Run emc machine config when the system starts
24 Sep 2009 18:54 #861 by leito1489
Hello everybody, i don't know if this is the righ category for this post so if is not sorry..
well the thing is that i've tried to start my machine config when the system starts (in KDE and Gnome) and when i log in nothing happens..
i know it's not a big problem but would like to know if there is something that i'm missing because i can't make it work..
well i hope i've been clear thanks in advance for your help
Leonardo.
24 Sep 2009 22:59 #862 by BigJohnT
Not really sure what your asking... are you wanting EMC to start up when you log in?
25 Sep 2009 01:20 #863 by leito1489
Hi john,
As you said, yes i want to run the machine config at the moment i log into the KDE session, i've tried but nothing worked yet.. so i decided to ask here because probably someone made this before.
By the way... because i'm new on linux i would like to know how to make the .ini file from my machine config to start the program when i log in... because when i use a shortcut... the .ini file is the one who starts the program, but i don't know wich propiertes are the ones who give the condition of executable to the .ini file.
I hope i've been clear, sorry but english is not my first language.
Thanks for your help john.
Leonardo.
25 Sep 2009 23:12 - 25 Sep 2009 23:22 #868 by BigJohnT
Hi Leonardo,
Your English is just fine
Take a look here
www.howtogeek.com/howto/ubuntu/how-to-ad...up-list-after-login/
You have to enter the actual command not a link to a desktop thingy like so:
/usr/bin/emc /home/jet/emc2/configs/sim-1/axis.ini
Works for me :)
Last edit: 25 Sep 2009 23:22 by BigJohnT.
26 Sep 2009 00:28 #869 by mozmck
For KDE it is a little different. You put a link in the ~/.kde/Autostart directory. For a program needing arguments you have to make a small shell script.
www.captain.at/howto-autostart-program-in-kde-gnome.php
26 Sep 2009 11:05 #871 by BigJohnT
Thanks for catching that. I missed that he was using KDE cause I don't have any idea what it is :)
01 Oct 2009 19:27 #910 by leito1489
Thanks for your help guys..
I tried using the bash script with kde in the autostart dir but didn't work... i think may be i have missing things in my kde files because i installed only the kde core for making the desktop functional, so i will try installing the full kde desktop and then i'll tell you if it worked.
Best regards from Argentina.
Leonardo.
Time to create page: 0.087 seconds
