- Thank you received: 7491
Some 3D printing advice to start this section
5 years 1 month ago #219513
Replied by tommylight on topic Some 3D printing advice to start this section
VORON Legacy @300mm/s , ACC @15000mm/s/s !!!
Not yet finished, waiting ....
The following user(s) said Thank You: shpatb, my1987toyota
5 years 1 month ago #219514
That is on Creality CR-10 MAX latest version modified to direct extruder with 0.8mm nozzle and 1mm width, 0.32mm layer height.
Never mind the bed it got ruined by printing everything at the centre, it is cheap magnetic stuff at 10 Euro/meter and 60m width, enough for the Max and when changing it only the top needs to be replaced making it 5 Euro! PLA and PLA+ stick to it even without heating except very small parts.
- scotta
- Thank you received: 489
5 years 1 month ago #219557
by scotta
Replied by scotta on topic Some 3D printing advice to start this section
Hi, any chance of sharing your config? I'm tempted to start playing with some speed tests. Especially when I get the STM32 version of Remora working.VORON Legacy @300mm/s , ACC @15000mm/s/s !!!
5 years 1 month ago #219558
Not at all, if i remember to do it tomorrow, i gladly will.
The config comes with LinuxCNC, the same one you are using after rechecking who is asking....
It did require a lot of editing to make it work as for some reason the .inc file was not read at all on a PC with RTAI kernel, using parallel port for now so i had to lower micro stepping to 4, the poor thing started undressing after several runs at that speed so i also have to chase screws on the table!
While we are at it, do you happen to have the motor mounts and idlers for 12mm rod? I did print some i found on the net for Bosch Rexroth 45x45 alu profile, came out nice, use 12mm rod, bot the motor is not where it should be for the Hypercube.
Already have the hotend/X printed and mounted.
BTW, i can not buy 20x20 alu extrusions here nor order them due to some ... issues!
5 years 1 month ago #219626
As requested, config attached as is, works with built in parallel port:Hi, any chance of sharing your config?
- scotta
5 years 1 month ago #219632
by scotta
I was interested in you MAX_ACCELERATION and STEPGEN_MAXACCEL values. I've always struggled with following error.
BR
Scott
Hi Tom, thanks for sharing. I didn't realise that my config had made it into LinuxCNC.
BR
Scott
Time to create page: 0.130 seconds
