EMC2 live CD install, Ubuntu works fine not EMC2
25 Feb 2011 06:02 #7443 by WRC_CNC
I am trying to run this on an industrial single board computer, it is a pentium 3 and pretty fast.
Ubuntu works fine but EMC2 crashes, I am new to this, I was a mach 3 user.
I am hoping it will run on these machines they will make nice CNC computers.
Here is the errors:
Print file information:
RUN_IN_PLACE=no
EMC2_DIR=
EMC2_BIN_DIR=/usr/bin
EMC2_TCL_DIR=/usr/share/emc/tcl
EMC2_SCRIPT_DIR=
EMC2_RTLIB_DIR=/usr/realtime-2.6.32-122-rtai/modules/emc2
EMC2_CONFIG_DIR=
EMC2_LANG_DIR=/usr/share/emc/tcl/msgs
INIVAR=inivar
HALCMD=halcmd
EMC2_EMCSH=/usr/bin/wish8.5
EMC2 - 2.4.3
Machine configuration directory is '/home/wrc-cnc/emc2/configs/Sherline3Axis'
Machine configuration file is 'Sherline3Axis_inch.ini'
INIFILE=/home/wrc-cnc/emc2/configs/Sherline3Axis/Sherline3Axis_inch.ini
PARAMETER_FILE=stepper.var
EMCMOT=motmod
EMCIO=io
TASK=milltask
HALUI=
DISPLAY=axis
NML_FILE=
Starting EMC2...
Starting EMC2 server program: emcsvr
Realtime system did not load
Shutting down and cleaning up EMC2...
Killing task emcsvr, PID=3295
Cleanup done
Debug file information:
insmod: error inserting '/usr/realtime-2.6.32-122-rtai/modules/rtai_hal.ko': -1 Operation not permitted
3295
PID TTY STAT TIME COMMAND
Stopping realtime threads
RTAPI: ERROR: could not open shared memory (errno=2)
HAL: ERROR: rtapi init failed
halcmd: hal_init() failed: -22
NOTE: 'rtapi' kernel module must be loaded
Unloading hal components
ERROR: Module hal_lib does not exist in /proc/modules
ERROR: Module rtapi does not exist in /proc/modules
ERROR: Module rtai_math does not exist in /proc/modules
ERROR: Module rtai_sem does not exist in /proc/modules
ERROR: Module rtai_fifos does not exist in /proc/modules
ERROR: Module rtai_sched does not exist in /proc/modules
ERROR: Module rtai_hal does not exist in /proc/modules
Kernel message information:
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Linux version 2.6.32-122-rtai (root@moses-6core) (gcc version 4.4.3 (Ubuntu 4.4.3-4ubuntu5) ) #rtai SMP Tue Jul 27 12:44:07 CDT 2010 (Ubuntu 2.6.32-122.35.rtai-rtai 2.6.32.11+drm33.2)
[ 0.000000] KERNEL supported cpus:
[ 0.000000] Intel GenuineIntel
[ 0.000000] AMD AuthenticAMD
[ 0.000000] NSC Geode by NSC
[ 0.000000] Cyrix CyrixInstead
[ 0.000000] Centaur CentaurHauls
[ 0.000000] Transmeta GenuineTMx86
[ 0.000000] Transmeta TransmetaCPU
[ 0.000000] UMC UMC UMC UMC
[ 0.000000] BIOS-provided physical RAM map:
[ 0.000000] BIOS-e820: 0000000000000000 - 00000000000a0000 (usable)
[ 0.000000] BIOS-e820: 00000000000f0000 - 0000000000100000 (reserved)
[ 0.000000] BIOS-e820: 0000000000100000 - 000000000f7f0000 (usable)
[ 0.000000] BIOS-e820: 000000000f7f0000 - 000000000f7f3000 (ACPI NVS)
[ 0.000000] BIOS-e820: 000000000f7f3000 - 000000000f800000 (ACPI data)
[ 0.000000] BIOS-e820: 000000000f800000 - 0000000010000000 (reserved)
[ 0.000000] BIOS-e820: 00000000ffff0000 - 0000000100000000 (reserved)
[ 0.000000] DMI 2.2 present.
[ 0.000000] last_pfn = 0xf7f0 max_arch_pfn = 0x100000
[ 0.000000] MTRR default type: uncachable
[ 0.000000] MTRR fixed ranges enabled:
[ 0.000000] 00000-9FFFF write-back
[ 0.000000] A0000-BFFFF uncachable
[ 0.000000] C0000-CDFFF write-protect
[ 0.000000] CE000-FFFFF uncachable
[ 0.000000] MTRR variable ranges enabled:
[ 0.000000] 0 base 000000000 mask FF0000000 write-back
[ 0.000000] 1 base 00F800000 mask FFF800000 uncachable
[ 0.000000] 2 base 0E8000000 mask FFC000000 write-combining
[ 0.000000] 3 disabled
[ 0.000000] 4 disabled
[ 0.000000] 5 disabled
[ 0.000000] 6 disabled
[ 0.000000] 7 disabled
[ 0.000000] PAT not supported by CPU.
[ 0.000000] e820 update range: 0000000000002000 - 0000000000006000 (usable) ==> (reserved)
[ 0.000000] Scanning 1 areas for low memory corruption
[ 0.000000] modified physical RAM map:
[ 0.000000] modified: 0000000000000000 - 0000000000002000 (usable)
[ 0.000000] modified: 0000000000002000 - 0000000000006000 (reserved)
[ 0.000000] modified: 0000000000006000 - 00000000000a0000 (usable)
[ 0.000000] modified: 00000000000f0000 - 0000000000100000 (reserved)
[ 0.000000] modified: 0000000000100000 - 000000000f7f0000 (usable)
[ 0.000000] modified: 000000000f7f0000 - 000000000f7f3000 (ACPI NVS)
[ 0.000000] modified: 000000000f7f3000 - 000000000f800000 (ACPI data)
[ 0.000000] modified: 000000000f800000 - 0000000010000000 (reserved)
[ 0.000000] modified: 00000000ffff0000 - 0000000100000000 (reserved)
[ 0.000000] initial memory mapped : 0 - 00c00000
[ 0.000000] init_memory_mapping: 0000000000000000-000000000f7f0000
[ 0.000000] Using x86 segment limits to approximate NX protection
[ 0.000000] 0000000000 - 0000400000 page 4k
[ 0.000000] 0000400000 - 000f400000 page 2M
[ 0.000000] 000f400000 - 000f7f0000 page 4k
[ 0.000000] kernel direct mapping tables up to f7f0000 @ 7000-c000
[ 0.000000] RAMDISK: 0adba000 - 0ba3365d
[ 0.000000] ACPI: RSDP 000f73c0 00014 (v00 VIA606)
[ 0.000000] ACPI: RSDT 0f7f3000 00028 (v01 VIA606 AWRDACPI 42302E31 AWRD 00000000)
[ 0.000000] ACPI: FACP 0f7f3040 00074 (v01 VIA606 AWRDACPI 42302E31 AWRD 00000000)
[ 0.000000] ACPI: DSDT 0f7f30c0 02B1A (v01 VIA606 AWRDACPI 00001000 MSFT 0100000C)
[ 0.000000] ACPI: FACS 0f7f0000 00040
[ 0.000000] 0MB HIGHMEM available.
[ 0.000000] 247MB LOWMEM available.
[ 0.000000] mapped low ram: 0 - 0f7f0000
[ 0.000000] low ram: 0 - 0f7f0000
[ 0.000000] node 0 low ram: 00000000 - 0f7f0000
[ 0.000000] node 0 bootmap 00008000 - 00009f00
[ 0.000000] (9 early reservations) ==> bootmem [0000000000 - 000f7f0000]
[ 0.000000] #0 [0000000000 - 0000001000] BIOS data page ==> [0000000000 - 0000001000]
[ 0.000000] #1 [0000001000 - 0000002000] EX TRAMPOLINE ==> [0000001000 - 0000002000]
[ 0.000000] #2 [0000006000 - 0000007000] TRAMPOLINE ==> [0000006000 - 0000007000]
[ 0.000000] #3 [0000100000 - 00008b0db8] TEXT DATA BSS ==> [0000100000 - 00008b0db8]
[ 0.000000] #4 [000adba000 - 000ba3365d] RAMDISK ==> [000adba000 - 000ba3365d]
[ 0.000000] #5 [000009f000 - 0000100000] BIOS reserved ==> [000009f000 - 0000100000]
[ 0.000000] #6 [00008b1000 - 00008b408e] BRK ==> [00008b1000 - 00008b408e]
[ 0.000000] #7 [0000007000 - 0000008000] PGTABLE ==> [0000007000 - 0000008000]
[ 0.000000] #8 [0000008000 - 000000a000] BOOTMAP ==> [0000008000 - 000000a000]
[ 0.000000] Zone PFN ranges:
[ 0.000000] DMA 0x00000000 -> 0x00001000
[ 0.000000] Normal 0x00001000 -> 0x0000f7f0
[ 0.000000] HighMem 0x0000f7f0 -> 0x0000f7f0
[ 0.000000] Movable zone start PFN for each node
[ 0.000000] early_node_map[3] active PFN ranges
[ 0.000000] 0: 0x00000000 -> 0x00000002
[ 0.000000] 0: 0x00000006 -> 0x000000a0
[ 0.000000] 0: 0x00000100 -> 0x0000f7f0
[ 0.000000] On node 0 totalpages: 63372
[ 0.000000] free_area_init_node: node 0, pgdat c07470e0, node_mem_map c1001000
[ 0.000000] DMA zone: 32 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 3964 pages, LIFO batch:0
[ 0.000000] Normal zone: 464 pages used for memmap
[ 0.000000] Normal zone: 58912 pages, LIFO batch:15
[ 0.000000] Using APIC driver default
[ 0.000000] ACPI: PM-Timer IO Port: 0x4008
[ 0.000000] SMP: Allowing 1 CPUs, 0 hotplug CPUs
[ 0.000000] Local APIC disabled by BIOS -- you can enable it with "lapic"
[ 0.000000] APIC: disable apic facility
[ 0.000000] nr_irqs_gsi: 16
[ 0.000000] Allocating PCI resources starting at 10000000 (gap: 10000000:efff0000)
[ 0.000000] NR_CPUS:8 nr_cpumask_bits:8 nr_cpu_ids:1 nr_node_ids:1
[ 0.000000] PERCPU: Embedded 24 pages/cpu @c1400000 s74936 r0 d23368 u4194304
[ 0.000000] pcpu-alloc: s74936 r0 d23368 u4194304 alloc=1*4194304
[ 0.000000] pcpu-alloc: [0] 0
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 62876
[ 0.000000] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-2.6.32-122-rtai root=UUID=99012089-a085-4cbc-a747-14a9e2541425 ro quiet splash
[ 0.000000] PID hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.000000] Dentry cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.000000] Inode-cache hash table entries: 16384 (order: 4, 65536 bytes)
[ 0.000000] Enabling fast FPU save and restore... done.
[ 0.000000] Enabling unmasked SIMD FPU exception support... done.
[ 0.000000] Initializing CPU#0
[ 0.000000] allocated 1269440 bytes of page_cgroup
[ 0.000000] please try 'cgroup_disable=memory' option if you don't want memory cgroups
[ 0.000000] Initializing HighMem for node 0 (00000000:00000000)
[ 0.000000] Memory: 229000k/253888k available (4539k kernel code, 24224k reserved, 1928k data, 620k init, 0k highmem)
[ 0.000000] virtual kernel memory layout:
[ 0.000000] fixmap : 0xfff1e000 - 0xfffff000 ( 900 kB)
[ 0.000000] pkmap : 0xff800000 - 0xffc00000 (4096 kB)
[ 0.000000] vmalloc : 0xcfff0000 - 0xff7fe000 ( 760 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xcf7f0000 ( 247 MB)
[ 0.000000] .init : 0xc0751000 - 0xc07ec000 ( 620 kB)
[ 0.000000] .data : 0xc056ecbc - 0xc0750e68 (1928 kB)
[ 0.000000] .text : 0xc0100000 - 0xc056ecbc (4539 kB)
[ 0.000000] Checking if this processor honours the WP bit even in supervisor mode...Ok.
[ 0.000000] SLUB: Genslabs=13, HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[ 0.000000] Hierarchical RCU implementation.
[ 0.000000] NR_IRQS:2304 nr_irqs:256
[ 0.000000] I-pipe 2.6-03: pipeline enabled.
[ 0.000000] Console: colour VGA+ 80x25
[ 0.000000] console [tty0] enabled
[ 0.000000] Fast TSC calibration using PIT
[ 0.000000] Detected 1263.460 MHz processor.
[ 0.004009] Calibrating delay loop (skipped), value calculated using timer frequency.. 2526.92 BogoMIPS (lpj=5053840)
[ 0.004050] Security Framework initialized
[ 0.004113] AppArmor: AppArmor initialized
[ 0.004132] Mount-cache hash table entries: 512
[ 0.004411] Initializing cgroup subsys ns
[ 0.004421] Initializing cgroup subsys cpuacct
[ 0.004431] Initializing cgroup subsys memory
[ 0.004452] Initializing cgroup subsys devices
[ 0.004459] Initializing cgroup subsys freezer
[ 0.004464] Initializing cgroup subsys net_cls
[ 0.004513] CPU: L1 I cache: 16K, L1 D cache: 16K
[ 0.004520] CPU: L2 cache: 512K
[ 0.004531] mce: CPU supports 5 MCE banks
[ 0.004565] Performance Events:
[ 0.004572] no APIC, boot with the "lapic" boot parameter to force-enable it.
[ 0.004577] no hardware sampling interrupt available.
[ 0.004582] p6 PMU driver.
[ 0.004621] ... version: 0
[ 0.004626] ... bit width: 32
[ 0.004630] ... generic registers: 2
[ 0.004635] ... value mask: 00000000ffffffff
[ 0.004640] ... max period: 000000007fffffff
[ 0.004645] ... fixed-purpose events: 0
[ 0.004650] ... event mask: 0000000000000003
[ 0.004660] Checking 'hlt' instruction... OK.
[ 0.021245] SMP alternatives: switching to UP code
[ 0.029388] Freeing SMP alternatives: 31k freed
[ 0.029413] ACPI: Core revision 20090903
[ 0.036179] ACPI: setting ELCR to 0800 (from 1a20)
[ 0.037719] ftrace: converting mcount calls to 0f 1f 44 00 00
[ 0.037732] ftrace: allocating 21003 entries in 42 pages
[ 0.050599] Enabling APIC mode: Flat. Using 0 I/O APICs
[ 0.050612] weird, boot CPU (#0) not listed by the BIOS.
[ 0.050616] SMP motherboard not detected.
[ 0.050622] Local APIC not detected. Using dummy APIC emulation.
[ 0.050627] SMP disabled
[ 0.051076] Brought up 1 CPUs
[ 0.051090] Total of 1 processors activated (2526.92 BogoMIPS).
[ 0.052062] CPU0 attaching NULL sched-domain.
[ 0.052422] devtmpfs: initialized
[ 0.053182] regulator: core version 0.5
[ 0.053297] NET: Registered protocol family 16
[ 0.053570] EISA bus registered
[ 0.053587] ACPI: bus type pci registered
[ 0.085425] PCI: PCI BIOS revision 2.10 entry at 0xfb220, last bus=1
[ 0.085431] PCI: Using configuration type 1 for base access
[ 0.087138] bio: create slab <bio-0> at 0
[ 0.087990] ACPI: EC: Look up EC in DSDT
[ 0.095316] ACPI: Interpreter enabled
[ 0.095322] ACPI: (supports S0 S5)
[ 0.095345] ACPI: Using PIC for interrupt routing
[ 0.102085] ACPI: No dock devices found.
[ 0.102269] ACPI: PCI Root Bridge [PCI0] (0000:00)
[ 0.102350] pci 0000:00:00.0: reg 10 32bit mmio pref: [0xe8000000-0xebffffff]
[ 0.102437] pci 0000:00:01.0: supports D1
[ 0.102549] pci 0000:00:07.1: reg 20 io port: [0xc000-0xc00f]
[ 0.102618] pci 0000:00:07.2: reg 20 io port: [0xc400-0xc41f]
[ 0.102683] pci 0000:00:07.3: reg 20 io port: [0xc800-0xc81f]
[ 0.102770] pci 0000:00:07.4: quirk: region 6000-607f claimed by vt82c686 HW-mon
[ 0.102778] pci 0000:00:07.4: quirk: region 5000-500f claimed by vt82c686 SMB
[ 0.102824] pci 0000:00:07.5: reg 10 io port: [0xcc00-0xccff]
[ 0.102834] pci 0000:00:07.5: reg 14 io port: [0xd000-0xd003]
[ 0.102844] pci 0000:00:07.5: reg 18 io port: [0xd400-0xd403]
[ 0.102908] pci 0000:00:0a.0: reg 10 32bit mmio: [0xef020000-0xef020fff]
[ 0.102918] pci 0000:00:0a.0: reg 14 io port: [0xd800-0xd83f]
[ 0.102928] pci 0000:00:0a.0: reg 18 32bit mmio: [0xef000000-0xef01ffff]
[ 0.102947] pci 0000:00:0a.0: reg 30 32bit mmio pref: [0x000000-0x00ffff]
[ 0.102966] pci 0000:00:0a.0: supports D1 D2
[ 0.102972] pci 0000:00:0a.0: PME# supported from D0 D1 D2 D3hot
[ 0.102980] pci 0000:00:0a.0: PME# disabled
[ 0.103025] pci 0000:00:0b.0: reg 20 io port: [0xdc00-0xdc1f]
[ 0.103050] pci 0000:00:0b.0: supports D1 D2
[ 0.103055] pci 0000:00:0b.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.103062] pci 0000:00:0b.0: PME# disabled
[ 0.103107] pci 0000:00:0b.1: reg 20 io port: [0xe000-0xe01f]
[ 0.103132] pci 0000:00:0b.1: supports D1 D2
[ 0.103137] pci 0000:00:0b.1: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.103144] pci 0000:00:0b.1: PME# disabled
[ 0.103176] pci 0000:00:0b.2: reg 10 32bit mmio: [0xef021000-0xef0210ff]
[ 0.103215] pci 0000:00:0b.2: supports D1 D2
[ 0.103220] pci 0000:00:0b.2: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.103227] pci 0000:00:0b.2: PME# disabled
[ 0.103295] pci 0000:01:00.0: reg 10 32bit mmio: [0xed000000-0xed07ffff]
[ 0.103305] pci 0000:01:00.0: reg 14 32bit mmio pref: [0xe0000000-0xe7ffffff]
[ 0.103328] pci 0000:01:00.0: reg 30 32bit mmio pref: [0x000000-0x00ffff]
[ 0.103349] pci 0000:01:00.0: supports D1 D2
[ 0.103390] pci 0000:00:01.0: bridge 32bit mmio: [0xec000000-0xedffffff]
[ 0.103399] pci 0000:00:01.0: bridge 32bit mmio pref: [0xe0000000-0xe7ffffff]
[ 0.103410] pci_bus 0000:00: on NUMA node 0
[ 0.103422] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT]
[ 0.142208] ACPI: PCI Interrupt Link [LNKA] (IRQs 1 3 4 5 6 7 10 11 12 14 15) *9
[ 0.142534] ACPI: PCI Interrupt Link [LNKB] (IRQs 1 3 4 *5 6 7 10 11 12 14 15)
[ 0.142860] ACPI: PCI Interrupt Link [LNKC] (IRQs 1 3 4 5 6 7 10 11 *12 14 15)
[ 0.143186] ACPI: PCI Interrupt Link [LNKD] (IRQs 1 3 4 5 6 7 10 *11 12 14 15)
[ 0.143421] vgaarb: device added: PCI:0000:01:00.0,decodes=io+mem,owns=io+mem,locks=none
[ 0.143427] vgaarb: loaded
[ 0.143708] SCSI subsystem initialized
[ 0.143878] libata version 3.00 loaded.
[ 0.144067] usbcore: registered new interface driver usbfs
[ 0.144098] usbcore: registered new interface driver hub
[ 0.144180] usbcore: registered new device driver usb
[ 0.144468] ACPI: WMI: Mapper loaded
[ 0.144473] PCI: Using ACPI for IRQ routing
[ 0.144735] NetLabel: Initializing
[ 0.144740] NetLabel: domain hash size = 128
[ 0.144744] NetLabel: protocols = UNLABELED CIPSOv4
[ 0.144776] NetLabel: unlabeled traffic allowed by default
[ 0.144855] Switching to clocksource tsc
[ 0.148655] AppArmor: AppArmor Filesystem Enabled
[ 0.148716] pnp: PnP ACPI init
[ 0.148775] ACPI: bus type pnp registered
[ 0.154746] pnp: PnP ACPI: found 13 devices
[ 0.154754] ACPI: ACPI bus type pnp unregistered
[ 0.154766] PnPBIOS: Disabled by ACPI PNP
[ 0.154793] system 00:00: iomem range 0xd0000-0xd3fff has been reserved
[ 0.154801] system 00:00: iomem range 0xf0000-0xf7fff could not be reserved
[ 0.154808] system 00:00: iomem range 0xf8000-0xfbfff could not be reserved
[ 0.154816] system 00:00: iomem range 0xfc000-0xfffff could not be reserved
[ 0.154823] system 00:00: iomem range 0xf7f0000-0xf7fffff could not be reserved
[ 0.154831] system 00:00: iomem range 0xffff0000-0xffffffff has been reserved
[ 0.154838] system 00:00: iomem range 0x0-0x9ffff could not be reserved
[ 0.154846] system 00:00: iomem range 0x100000-0xf7effff could not be reserved
[ 0.154853] system 00:00: iomem range 0xfee00000-0xfee00fff has been reserved
[ 0.154870] system 00:02: ioport range 0x4d0-0x4d1 has been reserved
[ 0.189919] pci 0000:00:01.0: PCI bridge, secondary bus 0000:01
[ 0.189926] pci 0000:00:01.0: IO window: disabled
[ 0.189936] pci 0000:00:01.0: MEM window: 0xec000000-0xedffffff
[ 0.189944] pci 0000:00:01.0: PREFETCH window: 0xe0000000-0xe7ffffff
[ 0.189969] pci 0000:00:01.0: setting latency timer to 64
[ 0.189981] pci_bus 0000:00: resource 0 io: [0x00-0xffff]
[ 0.189987] pci_bus 0000:00: resource 1 mem: [0x000000-0xffffffff]
[ 0.189994] pci_bus 0000:01: resource 1 mem: [0xec000000-0xedffffff]
[ 0.190000] pci_bus 0000:01: resource 2 pref mem [0xe0000000-0xe7ffffff]
[ 0.190113] NET: Registered protocol family 2
[ 0.190344] IP route cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.191001] TCP established hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.191304] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.191547] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.191553] TCP reno registered
[ 0.191752] NET: Registered protocol family 1
[ 0.191796] pci 0000:00:01.0: disabling DAC on VIA PCI bridge
[ 0.191806] pci 0000:00:07.0: Disabling VIA external APIC routing
[ 0.191874] pci 0000:00:0a.0: Firmware left e100 interrupts enabled; disabling
[ 0.191934] pci 0000:01:00.0: Boot video device
[ 0.192359] Scanning for low memory corruption every 60 seconds
[ 0.192608] audit: initializing netlink socket (disabled)
[ 0.192636] type=2000 audit(1298559166.191:1): initialized
[ 0.206563] Trying to unpack rootfs image as initramfs...
[ 0.223701] HugeTLB registered 4 MB page size, pre-allocated 0 pages
[ 0.231935] VFS: Disk quotas dquot_6.5.2
[ 0.232187] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.233870] fuse init (API version 7.13)
[ 0.234092] msgmni has been set to 447
[ 0.239473] alg: No test for stdrng (krng)
[ 0.239662] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
[ 0.239670] io scheduler noop registered
[ 0.239675] io scheduler anticipatory registered
[ 0.239679] io scheduler deadline registered
[ 0.239815] io scheduler cfq registered (default)
[ 0.240075] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
[ 0.240129] pciehp: PCI Express Hot Plug Controller Driver version: 0.4
[ 0.240294] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input0
[ 0.240305] ACPI: Power Button [PWRB]
[ 0.240438] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input1
[ 0.240445] ACPI: Power Button [PWRF]
[ 0.243254] isapnp: Scanning for PnP cards...
[ 0.249560] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 0.249712] serial8250: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[ 0.249861] serial8250: ttyS1 at I/O 0x2f8 (irq = 3) is a 16550A
[ 0.249999] serial8250: ttyS2 at I/O 0x3e8 (irq = 4) is a 16550A
[ 0.250525] 00:08: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[ 0.250739] 00:09: ttyS1 at I/O 0x2f8 (irq = 3) is a 16550A
[ 0.251009] 00:0c: ttyS2 at I/O 0x3e8 (irq = 10) is a 16550A
[ 0.257721] brd: module loaded
[ 0.258827] loop: module loaded
[ 0.307595] input: Macintosh mouse button emulation as /devices/virtual/input/input2
[ 0.308890] Fixed MDIO Bus: probed
[ 0.308975] PPP generic driver version 2.4.2
[ 0.309144] tun: Universal TUN/TAP device driver, 1.6
[ 0.309149] tun: (C) 1999-2004 Max Krasnyansky <This email address is being protected from spambots. You need JavaScript enabled to view it.>
[ 0.309399] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 0.310362] ACPI: PCI Interrupt Link [LNKA] enabled at IRQ 11
[ 0.310370] PCI: setting IRQ 11 as level-triggered
[ 0.310379] ehci_hcd 0000:00:0b.2: PCI INT C -> Link[LNKA] -> GSI 11 (level, low) -> IRQ 11
[ 0.310418] ehci_hcd 0000:00:0b.2: EHCI Host Controller
[ 0.310531] ehci_hcd 0000:00:0b.2: new USB bus registered, assigned bus number 1
[ 0.310607] ehci_hcd 0000:00:0b.2: irq 11, io mem 0xef021000
[ 0.319871] ehci_hcd 0000:00:0b.2: USB 2.0 started, EHCI 1.00
[ 0.320280] usb usb1: configuration #1 chosen from 1 choice
[ 0.320357] hub 1-0:1.0: USB hub found
[ 0.320392] hub 1-0:1.0: 4 ports detected
[ 0.320528] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 0.320567] uhci_hcd: USB Universal Host Controller Interface driver
[ 0.321543] ACPI: PCI Interrupt Link [LNKD] enabled at IRQ 11
[ 0.321554] uhci_hcd 0000:00:07.2: PCI INT D -> Link[LNKD] -> GSI 11 (level, low) -> IRQ 11
[ 0.321574] uhci_hcd 0000:00:07.2: UHCI Host Controller
[ 0.321697] uhci_hcd 0000:00:07.2: new USB bus registered, assigned bus number 2
[ 0.321738] uhci_hcd 0000:00:07.2: irq 11, io base 0x0000c400
[ 0.321946] usb usb2: configuration #1 chosen from 1 choice
[ 0.322018] hub 2-0:1.0: USB hub found
[ 0.322039] hub 2-0:1.0: 2 ports detected
[ 0.322142] uhci_hcd 0000:00:07.3: PCI INT D -> Link[LNKD] -> GSI 11 (level, low) -> IRQ 11
[ 0.322156] uhci_hcd 0000:00:07.3: UHCI Host Controller
[ 0.322239] uhci_hcd 0000:00:07.3: new USB bus registered, assigned bus number 3
[ 0.322267] uhci_hcd 0000:00:07.3: irq 11, io base 0x0000c800
[ 0.322477] usb usb3: configuration #1 chosen from 1 choice
[ 0.322531] hub 3-0:1.0: USB hub found
[ 0.322547] hub 3-0:1.0: 2 ports detected
[ 0.328112] ACPI: PCI Interrupt Link [LNKC] enabled at IRQ 12
[ 0.328126] PCI: setting IRQ 12 as level-triggered
[ 0.328137] uhci_hcd 0000:00:0b.0: PCI INT A -> Link[LNKC] -> GSI 12 (level, low) -> IRQ 12
[ 0.328167] uhci_hcd 0000:00:0b.0: UHCI Host Controller
[ 0.328384] uhci_hcd 0000:00:0b.0: new USB bus registered, assigned bus number 4
[ 0.328434] uhci_hcd 0000:00:0b.0: irq 12, io base 0x0000dc00
[ 0.328717] usb usb4: configuration #1 chosen from 1 choice
[ 0.328787] hub 4-0:1.0: USB hub found
[ 0.328810] hub 4-0:1.0: 2 ports detected
[ 0.328926] uhci_hcd 0000:00:0b.1: PCI INT B -> Link[LNKD] -> GSI 11 (level, low) -> IRQ 11
[ 0.328940] uhci_hcd 0000:00:0b.1: UHCI Host Controller
[ 0.329035] uhci_hcd 0000:00:0b.1: new USB bus registered, assigned bus number 5
[ 0.329069] uhci_hcd 0000:00:0b.1: irq 11, io base 0x0000e000
[ 0.329272] usb usb5: configuration #1 chosen from 1 choice
[ 0.329326] hub 5-0:1.0: USB hub found
[ 0.329343] hub 5-0:1.0: 2 ports detected
[ 0.329539] PNP: PS/2 Controller [PNP0303:PS2K] at 0x60,0x64 irq 1
[ 0.329545] PNP: PS/2 appears to have AUX port disabled, if this is incorrect please boot with i8042.nopnp
[ 0.329776] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 0.330068] mice: PS/2 mouse device common for all mice
[ 0.330440] rtc_cmos 00:04: rtc core: registered rtc_cmos as rtc0
[ 0.330474] rtc0: alarms up to one year, y3k, 242 bytes nvram
[ 0.330754] device-mapper: uevent: version 1.0.3
[ 0.331168] device-mapper: ioctl: 4.15.0-ioctl (2009-04-01) initialised: This email address is being protected from spambots. You need JavaScript enabled to view it.
[ 0.333660] device-mapper: multipath: version 1.1.0 loaded
[ 0.333671] device-mapper: multipath round-robin: version 1.0.0 loaded
[ 0.335659] EISA: Probing bus 0 at eisa.0
[ 0.335687] Cannot allocate resource for EISA slot 4
[ 0.335693] Cannot allocate resource for EISA slot 5
[ 0.335698] Cannot allocate resource for EISA slot 6
[ 0.335712] EISA: Detected 0 cards.
[ 0.335719] cpuidle: using governor ladder
[ 0.335724] cpuidle: using governor menu
[ 0.336725] TCP cubic registered
[ 0.337121] NET: Registered protocol family 10
[ 0.338182] lo: Disabled Privacy Extensions
[ 0.338884] NET: Registered protocol family 17
[ 0.338977] Using IPI No-Shortcut mode
[ 0.339280] registered taskstats version 1
[ 0.339723] rtc_cmos 00:04: setting system clock to 2011-02-24 14:52:47 UTC (1298559167)
[ 0.339731] BIOS EDD facility v0.16 2004-Jun-25, 0 devices found
[ 0.339735] EDD information not available.
[ 0.350336] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input3
[ 0.582912] hub 1-0:1.0: over-current change on port 3
[ 0.683419] hub 1-0:1.0: over-current change on port 4
[ 0.930789] isapnp: No Plug & Play device found
[ 1.072237] usb 4-2: new low speed USB device using uhci_hcd and address 2
[ 1.247419] Freeing initrd memory: 12773k freed
[ 1.291941] usb 4-2: configuration #1 chosen from 1 choice
[ 1.292214] Freeing unused kernel memory: 620k freed
[ 1.294182] Write protecting the kernel text: 4540k
[ 1.294250] Write protecting the kernel read-only data: 1668k
[ 1.340625] udev: starting version 151
[ 1.718272] pata_via 0000:00:07.1: version 0.3.4
[ 1.727519] scsi0 : pata_via
[ 1.728728] scsi1 : pata_via
[ 1.728837] ata1: PATA max UDMA/100 cmd 0x1f0 ctl 0x3f6 bmdma 0xc000 irq 14
[ 1.728844] ata2: PATA max UDMA/100 cmd 0x170 ctl 0x376 bmdma 0xc008 irq 15
[ 1.744603] Linux agpgart interface v0.103
[ 1.745137] vga16fb: initializing
[ 1.745147] vga16fb: mapped to 0xc00a0000
[ 1.745428] fb0: VGA16 VGA frame buffer device
[ 1.764988] Floppy drive(s): fd0 is 1.44M
[ 1.778357] e100: Intel(R) PRO/100 Network Driver, 3.5.24-k2-NAPI
[ 1.778367] e100: Copyright(c) 1999-2006 Intel Corporation
[ 1.778461] e100 0000:00:0a.0: PCI INT A -> Link[LNKD] -> GSI 11 (level, low) -> IRQ 11
[ 1.800090] e100 0000:00:0a.0: PME# disabled
[ 1.801627] e100: eth0: e100_probe: addr 0xef020000, irq 11, MAC addr 00:d0:c9:95:ec:e2
[ 1.803845] FDC 0 is a post-1991 82077
[ 2.053871] ata1.00: ATA-7: ST3120213A, 3.AAJ, max UDMA/100
[ 2.053881] ata1.00: 234441648 sectors, multi 16: LBA48
[ 2.053942] ata1.01: ATAPI: PCRW1208, P3.1, max MWDMA2
[ 2.120533] ata1.00: configured for UDMA/100
[ 2.136525] ata1.01: configured for MWDMA2
[ 2.137287] scsi 0:0:0:0: Direct-Access ATA ST3120213A 3.AA PQ: 0 ANSI: 5
[ 2.137676] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ 2.140143] scsi 0:0:1:0: CD-ROM PHILIPS PCRW1208 P3.1 PQ: 0 ANSI: 5
[ 2.140910] sd 0:0:0:0: [sda] 234441648 512-byte logical blocks: (120 GB/111 GiB)
[ 2.147923] sr0: scsi3-mmc drive: 36x/36x writer cd/rw xa/form2 cdda tray
[ 2.147930] Uniform CD-ROM driver Revision: 3.20
[ 2.148474] sr 0:0:1:0: Attached scsi CD-ROM sr0
[ 2.148715] sr 0:0:1:0: Attached scsi generic sg1 type 5
[ 2.148982] sd 0:0:0:0: [sda] Write Protect is off
[ 2.148989] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 2.149078] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 2.149401] sda: sda1 sda2 < sda5 sda6 >
[ 2.211537] sd 0:0:0:0: [sda] Attached SCSI disk
[ 7.188048] ata2: link is slow to respond, please be patient (ready=0)
[ 12.172045] ata2: device not ready (errno=-16), forcing hardreset
[ 12.351703] usbcore: registered new interface driver hiddev
[ 12.365635] agpgart: Detected VIA ProSavage PM133/PL133/PN133 chipset
[ 12.371065] input: Logitech Optical USB Mouse as /devices/pci0000:00/0000:00:0b.0/usb4/4-2/4-2:1.0/input/input4
[ 12.371467] generic-usb 0003:046D:C016.0001: input,hidraw0: USB HID v1.10 Mouse [Logitech Optical USB Mouse] on usb-0000:00:0b.0-2/input0
[ 12.371538] usbcore: registered new interface driver usbhid
[ 12.371827] usbhid: v2.6:USB HID core driver
[ 12.380570] agpgart-via 0000:00:00.0: AGP aperture is 64M @ 0xe8000000
[ 12.516062] Console: switching to colour frame buffer device 80x30
[ 13.300162] xor: automatically using best checksumming function: pIII_sse
[ 13.320027] pIII_sse : 2977.000 MB/sec
[ 13.320033] xor: using function: pIII_sse (2977.000 MB/sec)
[ 13.356798] device-mapper: dm-raid45: initialized v0.2594b
[ 13.559926] EXT4-fs (sda5): mounted filesystem with ordered data mode
[ 15.022325] Adding 708600k swap on /dev/sda6. Priority:-1 extents:1 across:708600k
[ 15.571694] udev: starting version 151
[ 16.758766] type=1505 audit(1298584383.916:2): operation="profile_load" pid=447 name="/sbin/dhclient3"
[ 16.759646] type=1505 audit(1298584383.916:3): operation="profile_load" pid=447 name="/usr/lib/NetworkManager/nm-dhcp-client.action"
[ 16.760290] type=1505 audit(1298584383.920:4): operation="profile_load" pid=447 name="/usr/lib/connman/scripts/dhclient-script"
[ 17.203585] parport_pc: VIA 686A/8231 detected
[ 17.203595] parport_pc: probing current configuration
[ 17.203617] parport_pc: Current parallel port base: 0x378
[ 17.203668] parport0: PC-style at 0x378, irq 7 [PCSPP,EPP]
[ 17.300209] parport_pc: VIA parallel port: io=0x378, irq=7
[ 17.339040] lp0: using parport0 (interrupt-driven).
[ 17.345748] ppdev: user-space parallel port driver
[ 17.680681] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[ 20.668891] VIA 82xx Audio 0000:00:07.5: PCI INT C -> Link[LNKC] -> GSI 12 (level, low) -> IRQ 12
[ 20.669040] VIA 82xx Audio 0000:00:07.5: setting latency timer to 64
[ 20.831056] type=1505 audit(1298584387.988:5): operation="profile_load" pid=663 name="/usr/share/gdm/guest-session/Xsession"
[ 20.835441] type=1505 audit(1298584387.992:6): operation="profile_replace" pid=664 name="/sbin/dhclient3"
[ 20.836942] type=1505 audit(1298584387.996:7): operation="profile_replace" pid=664 name="/usr/lib/NetworkManager/nm-dhcp-client.action"
[ 20.837464] type=1505 audit(1298584387.996:8): operation="profile_replace" pid=664 name="/usr/lib/connman/scripts/dhclient-script"
[ 20.876357] type=1505 audit(1298584388.036:9): operation="profile_load" pid=665 name="/usr/bin/evince"
[ 20.892785] type=1505 audit(1298584388.052:10): operation="profile_load" pid=665 name="/usr/bin/evince-previewer"
[ 20.901221] type=1505 audit(1298584388.060:11): operation="profile_load" pid=665 name="/usr/bin/evince-thumbnailer"
[ 21.206877] e100 0000:00:0a.0: firmware: requesting e100/d102e_ucode.bin
[ 21.324193] ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 25.753237] [drm] Initialized drm 1.1.0 20060810
[ 25.789828] [drm] Initialized savage 2.4.1 20050313 for 0000:01:00.0 on minor 0
[ 936.868057] usb 5-2: new full speed USB device using uhci_hcd and address 2
[ 937.055100] usb 5-2: not running at top speed; connect to a high speed hub
[ 937.224375] usb 5-2: configuration #1 chosen from 1 choice
[ 937.646219] cfg80211: Calling CRDA to update world regulatory domain
[ 938.192001] cfg80211: World regulatory domain updated:
[ 938.192058] (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[ 938.192066] (2402000 KHz - 2472000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
[ 938.192073] (2457000 KHz - 2482000 KHz @ 20000 KHz), (300 mBi, 2000 mBm)
[ 938.192079] (2474000 KHz - 2494000 KHz @ 20000 KHz), (300 mBi, 2000 mBm)
[ 938.192085] (5170000 KHz - 5250000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
[ 938.192092] (5735000 KHz - 5835000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
[ 938.458836] phy0: Selected rate control algorithm 'minstrel'
[ 938.461957] Registered led device: rt73usb-phy0::radio
[ 938.462057] Registered led device: rt73usb-phy0::assoc
[ 938.462146] Registered led device: rt73usb-phy0::quality
[ 938.465593] usbcore: registered new interface driver rt73usb
[ 939.031540] rt73usb 5-2:1.0: firmware: requesting rt73.bin
[ 939.574422] ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 1058.037447] wlan0: deauthenticating from 68:7f:74:c6:a6:74 by local choice (reason=3)
[ 1058.044376] wlan0: direct probe to AP 68:7f:74:c6:a6:74 (try 1)
[ 1058.049591] wlan0: direct probe responded
[ 1058.049608] wlan0: authenticate with AP 68:7f:74:c6:a6:74 (try 1)
[ 1058.051366] wlan0: authenticated
[ 1058.051419] wlan0: associate with AP 68:7f:74:c6:a6:74 (try 1)
[ 1058.054391] wlan0: RX AssocResp from 68:7f:74:c6:a6:74 (capab=0x411 status=0 aid=3)
[ 1058.054397] wlan0: associated
[ 1058.073481] ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[ 1059.263211] padlock: VIA PadLock not detected.
[ 2569.585317] RTAI[hal]: ERROR, LOCAL APIC CONFIGURED BUT NOT AVAILABLE/ENABLED.
[ 2772.857608] RTAI[hal]: ERROR, LOCAL APIC CONFIGURED BUT NOT AVAILABLE/ENABLED.
[ 3054.553028] RTAI[hal]: ERROR, LOCAL APIC CONFIGURED BUT NOT AVAILABLE/ENABLED.
[ 3083.126292] RTAI[hal]: ERROR, LOCAL APIC CONFIGURED BUT NOT AVAILABLE/ENABLED.
25 Feb 2011 07:04 #7444 by step4linux
this problem was already disussed several times in this forum, it should be easy to find the related threads.
Gerd
25 Feb 2011 15:03 #7449 by WRC_CNC
OK, Found some threads on Lapic, and i read that: 0.050622] Local APIC not detected. Using dummy APIC emulation.
Pretty much means this computer is not going to work is that true?
25 Feb 2011 15:19 #7450 by PCW
Not with 10.04 (until someone compiles a non LAPIC RTAI kernel for 10.04)
its likely your system will work with with 8.04 however
25 Feb 2011 16:31 #7451 by step4linux
correct, provided you tried the lapic update for grub. did you ?
25 Feb 2011 18:07 #7455 by WRC_CNC
No I have not changed anything.
You must mean this:
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash"
to
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash lapic"
and then run update-grub and reboot
Ok, Where is this line of code? and How do I run the update-grub?
25 Feb 2011 18:52 #7456 by step4linux
its in this file: /etc/default/grub, but be sure to edit it with admin priviledge (e.g. sudo).
to run update-grub, open a terminal and type sudo update-grub <return>, enter your password when asked, and then reboot.
If it still does not work search for the words "Using dummy APIC emulation." in the error message.
If you find this message, bad luck.
Gerd
PS: if you are german speaking, you can look also here: code.google.com/p/emc2hotwinch/wiki/Probleme
26 Feb 2011 22:27 #7477 by WRC_CNC
Ok, Gave up on version 10 and installed version 8 live CD.
It will run EMC2 but the hardy hearon dosnt seam to work as well as Lucid lynx, Especialy the mouse, I tried adjusting the settings but it is still very bad to use.
So I tired installing version 10 on another pentium 3 computer, I have pretty much the same errors when I try and run EMC and there where a couple errors about memory when it was installing.
What do I have to do to make this stuff work? I have spent quite a bit of $ on Montec boards so I need to make this work somehow.
27 Feb 2011 00:22 #7478 by BigJohnT
A Pentium 3 is pretty old hardware you might consider a D510MO they are pretty cheap and known to work well with EMC. Otherwise you might try and find the 6.06 version of the LiveCD for your old computer.
28 Feb 2011 03:24 #7501 by WRC_CNC
Installed Lucid Lynx on a 3GHz celeron machine and it work perfect, It was my CAD/CAM PC but now it will have a different use.
Dropped in the PCI board and fired up the Montenc config and it started and worked fine, So now the learning curve really begins, I need to figure out the HAL config and how to tweek it. Any sugestions? I guess just read and start playing around with it.
Time to create page: 0.126 seconds
