Getting EMC Packages
  • BigJohnT
  • BigJohnT's Avatar Topic Author
  • Administrator
  • Administrator
30 Mar 2011 15:10 - 29 Jun 2013 03:21 #8287 by BigJohnT
Getting EMC Packages was created by BigJohnT
Installing from a USB Stick
help.ubuntu.com/community/Installation/FromUSBStick
Updating 2.4.x without an internet connection.
Download the latest deb for 10.04 here:
linuxcnc.org/lucid/dists/lucid/emc2.4/binary-i386/
copy the deb to your remote computer and install with the package manager.
If you need features not in the current release you can get 2.5 here
buildbot.linuxcnc.org/
Last edit: 29 Jun 2013 03:21 by BigJohnT.
18 Apr 2011 22:20 #9063 by fabworx
Replied by fabworx on topic Re:Getting EMC Packages
i am completely new as in this is the first use of any linux version as of 2 days ago. how do i install this. i see it on the other page but there are no instructions as to how to go about getting it installed. thank you.
18 Apr 2011 22:30 #9064 by fabworx
ok I figured it out duh. ill post so others can learn from my brain absence. you have to point to the deb file from the update manager.
so from the update manager click settings go to the 'other software' tab then add the files from johns page.
21 Jul 2011 11:40 - 21 Jul 2011 12:04 #11708 by piasdom
Replied by piasdom on topic Re:Getting EMC Packages
ok i took the plunge ...... i installed emc2.5.
all is working(almost all) put i have a question or two about the cycle timer.
when i pause the program, it resets the timer. is it suppose to work like that ?
and using file/properties, can i use that and cycle timer some way to get time remaining ?
like file/properties - cycle timer = time remaining.
Last edit: 21 Jul 2011 12:04 by piasdom.
20 Feb 2015 17:50 - 20 Feb 2015 17:51 #56145 by smalla
Replied by smalla on topic Getting EMC Packages
It would be nice to include the debian repo somewhere in the docs, it took me 15 minutes to figure it out:
deb http://linuxcnc.org wheezy base 2.6-sim
or
or
deb http://linuxcnc.org wheezy base 2.7-rtai
or
deb http://linuxcnc.org wheezy base 2.7-uspace
together with the gpg key:
gpg --keyserver pgpkeys.mit.edu --recv-key 8F374FEF
    gpg -a --export 8F374FEF | sudo apt-key add -
Last edit: 20 Feb 2015 17:51 by smalla.
Time to create page: 0.116 seconds
