 0.000000] BIOS-e820: 00000000000f0000 - 0000000000100000 (reserved)
[ 0.000000] BIOS-e820: 0000000000100000 - 000000001f7d0000 (usable)
[ 0.000000] BIOS-e820: 000000001f7d0000 - 000000001f7e0000 (reserved)
[ 0.000000] BIOS-e820: 000000001f7e0000 - 000000001f7e8000 (ACPI data)
[ 0.000000] BIOS-e820: 000000001f7e8000 - 000000001f800000 (ACPI NVS)
[ 0.000000] BIOS-e820: 000000001f800000 - 0000000020000000 (reserved)
[ 0.000000] BIOS-e820: 00000000ffff0000 - 0000000100000000 (reserved)
[ 0.000000] DMI 2.3 present.
[ 0.000000] last_pfn = 0x1f7d0 max_arch_pfn = 0x100000
[ 0.000000] MTRR default type: uncachable
[ 0.000000] MTRR fixed ranges enabled:
[ 0.000000] 00000-9FFFF write-back
[ 0.000000] A0000-BFFFF uncachable
[ 0.000000] C0000-CBFFF write-protect
[ 0.000000] CC000-EFFFF uncachable
[ 0.000000] F0000-FFFFF write-protect
[ 0.000000] MTRR variable ranges enabled:
[ 0.000000] 0 base 000000000 mask FE0000000 write-back
[ 0.000000] 1 disabled
[ 0.000000] 2 disabled
[ 0.000000] 3 disabled
[ 0.000000] 4 disabled
[ 0.000000] 5 disabled
[ 0.000000] 6 disabled
[ 0.000000] 7 disabled
[ 0.000000] PAT not supported by CPU.
[ 0.000000] e820 update range: 0000000000002000 - 0000000000006000 (usable) ==> (reserved)
[ 0.000000] Scanning 1 areas for low memory corruption
[ 0.000000] modified physical RAM map:
[ 0.000000] modified: 0000000000000000 - 0000000000002000 (usable)
[ 0.000000] modified: 0000000000002000 - 0000000000006000 (reserved)
[ 0.000000] modified: 0000000000006000 - 000000000009fc00 (usable)
[ 0.000000] modified: 000000000009fc00 - 00000000000a0000 (reserved)
[ 0.000000] modified: 00000000000f0000 - 0000000000100000 (reserved)
[ 0.000000] modified: 0000000000100000 - 000000001f7d0000 (usable)
[ 0.000000] modified: 000000001f7d0000 - 000000001f7e0000 (reserved)
[ 0.000000] modified: 000000001f7e0000 - 000000001f7e8000 (ACPI data)
[ 0.000000] modified: 000000001f7e8000 - 000000001f800000 (ACPI NVS)
[ 0.000000] modified: 000000001f800000 - 0000000020000000 (reserved)
[ 0.000000] modified: 00000000ffff0000 - 0000000100000000 (reserved)
[ 0.000000] initial memory mapped : 0 - 00c00000
[ 0.000000] init_memory_mapping: 0000000000000000-000000001f7d0000
[ 0.000000] Using x86 segment limits to approximate NX protection
[ 0.000000] 0000000000 - 0000400000 page 4k
[ 0.000000] 0000400000 - 001f400000 page 2M
[ 0.000000] 001f400000 - 001f7d0000 page 4k
[ 0.000000] kernel direct mapping tables up to 1f7d0000 @ 7000-c000
[ 0.000000] RAMDISK: 16d9d000 - 17a1bdeb
[ 0.000000] ACPI: RSDP 000fe030 00014 (v00 IBM )
[ 0.000000] ACPI: RSDT 1f7e0000 0002C (v01 IBM Cnote2 00003080 IBM 00000001)
[ 0.000000] ACPI: FACP 1f7e0054 00074 (v01 IBM Cnote2 00003080 IBM 00000001)
[ 0.000000] ACPI: DSDT 1f7e00cc 05C71 (v01 IBM CNOTE2 00003080 MSFT 0100000C)
[ 0.000000] ACPI: FACS 1f7e8000 00040
[ 0.000000] ACPI: BOOT 1f7e002c 00028 (v01 IBM Cnote2 00003080 IBM 00000001)
[ 0.000000] 0MB HIGHMEM available.
[ 0.000000] 503MB LOWMEM available.
[ 0.000000] mapped low ram: 0 - 1f7d0000
[ 0.000000] low ram: 0 - 1f7d0000
[ 0.000000] node 0 low ram: 00000000 - 1f7d0000
[ 0.000000] node 0 bootmap 00008000 - 0000befc
[ 0.000000] (9 early reservations) ==> bootmem [0000000000 - 001f7d0000]
[ 0.000000] #0 [0000000000 - 0000001000] BIOS data page ==> [0000000000 - 0000001000]
[ 0.000000] #1 [0000001000 - 0000002000] EX TRAMPOLINE ==> [0000001000 - 0000002000]
[ 0.000000] #2 [0000006000 - 0000007000] TRAMPOLINE ==> [0000006000 - 0000007000]
[ 0.000000] #3 [0000100000 - 00008b0db8] TEXT DATA BSS ==> [0000100000 - 00008b0db8]
[ 0.000000] #4 [0016d9d000 - 0017a1bdeb] RAMDISK ==> [0016d9d000 - 0017a1bdeb]
[ 0.000000] #5 [000009fc00 - 0000100000] BIOS reserved ==> [000009fc00 - 0000100000]
[ 0.000000] #6 [00008b1000 - 00008b412e] BRK ==> [00008b1000 - 00008b412e]
[ 0.000000] #7 [0000007000 - 0000008000] PGTABLE ==> [0000007000 - 0000008000]
[ 0.000000] #8 [0000008000 - 000000c000] BOOTMAP ==> [0000008000 - 000000c000]
[ 0.000000] Zone PFN ranges:
[ 0.000000] DMA 0x00000000 -> 0x00001000
[ 0.000000] Normal 0x00001000 -> 0x0001f7d0
[ 0.000000] HighMem 0x0001f7d0 -> 0x0001f7d0
[ 0.000000] Movable zone start PFN for each node
[ 0.000000] early_node_map[3] active PFN ranges
[ 0.000000] 0: 0x00000000 -> 0x00000002
[ 0.000000] 0: 0x00000006 -> 0x0000009f
[ 0.000000] 0: 0x00000100 -> 0x0001f7d0
[ 0.000000] On node 0 totalpages: 128875
[ 0.000000] free_area_init_node: node 0, pgdat c07470e0, node_mem_map c1001000
[ 0.000000] DMA zone: 32 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 3963 pages, LIFO batch:0
[ 0.000000] Normal zone: 976 pages used for memmap
[ 0.000000] Normal zone: 123904 pages, LIFO batch:31
[ 0.000000] Using APIC driver default
[ 0.000000] ACPI: PM-Timer IO Port: 0xf108
[ 0.000000] SMP: Allowing 1 CPUs, 0 hotplug CPUs
[ 0.000000] Local APIC disabled by BIOS -- you can enable it with "lapic"
[ 0.000000] APIC: disable apic facility
[ 0.000000] nr_irqs_gsi: 16
[ 0.000000] Allocating PCI resources starting at 20000000 (gap: 20000000:dfff0000)
[ 0.000000] NR_CPUS:8 nr_cpumask_bits:8 nr_cpu_ids:1 nr_node_ids:1
[ 0.000000] PERCPU: Embedded 24 pages/cpu @c1400000 s74936 r0 d23368 u4194304
[ 0.000000] pcpu-alloc: s74936 r0 d23368 u4194304 alloc=1*4194304
[ 0.000000] pcpu-alloc: [0] 0
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 127867
[ 0.000000] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-2.6.32-122-rtai root=UUID=14c8b713-6821-4ebc-95b5-b6351e6ce257 ro quiet splash
[ 0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.000000] Enabling fast FPU save and restore... done.
[ 0.000000] Enabling unmasked SIMD FPU exception support... done.
[ 0.000000] Initializing CPU#0
[ 0.000000] allocated 2579520 bytes of page_cgroup
[ 0.000000] please try 'cgroup_disable=memory' option if you don't want memory cgroups
[ 0.000000] Initializing HighMem for node 0 (00000000:00000000)
[ 0.000000] Memory: 487432k/515904k available (4539k kernel code, 27764k reserved, 1928k data, 620k init, 0k highmem)
[ 0.000000] virtual kernel memory layout:
[ 0.000000] fixmap : 0xfff1e000 - 0xfffff000 ( 900 kB)
[ 0.000000] pkmap : 0xff800000 - 0xffc00000 (4096 kB)
[ 0.000000] vmalloc : 0xdffd0000 - 0xff7fe000 ( 504 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xdf7d0000 ( 503 MB)
[ 0.000000] .init : 0xc0751000 - 0xc07ec000 ( 620 kB)
[ 0.000000] .data : 0xc056ecbc - 0xc0750e68 (1928 kB)
[ 0.000000] .text : 0xc0100000 - 0xc056ecbc (4539 kB)
[ 0.000000] Checking if this processor honours the WP bit even in supervisor mode...Ok.
[ 0.000000] SLUB: Genslabs=13, HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[ 0.000000] Hierarchical RCU implementation.
[ 0.000000] NR_IRQS:2304 nr_irqs:256
[ 0.000000] I-pipe 2.6-03: pipeline enabled.
[ 0.000000] Console: colour VGA+ 80x25
[ 0.000000] console [tty0] enabled
[ 0.000000] Fast TSC calibration using PIT
[ 0.000000] Detected 730.978 MHz processor.
[ 0.004010] Calibrating delay loop (skipped), value calculated using timer frequency.. 1461.95 BogoMIPS (lpj=2923912)
[ 0.004064] Security Framework initialized
[ 0.004138] AppArmor: AppArmor initialized
[ 0.004166] Mount-cache hash table entries: 512
[ 0.004528] Initializing cgroup subsys ns
[ 0.004542] Initializing cgroup subsys cpuacct
[ 0.004557] Initializing cgroup subsys memory
[ 0.004587] Initializing cgroup subsys devices
[ 0.004597] Initializing cgroup subsys freezer
[ 0.004606] Initializing cgroup subsys net_cls
[ 0.004669] CPU: L1 I cache: 16K, L1 D cache: 16K
[ 0.004681] CPU: L2 cache: 512K
[ 0.004694] mce: CPU supports 5 MCE banks
[ 0.004732] Performance Events:
[ 0.004740] no APIC, boot with the "lapic" boot parameter to force-enable it.
[ 0.004749] no hardware sampling interrupt available.
[ 0.004758] p6 PMU driver.
[ 0.004802] ... version: 0
[ 0.004810] ... bit width: 32
[ 0.004818] ... generic registers: 2
[ 0.004826] ... value mask: 00000000ffffffff
[ 0.004835] ... max period: 000000007fffffff
[ 0.004843] ... fixed-purpose events: 0
[ 0.004851] ... event mask: 0000000000000003
[ 0.004864] Checking 'hlt' instruction... OK.
[ 0.021781] SMP alternatives: switching to UP code
[ 0.035220] Freeing SMP alternatives: 31k freed
[ 0.035256] ACPI: Core revision 20090903
[ 0.051807] ACPI: setting ELCR to 0200 (from 0800)
[ 0.052022] ftrace: converting mcount calls to 0f 1f 44 00 00
[ 0.052039] ftrace: allocating 21003 entries in 42 pages
[ 0.071804] Enabling APIC mode: Flat. Using 0 I/O APICs
[ 0.071820] weird, boot CPU (#0) not listed by the BIOS.
[ 0.071828] SMP motherboard not detected.
[ 0.071836] Local APIC not detected. Using dummy APIC emulation.
[ 0.071843] SMP disabled
[ 0.072366] Brought up 1 CPUs
[ 0.072382] Total of 1 processors activated (1461.95 BogoMIPS).
[ 0.073960] CPU0 attaching NULL sched-domain.
[ 0.074411] devtmpfs: initialized
[ 0.075602] regulator: core version 0.5
[ 0.075765] NET: Registered protocol family 16
[ 0.076216] EISA bus registered
[ 0.076241] ACPI: bus type pci registered
[ 0.077852] PCI: PCI BIOS revision 2.10 entry at 0xf0200, last bus=1
[ 0.077861] PCI: Using configuration type 1 for base access
[ 0.080694] bio: create slab <bio-0> at 0
[ 0.082547] ACPI: EC: Look up EC in DSDT
[ 0.103573] ACPI: Interpreter enabled
[ 0.103587] ACPI: (supports S0 S5)
[ 0.103625] ACPI: Using PIC for interrupt routing
[ 0.144395] ACPI: EC: GPE = 0x1d, I/O: command/status = 0x66, data = 0x62
[ 0.144820] ACPI: No dock devices found.
[ 0.145187] ACPI: PCI Root Bridge [PCI0] (0000:00)
[ 0.145368] pci 0000:00:02.0: reg 10 32bit mmio pref: [0x98000000-0x9fffffff]
[ 0.145384] pci 0000:00:02.0: reg 14 32bit mmio: [0x90100000-0x9017ffff]
[ 0.145424] pci 0000:00:02.0: supports D1
[ 0.145463] pci 0000:00:02.1: reg 10 32bit mmio pref: [0x88000000-0x8fffffff]
[ 0.145478] pci 0000:00:02.1: reg 14 32bit mmio: [0x80200000-0x8027ffff]
[ 0.145517] pci 0000:00:02.1: supports D1
[ 0.145622] pci 0000:00:1d.0: reg 20 io port: [0xa4a0-0xa4bf]
[ 0.145698] pci 0000:00:1d.1: reg 20 io port: [0xa4e0-0xa4ff]
[ 0.145779] pci 0000:00:1d.2: reg 20 io port: [0xa800-0xa81f]
[ 0.145920] pci 0000:00:1f.0: quirk: region f100-f17f claimed by ICH4 ACPI/GPIO/TCO
[ 0.145934] pci 0000:00:1f.0: quirk: region f200-f23f claimed by ICH4 GPIO
[ 0.145977] pci 0000:00:1f.1: reg 10 io port: [0xa830-0xa837]
[ 0.145994] pci 0000:00:1f.1: reg 14 io port: [0xa848-0xa84b]
[ 0.146010] pci 0000:00:1f.1: reg 18 io port: [0xa860-0xa867]
[ 0.146026] pci 0000:00:1f.1: reg 1c io port: [0xa878-0xa87b]
[ 0.146042] pci 0000:00:1f.1: reg 20 io port: [0xa890-0xa89f]
[ 0.146058] pci 0000:00:1f.1: reg 24 32bit mmio: [0x000000-0x0003ff]
[ 0.146133] pci 0000:00:1f.3: reg 20 io port: [0x8000-0x801f]
[ 0.146190] pci 0000:00:1f.5: reg 10 io port: [0x9800-0x98ff]
[ 0.146206] pci 0000:00:1f.5: reg 14 io port: [0x9c00-0x9c3f]
[ 0.146277] pci 0000:00:1f.6: reg 10 io port: [0xa000-0xa0ff]
[ 0.146293] pci 0000:00:1f.6: reg 14 io port: [0xa400-0xa47f]
[ 0.146397] pci 0000:01:08.0: reg 10 32bit mmio: [0x80100000-0x80100fff]
[ 0.146414] pci 0000:01:08.0: reg 14 io port: [0x7000-0x703f]
[ 0.146465] pci 0000:01:08.0: supports D1 D2
[ 0.146474] pci 0000:01:08.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.146486] pci 0000:01:08.0: PME# disabled
[ 0.146540] pci 0000:01:09.0: reg 10 32bit mmio: [0x000000-0x000fff]
[ 0.146570] pci 0000:01:09.0: supports D1 D2
[ 0.146579] pci 0000:01:09.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.146590] pci 0000:01:09.0: PME# disabled
[ 0.146637] pci 0000:00:1e.0: transparent bridge
[ 0.146649] pci 0000:00:1e.0: bridge io port: [0x7000-0x7fff]
[ 0.146662] pci 0000:00:1e.0: bridge 32bit mmio: [0x80100000-0x801fffff]
[ 0.146708] pci_bus 0000:00: on NUMA node 0
[ 0.146722] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT]
[ 0.146860] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.PCI1._PRT]
[ 0.158036] ACPI: PCI Interrupt Link [PILA] (IRQs 3 4 5 6 7 9 *11 12 14 15)
[ 0.158533] ACPI: PCI Interrupt Link [PILB] (IRQs 3 4 5 6 7 9 *11 12 14 15)
[ 0.159026] ACPI: PCI Interrupt Link [PILC] (IRQs 3 4 5 6 7 9 *11 12 14 15)
[ 0.159524] ACPI: PCI Interrupt Link [PILD] (IRQs 3 4 5 6 7 9 *11 12 14 15)
[ 0.160038] ACPI: PCI Interrupt Link [PILE] (IRQs 3 4 5 6 7 9 *11 12 14 15)
[ 0.160536] ACPI: PCI Interrupt Link [PILF] (IRQs 3 4 5 6 7 9 *11 12 14 15)
[ 0.160965] ACPI: PCI Interrupt Link [PILG] (IRQs 3 4 5 6 7 9 11 12 14 15) *0, disabled.
[ 0.161390] ACPI: PCI Interrupt Link [PILH] (IRQs 3 4 5 6 7 9 11 12 14 15) *0, disabled.
[ 0.161752] vgaarb: device added: PCI:0000:00:02.0,decodes=io+mem,owns=io+mem,locks=none
[ 0.161778] vgaarb: loaded
[ 0.162187] SCSI subsystem initialized
[ 0.162415] libata version 3.00 loaded.
[ 0.162680] usbcore: registered new interface driver usbfs
[ 0.162726] usbcore: registered new interface driver hub
[ 0.162823] usbcore: registered new device driver usb
[ 0.163251] ACPI: WMI: Mapper loaded
[ 0.163259] PCI: Using ACPI for IRQ routing
[ 0.163633] NetLabel: Initializing
[ 0.163641] NetLabel: domain hash size = 128
[ 0.163647] NetLabel: protocols = UNLABELED CIPSOv4
[ 0.163690] NetLabel: unlabeled traffic allowed by default
[ 0.163788] Switching to clocksource tsc
[ 0.166363] AppArmor: AppArmor Filesystem Enabled
[ 0.166422] pnp: PnP ACPI init
[ 0.166478] ACPI: bus type pnp registered
[ 0.189120] pnp 00:0a: io resource (0xf100-0xf16f) overlaps 0000:00:1f.0 BAR 13 (0xf100-0xf17f), disabling
[ 0.189137] pnp 00:0a: io resource (0xf178-0xf17f) overlaps 0000:00:1f.0 BAR 13 (0xf100-0xf17f), disabling
[ 0.189184] pnp 00:0a: mem resource (0x0-0x9ff) overlaps 0000:01:09.0 BAR 0 (0x0-0xfff), disabling
[ 0.189198] pnp 00:0a: mem resource (0xf00-0xfff) overlaps 0000:01:09.0 BAR 0 (0x0-0xfff), disabling
[ 0.196299] pnp: PnP ACPI: found 11 devices
[ 0.196308] ACPI: ACPI bus type pnp unregistered
[ 0.196319] PnPBIOS: Disabled by ACPI PNP
[ 0.196364] system 00:0a: ioport range 0xf200-0xf23f has been reserved
[ 0.196376] system 00:0a: ioport range 0x380-0x38f has been reserved
[ 0.196388] system 00:0a: ioport range 0x4d0-0x4d1 has been reserved
[ 0.196400] system 00:0a: ioport range 0x580-0x587 has been reserved
[ 0.196415] system 00:0a: iomem range 0xfff80000-0xffffffff could not be reserved
[ 0.196428] system 00:0a: iomem range 0xffb00000-0xffbfffff has been reserved
[ 0.196441] system 00:0a: iomem range 0xfff00000-0xfff7ffff has been reserved
[ 0.196454] system 00:0a: iomem range 0x100000-0xffffff could not be reserved
[ 0.196467] system 00:0a: iomem range 0x1000000-0x1f7fffff could not be reserved
[ 0.196480] system 00:0a: iomem range 0xfebffc00-0xfebfffff has been reserved
[ 0.231708] pci 0000:01:09.0: CardBus bridge, secondary bus 0000:02
[ 0.231720] pci 0000:01:09.0: IO window: 0x007400-0x0074ff
[ 0.231733] pci 0000:01:09.0: IO window: 0x007800-0x0078ff
[ 0.231746] pci 0000:01:09.0: PREFETCH window: 0x20000000-0x23ffffff
[ 0.231758] pci 0000:01:09.0: MEM window: 0x28000000-0x2bffffff
[ 0.231771] pci 0000:00:1e.0: PCI bridge, secondary bus 0000:01
[ 0.231782] pci 0000:00:1e.0: IO window: 0x7000-0x7fff
[ 0.231796] pci 0000:00:1e.0: MEM window: 0x80100000-0x801fffff
[ 0.231810] pci 0000:00:1e.0: PREFETCH window: 0x20000000-0x23ffffff
[ 0.231840] pci 0000:00:1e.0: setting latency timer to 64
[ 0.232498] ACPI: PCI Interrupt Link [PILB] enabled at IRQ 11
[ 0.232508] PCI: setting IRQ 11 as level-triggered
[ 0.232522] pci 0000:01:09.0: PCI INT A -> Link[PILB] -> GSI 11 (level, low) -> IRQ 11
[ 0.232542] pci_bus 0000:00: resource 0 io: [0x00-0xffff]
[ 0.232553] pci_bus 0000:00: resource 1 mem: [0x000000-0xffffffff]
[ 0.232564] pci_bus 0000:01: resource 0 io: [0x7000-0x7fff]
[ 0.232575] pci_bus 0000:01: resource 1 mem: [0x80100000-0x801fffff]
[ 0.232586] pci_bus 0000:01: resource 2 pref mem [0x20000000-0x23ffffff]
[ 0.232597] pci_bus 0000:01: resource 3 io: [0x00-0xffff]
[ 0.232607] pci_bus 0000:01: resource 4 mem: [0x000000-0xffffffff]
[ 0.232618] pci_bus 0000:02: resource 0 io: [0x7400-0x74ff]
[ 0.232628] pci_bus 0000:02: resource 1 io: [0x7800-0x78ff]
[ 0.232639] pci_bus 0000:02: resource 2 pref mem [0x20000000-0x23ffffff]
[ 0.232650] pci_bus 0000:02: resource 3 mem: [0x28000000-0x2bffffff]
[ 0.232775] NET: Registered protocol family 2
[ 0.233107] IP route cache hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.234139] TCP established hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.234472] TCP bind hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.234807] TCP: Hash tables configured (established 16384 bind 16384)
[ 0.234818] TCP reno registered
[ 0.235112] NET: Registered protocol family 1
[ 0.235183] pci 0000:00:02.0: Boot video device
[ 0.235299] pci 0000:01:08.0: Firmware left e100 interrupts enabled; disabling
[ 0.235565] Simple Boot Flag at 0x41 set to 0x1
[ 0.235880] Scanning for low memory corruption every 60 seconds
[ 0.236311] audit: initializing netlink socket (disabled)
[ 0.236352] type=2000 audit(1297362692.236:1): initialized
[ 0.260243] Trying to unpack rootfs image as initramfs...
[ 0.284932] HugeTLB registered 4 MB page size, pre-allocated 0 pages
[ 0.300387] VFS: Disk quotas dquot_6.5.2
[ 0.300663] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.303102] fuse init (API version 7.13)
[ 0.303443] msgmni has been set to 952
[ 0.308410] alg: No test for stdrng (krng)
[ 0.308590] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
[ 0.308601] io scheduler noop registered
[ 0.308609] io scheduler anticipatory registered
[ 0.308617] io scheduler deadline registered
[ 0.308809] io scheduler cfq registered (default)
[ 0.309155] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
[ 0.309240] pciehp: PCI Express Hot Plug Controller Driver version: 0.4
[ 0.309498] input: Sleep Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input0
[ 0.309525] ACPI: Sleep Button [SLPB]
[ 0.309734] input: Lid Switch as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0D:00/input/input1
[ 0.309967] ACPI: Lid Switch [LID]
[ 0.310120] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input2
[ 0.310132] ACPI: Power Button [PWRF]
[ 0.312232] isapnp: Scanning for PnP cards...
[ 0.326318] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 0.372279] serial 00:07: activated
[ 0.372503] 00:07: ttyS0 at I/O 0x3f8 (irq = 3) is a 16550A
[ 0.372837] serial 0000:00:1f.6: PCI INT B -> Link[PILB] -> GSI 11 (level, low) -> IRQ 11
[ 0.372857] serial 0000:00:1f.6: PCI INT B disabled
[ 0.380735] brd: module loaded
[ 0.382506] loop: module loaded
[ 0.382875] input: Macintosh mouse button emulation as /devices/virtual/input/input3
[ 0.383248] ata_piix 0000:00:1f.1: version 2.13
[ 0.383285] ata_piix 0000:00:1f.1: can't derive routing for PCI INT A
[ 0.383395] ata_piix 0000:00:1f.1: setting latency timer to 64
[ 0.388599] scsi0 : ata_piix
[ 0.389018] scsi1 : ata_piix
[ 0.396705] ata1: PATA max UDMA/100 cmd 0x1f0 ctl 0x3f6 bmdma 0xa890 irq 14
[ 0.396720] ata2: PATA max UDMA/100 cmd 0x170 ctl 0x376 bmdma 0xa898 irq 15
[ 0.398121] Fixed MDIO Bus: probed
[ 0.398254] PPP generic driver version 2.4.2
[ 0.398442] tun: Universal TUN/TAP device driver, 1.6
[ 0.398451] tun: (C) 1999-2004 Max Krasnyansky <This email address is being protected from spambots. You need JavaScript enabled to view it.>
[ 0.398783] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 0.398857] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 0.398904] uhci_hcd: USB Universal Host Controller Interface driver
[ 0.399691] ACPI: PCI Interrupt Link [PILA] enabled at IRQ 11
[ 0.399707] uhci_hcd 0000:00:1d.0: PCI INT A -> Link[PILA] -> GSI 11 (level, low) -> IRQ 11
[ 0.399734] uhci_hcd 0000:00:1d.0: setting latency timer to 64
[ 0.399745] uhci_hcd 0000:00:1d.0: UHCI Host Controller
[ 0.399866] uhci_hcd 0000:00:1d.0: new USB bus registered, assigned bus number 1
[ 0.399921] uhci_hcd 0000:00:1d.0: irq 11, io base 0x0000a4a0
[ 0.405224] usb usb1: configuration #1 chosen from 1 choice
[ 0.405343] hub 1-0:1.0: USB hub found
[ 0.405378] hub 1-0:1.0: 2 ports detected
[ 0.406268] ACPI: PCI Interrupt Link [PILD] enabled at IRQ 11
[ 0.406283] uhci_hcd 0000:00:1d.1: PCI INT B -> Link[PILD] -> GSI 11 (level, low) -> IRQ 11
[ 0.406308] uhci_hcd 0000:00:1d.1: setting latency timer to 64
[ 0.406319] uhci_hcd 0000:00:1d.1: UHCI Host Controller
[ 0.406476] uhci_hcd 0000:00:1d.1: new USB bus registered, assigned bus number 2
[ 0.406527] uhci_hcd 0000:00:1d.1: irq 11, io base 0x0000a4e0
[ 0.406844] usb usb2: configuration #1 chosen from 1 choice
[ 0.406945] hub 2-0:1.0: USB hub found
[ 0.406970] hub 2-0:1.0: 2 ports detected
[ 0.407665] ACPI: PCI Interrupt Link [PILC] enabled at IRQ 11
[ 0.407679] uhci_hcd 0000:00:1d.2: PCI INT C -> Link[PILC] -> GSI 11 (level, low) -> IRQ 11
[ 0.407698] uhci_hcd 0000:00:1d.2: setting latency timer to 64
[ 0.407708] uhci_hcd 0000:00:1d.2: UHCI Host Controller
[ 0.407843] uhci_hcd 0000:00:1d.2: new USB bus registered, assigned bus number 3
[ 0.407884] uhci_hcd 0000:00:1d.2: irq 11, io base 0x0000a800
[ 0.408240] usb usb3: configuration #1 chosen from 1 choice
[ 0.408343] hub 3-0:1.0: USB hub found
[ 0.408368] hub 3-0:1.0: 2 ports detected
[ 0.408653] PNP: PS/2 Controller [PNP0303:KBC0,PNP0f13:PS2M] at 0x60,0x64 irq 1,12
[ 0.410374] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 0.410407] serio: i8042 AUX port at 0x60,0x64 irq 12
[ 0.416659] mice: PS/2 mouse device common for all mice
[ 0.417121] rtc_cmos 00:04: RTC can wake from S4
[ 0.417272] rtc_cmos 00:04: rtc core: registered rtc_cmos as rtc0
[ 0.417312] rtc0: alarms up to one month, y3k, 242 bytes nvram
[ 0.417687] device-mapper: uevent: version 1.0.3
[ 0.418089] device-mapper: ioctl: 4.15.0-ioctl (2009-04-01) initialised: This email address is being protected from spambots. You need JavaScript enabled to view it.
[ 0.418289] device-mapper: multipath: version 1.1.0 loaded
[ 0.418299] device-mapper: multipath round-robin: version 1.0.0 loaded
[ 0.421116] EISA: Probing bus 0 at eisa.0
[ 0.421165] Cannot allocate resource for EISA slot 7
[ 0.421174] Cannot allocate resource for EISA slot 8
[ 0.421182] EISA: Detected 0 cards.
[ 0.421192] cpuidle: using governor ladder
[ 0.421200] cpuidle: using governor menu
[ 0.422832] TCP cubic registered
[ 0.423477] NET: Registered protocol family 10
[ 0.425133] lo: Disabled Privacy Extensions
[ 0.428681] NET: Registered protocol family 17
[ 0.428806] Using IPI No-Shortcut mode
[ 0.429147] registered taskstats version 1
[ 0.429619] rtc_cmos 00:04: setting system clock to 2011-02-10 18:31:33 UTC (1297362693)
[ 0.429631] BIOS EDD facility v0.16 2004-Jun-25, 0 devices found
[ 0.429638] EDD information not available.
[ 0.488433] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input4
[ 0.597717] ata2.00: ATAPI: MATSHITADVD-ROM SR-8177, NB21, max UDMA/33
[ 0.597948] ata1.00: ATA-6: HTS541060G9AT00, MB3IA60A, max UDMA/100
[ 0.597960] ata1.00: 117210240 sectors, multi 16: LBA
[ 0.604726] ata2.00: configured for UDMA/33
[ 0.613787] ata1.00: configured for UDMA/100
[ 1.027844] isapnp: No Plug & Play device found
[ 1.028379] scsi 0:0:0:0: Direct-Access ATA HTS541060G9AT00 MB3I PQ: 0 ANSI: 5
[ 1.028918] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ 1.029396] sd 0:0:0:0: [sda] 117210240 512-byte logical blocks: (60.0 GB/55.8 GiB)
[ 1.029591] sd 0:0:0:0: [sda] Write Protect is off
[ 1.029603] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 1.029705] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 1.030437] sda:
[ 1.031493] scsi 1:0:0:0: CD-ROM MATSHITA DVD-ROM SR-8177 NB21 PQ: 0 ANSI: 5
[ 1.038471] sr0: scsi3-mmc drive: 24x/24x cd/rw xa/form2 cdda tray
[ 1.038486] Uniform CD-ROM driver Revision: 3.20
[ 1.038858] sr 1:0:0:0: Attached scsi CD-ROM sr0
[ 1.039084] sr 1:0:0:0: Attached scsi generic sg1 type 5
[ 1.047446] sda1 sda2 < sda5 >
[ 1.074113] sd 0:0:0:0: [sda] Attached SCSI disk
[ 1.687720] Freeing initrd memory: 12795k freed
[ 1.725566] Freeing unused kernel memory: 620k freed
[ 1.727544] Write protecting the kernel text: 4540k
[ 1.727645] Write protecting the kernel read-only data: 1668k
[ 1.788713] udev: starting version 151
[ 2.431169] Linux agpgart interface v0.103
[ 2.441059] [Firmware Bug]: ACPI(VGA0) defines _DOD but not _DOS
[ 2.465977] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A03:00/LNXVIDEO:00/input/input5
[ 2.466249] ACPI: Video Device [VGA0] (multi-head: yes rom: no post: no)
[ 2.481172] agpgart-intel 0000:00:00.0: Intel 830M Chipset
[ 2.481817] agpgart-intel 0000:00:00.0: detected 8060K stolen memory
[ 2.484533] agpgart-intel 0000:00:00.0: AGP aperture is 128M @ 0x98000000
[ 2.488385] e100: Intel(R) PRO/100 Network Driver, 3.5.24-k2-NAPI
[ 2.488453] e100: Copyright(c) 1999-2006 Intel Corporation
[ 2.489807] ACPI: PCI Interrupt Link [PILE] enabled at IRQ 11
[ 2.489823] e100 0000:01:08.0: PCI INT A -> Link[PILE] -> GSI 11 (level, low) -> IRQ 11
[ 2.512890] e100 0000:01:08.0: PME# disabled
[ 2.539987] e100: eth0: e100_probe: addr 0x80100000, irq 11, MAC addr 00:00:e2:72:dd:bc
[ 2.649695] [drm] Initialized drm 1.1.0 20060810
[ 2.762301] [drm] i915 disabling kernel modesetting for known bad device.
[ 2.762360] pci 0000:00:02.0: PCI INT A -> Link[PILA] -> GSI 11 (level, low) -> IRQ 11
[ 2.762375] pci 0000:00:02.0: setting latency timer to 64
[ 2.773967] [drm] Initialized i915 1.6.0 20080730 for 0000:00:02.0 on minor 0
[ 2.783709] vga16fb: initializing
[ 2.783725] vga16fb: mapped to 0xc00a0000
[ 2.784076] fb0: VGA16 VGA frame buffer device
[ 2.936291] Console: switching to colour frame buffer device 80x30
[ 3.572688] xor: automatically using best checksumming function: pIII_sse
[ 3.592031] pIII_sse : 1725.000 MB/sec
[ 3.592041] xor: using function: pIII_sse (1725.000 MB/sec)
[ 3.637042] device-mapper: dm-raid45: initialized v0.2594b
[ 3.784687] EXT4-fs (sda1): INFO: recovery required on readonly filesystem
[ 3.784705] EXT4-fs (sda1): write access will be enabled during recovery
[ 5.211143] EXT4-fs (sda1): orphan cleanup on readonly fs
[ 5.211177] EXT4-fs (sda1): ext4_orphan_cleanup: deleting unreferenced inode 1835111
[ 5.211392] EXT4-fs (sda1): ext4_orphan_cleanup: deleting unreferenced inode 2621675
[ 5.211514] EXT4-fs (sda1): ext4_orphan_cleanup: deleting unreferenced inode 2621674
[ 5.211575] EXT4-fs (sda1): ext4_orphan_cleanup: deleting unreferenced inode 2621701
[ 5.211641] EXT4-fs (sda1): ext4_orphan_cleanup: deleting unreferenced inode 2621697
[ 5.211701] EXT4-fs (sda1): ext4_orphan_cleanup: deleting unreferenced inode 1835110
[ 5.211801] EXT4-fs (sda1): ext4_orphan_cleanup: deleting unreferenced inode 2621677
[ 5.211866] EXT4-fs (sda1): ext4_orphan_cleanup: deleting unreferenced inode 2621664
[ 5.211922] EXT4-fs (sda1): 8 orphan inodes deleted
[ 5.211935] EXT4-fs (sda1): recovery complete
[ 5.354389] EXT4-fs (sda1): mounted filesystem with ordered data mode
[ 16.046943] Adding 1466360k swap on /dev/sda5. Priority:-1 extents:1 across:1466360k
[ 16.259824] udev: starting version 151
[ 16.835819] lp: driver loaded but no devices found
[ 16.981321] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[ 17.032188] intel_rng: FWH not detected
[ 17.677218] Non-volatile memory driver v1.3
[ 17.717587] parport_pc 00:06: activated
[ 17.717643] parport_pc 00:06: reported by Plug and Play ACPI
[ 17.717819] parport0: PC-style at 0x278, irq 5 [PCSPP]
[ 17.812584] lp0: using parport0 (interrupt-driven).
[ 18.112600] irda_init()
[ 18.112659] NET: Registered protocol family 23
[ 18.244907] ppdev: user-space parallel port driver
[ 18.361491] type=1505 audit(1297380711.430:2): operation="profile_load" pid=605 name="/sbin/dhclient3"
[ 18.362930] type=1505 audit(1297380711.430:3): operation="profile_load" pid=605 name="/usr/lib/NetworkManager/nm-dhcp-client.action"
[ 18.363850] type=1505 audit(1297380711.430:4): operation="profile_load" pid=605 name="/usr/lib/connman/scripts/dhclient-script"
[ 18.393744] psmouse serio1: ID: 10 00 64
[ 18.508928] nsc-ircc 00:08: activated
[ 18.508950] nsc_ircc_pnp_probe() : From PnP, found firbase 0x2F8 ; irq 4 ; dma 1.
[ 18.509222] nsc-ircc, chip->init
[ 18.509239] nsc-ircc, Found chip at base=0x02e
[ 18.509269] nsc-ircc, driver loaded (Dag Brattli)
[ 18.514545] IrDA: Registered device irda0
[ 18.514560] nsc-ircc, Using dongle: IBM31T1100 or Temic TFDS6000/TFDS6500
[ 18.643461] thinkpad_acpi: ThinkPad ACPI Extras v0.24
[ 18.643473] thinkpad_acpi: ibm-acpi.sf.net/
[ 18.643482] thinkpad_acpi: ThinkPad BIOS 1FETE8WW (3.080), EC unknown
[ 18.643491] thinkpad_acpi: WARNING: Outdated ThinkPad BIOS/EC firmware
[ 18.643499] thinkpad_acpi: WARNING: This firmware may be missing critical bug fixes and/or important features
[ 18.665164] thinkpad_acpi: Console audio control enabled, mode: monitor (read only)
[ 18.665286] IBM TrackPoint firmware: 0x0e, buttons: 3/3
[ 18.676180] input: ThinkPad Extra Buttons as /devices/platform/thinkpad_acpi/input/input6
[ 18.682986] input: TPPS/2 IBM TrackPoint as /devices/platform/i8042/serio1/input/input7
[ 18.687075] yenta_cardbus 0000:01:09.0: CardBus bridge found [1014:1017]
[ 18.687107] yenta_cardbus 0000:01:09.0: Enabling burst memory read transactions
[ 18.687120] yenta_cardbus 0000:01:09.0: Using CSCINT to route CSC interrupts to PCI
[ 18.687130] yenta_cardbus 0000:01:09.0: Routing CardBus interrupts to PCI
[ 18.687143] yenta_cardbus 0000:01:09.0: TI: mfunc 0x01111c02, devctl 0x64
[ 18.916622] yenta_cardbus 0000:01:09.0: ISA IRQ mask 0x04d8, PCI irq 11
[ 18.916637] yenta_cardbus 0000:01:09.0: Socket status: 30000006
[ 18.916649] pci_bus 0000:01: Raising subordinate bus# of parent bus (#01) from #01 to #05
[ 18.916676] yenta_cardbus 0000:01:09.0: pcmcia: parent PCI bridge I/O window: 0x7000 - 0x7fff
[ 18.916691] pcmcia_socket pcmcia_socket0: cs: IO port probe 0x7000-0x7fff: clean.
[ 18.917362] yenta_cardbus 0000:01:09.0: pcmcia: parent PCI bridge Memory window: 0x80100000 - 0x801fffff
[ 18.917375] yenta_cardbus 0000:01:09.0: pcmcia: parent PCI bridge Memory window: 0x20000000 - 0x23ffffff
[ 19.138014] ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 19.140193] e100: eth0 NIC Link is Up 100 Mbps Full Duplex
[ 19.140540] ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 19.541419] pcmcia_socket pcmcia_socket0: cs: IO port probe 0x100-0x3af: clean.
[ 19.543202] pcmcia_socket pcmcia_socket0: cs: IO port probe 0x3e0-0x4ff: clean.
[ 19.545065] pcmcia_socket pcmcia_socket0: cs: IO port probe 0x820-0x8ff: clean.
[ 19.545793] pcmcia_socket pcmcia_socket0: cs: IO port probe 0xc00-0xcf7: clean.
[ 19.546958] pcmcia_socket pcmcia_socket0: cs: IO port probe 0xa00-0xaff: clean.
[ 19.676296] type=1505 audit(1297380712.746:5): operation="profile_load" pid=783 name="/usr/share/gdm/guest-session/Xsession"
[ 19.687912] type=1505 audit(1297380712.754:6): operation="profile_replace" pid=784 name="/sbin/dhclient3"
[ 19.697540] type=1505 audit(1297380712.766:7): operation="profile_replace" pid=784 name="/usr/lib/NetworkManager/nm-dhcp-client.action"
[ 19.698386] type=1505 audit(1297380712.766:8): operation="profile_replace" pid=784 name="/usr/lib/connman/scripts/dhclient-script"
[ 19.782607] type=1505 audit(1297380712.850:9): operation="profile_load" pid=787 name="/usr/bin/evince"
[ 19.821628] type=1505 audit(1297380712.890:10): operation="profile_load" pid=787 name="/usr/bin/evince-previewer"
[ 19.863140] type=1505 audit(1297380712.930:11): operation="profile_load" pid=787 name="/usr/bin/evince-thumbnailer"
[ 20.037597] Intel ICH 0000:00:1f.5: PCI INT B -> Link[PILB] -> GSI 11 (level, low) -> IRQ 11
[ 20.037638] Intel ICH 0000:00:1f.5: setting latency timer to 64
[ 20.476131] intel8x0_measure_ac97_clock: measured 53523 usecs (2572 samples)
[ 20.476145] intel8x0: clocking to 48000
[ 29.392054] eth0: no IPv6 routers present
[ 203.321430] RTAI[hal]: ERROR, LOCAL APIC CONFIGURED BUT NOT AVAILABLE/ENABLED.
I'm pretty new to Linux in general, so I can't make heads or tails of what the problem is, so if anyone could help me out, I would be forever grateful.
Thanks in advance,
Andrew
RUN_IN_PLACE=no
EMC2_DIR=
EMC2_SCRIPT_DIR=
EMC2_CONFIG_DIR=
INIVAR=inivar
HALCMD=halcmd
EMC2 - 2.4.3
EMCMOT=motmod
EMCIO=io
TASK=milltask
HALUI=
DISPLAY=axis
NML_FILE=
Starting EMC2...
Cleanup done
1428
[ 1.030437] sda:
Thanks in advance,
Andrew
11 Feb 2011 00:05 #7125
by BigJohnT
Replied by BigJohnT on topic Re:Installed, but won't run.
If your not really going to try and run a machine (and you should not from a laptop) install the pure simulator version.
wiki.linuxcnc.org/cgi-bin/emcinfo.pl?Ins...ge_already_installed
11 Feb 2011 00:11 #7126
Replied by PCW on topic Re:Installed, but won't run.
And if you are brave and are going to try running a machine see this thread about the lapic:
www.linuxcnc.org/component/option,com_ku...8/lang,english/#4205
11 Feb 2011 00:42 #7127
by 3MTA3
Replied by 3MTA3 on topic Re:Installed, but won't run.
I had read somewhere that a cnc machine should be run from a desktop instead of a laptop, but i didn't understand why. could you please explain it to me? is it even possible to run from a laptop?
i do plan to run a cnc machine, myself and a couple of friends are building the hardware side of it at school.
11 Feb 2011 01:44 #7130
Replied by cmorley on topic Re:Installed, but won't run.
its possible to run from some laptops.
In general laptops have latency trouble that is hard (or impossible) to work around.
11 Feb 2011 01:47 #7131
Laptops are not good candidates for EMC machine control because they usually have special hardware and low level software for power management that interferes with EMCs real time performance. For example, a 1 mS delay during a video playback while the laptop hardware/software checks its CPU temperature or battery charge state is undetectable, but if EMC is running a step motor a 1 mS delay will likely cause a stall, losing position and ruining the work...
- Kirk_Wallace
- Thank you received: 7
11 Feb 2011 02:11 #7132
by Kirk_Wallace
Replied by Kirk_Wallace on topic Re:Installed, but won't run.
CNC motion control needs to produce signals that are timed in an accurate and predictable way. In a coordinated move. all axes must move to the way points on time and synchronized. EMC2 uses a kernel patch that takes over from Linux and provides a realtime component to the operating system. This component is designed to give realtime tasks the resources they need to hit their marks every time. Unfortunately, there a few parts of the PC that can override the realtime system. Usually this is hardware. USB can be an issue this way. Laptops are usually a problem due to the hardware and software that handles the power saving features needed for running on a battery. If you can find and disable these features that interfere with realtime, the laptop should work okay. Since few laptops can be made to work properly, many here don't think it's worth bothering. Especially, since the machine one is trying to control is about as portable as a safe. Desktops that can run EMC2, with patience, can usually be found for very little cost, or if this is a school project, you may be able to get a donation.
13 Feb 2011 15:36 #7170
by 3MTA3
Replied by 3MTA3 on topic SOLVED(ish)
I was able to install an older version of Ubuntu (8.04) with EMC2 2.3 from that live CD and now I can load the program with no problem. I will try upgrading EMC2 to 2.4 when I have the time.
Thank you all for the information on laptops, I will need to explore ways to increase my chances of success when I actually attach steppers and run a program.
Time to create page: 0.114 seconds
