EMC live doesn't boot
26 Mar 2011 15:47 #8107
by dmauch
EMC live doesn't boot was created by dmauch
I d/led the latest version of emc live and successfully burn it on a CD.
I went into my bios and changed the boot sequence so that the CD boots first.
I placed the emc live cd in the tray and started the PC.. The PC message at the bottom is looking at the CD and I can see the light on the CD but the PC simply goes past the CD and instead loads windowds XP.
What is wrong?
Dan
What is wrong?
Dan
26 Mar 2011 16:03 #8109
by BigJohnT
Replied by BigJohnT on topic Re:EMC live doesn't boot
Windows is trying to assimilate you and your computer.
I would guess that the burn was not successful. Do you have another computer you can try the CD on?
Or unplug the hard drive so Windows can not be found and the real problem shows up.
26 Mar 2011 17:46 #8114
by mozmck
Replied by mozmck on topic Re:EMC live doesn't boot
When you burn a live CD, make sure you burn it at the slowest speed you can select. This is recommended in the Ubuntu CD burning instructions here: help.ubuntu.com/community/BurningIsoHowto
Also, I leave the computer alone while a CD is burning to make sure it is not interrupted.
Moses
Moses
26 Mar 2011 19:46 #8117
by dmauch
Replied by dmauch on topic Re:EMC live doesn't boot
I burnt in 3 different new CDR disks one at 48< one at 40X and the last one at 8X. I have tried the three disks on three different pc's and all three were set to boot from the CD . All three show the message that boot from the CD but then the cd player flashes a couple times and then windows starts instead.
While burning a I step away so the PC wasn't doing anything. In all three tries thwe CD burner program say it was successful. The file size of the d/l matches the file size on the CD.
Any other suggestions?
26 Mar 2011 19:53 #8119
by BigJohnT
Sounds like your just copying the file to the CD and not burning the ISO to the CD.
www.linuxcnc.org/docview/html/common_Getting_EMC.html#r3_3
26 Mar 2011 19:54 #8120
by dmauch
When I unplug the hard drive the PC statrst but then never gets to the Boot from CD message.
26 Mar 2011 20:22 #8122
by dmauch
The file I d/led says its the iso. ubuntu-10.04linuxcnc1386.iso
26 Mar 2011 20:24 #8123
by BigJohnT
Did you copy the file to the CD or burn the ISO? There is a difference...
26 Mar 2011 21:27 #8128
by mozmck
BigJohnT is right, it sounds like you just burnt it with a regular file system with the iso as a file. The iso contains it's own file system, so once it's burnt you won't see an iso file on the CD, but a whole bunch of directories and files. The link I gave earlier gives detailed instructions on burning an iso.
26 Mar 2011 21:38 #8129
by dmauch
Ok I d/led infra recoder and that installed correctly. My PC now boot ubuntu.
Thanks.
Thanks.
Time to create page: 0.332 seconds
