OT Open Office.
I've just downloaded OO and unpacked the files (I need something to make notes for my EMC2 install).
I have put this here as I'm not sure if this is a 10.04 issue or not.
How do I open a terminal window in the unpack directory ?
Or how do I navigate to \home\download\oo from the terminal window?
CD \home\download\oo does not work ?
Thanks Wallace
cd /home/download/oo
Notice that 'cd' is lowercase, that matters in linux. And you must use forward slashes, not backslashes. OO is kind of overkill for a few notes isn't it? gedit is what I use, and there may be abiword on there but I don't remember.
Moses
On the other hand I just right click in a directory and create a new text file and qedit is fine for a few notes.
cd/home
cd/Wallace
all report No such file or directory.
Do I have log in as a superuser ?
Why if use the file system, is download directory empty? If I use Places - Download - it shows me the files ?
If I go to where I unziped the files, I found an install program (Package installer) and installed OO.
I now cannot however find out how to run it! Nowhere to be found.
I forgot to mention that you must have a space between 'cd' and the directory. i.e.
cd /home
There must be a space between any command and it's arguments (directory in this case).
If you actually installed OO, it will be in your Applications->Office menu. If it's not there, it probably didn't install (or maybe not all of it).
Moses
DoneIn Synaptic, you may have to open Settings->Repositories and make sure there is a check by the "Community-maintained..." item. Hit the "Reload" button, after you close that dialog and after the packages are updated you should be able to find OO with a search.
Community-maintained..." was ticked.
After a search, a whole lot of Open Office items come up under package. Installed version is blank for all??
If I re-run the install progrem I get
Error:Conflicts with the installed package openoffice,org-core
I downloaded
openoffice.org3.3-debian-menus_3.309556_all.deb
Is this the correct version ?
PS thanks for the help.
Ubuntu software center from the application menu
Selected Provided by Ubuntu and looked for OO.
It did the install and now it is running.
Thanks Wallace
Every now and then Linux really does live up to its bad reputation doesn't it?
