3D printed stuff, showcase it here
- Thank you received: 7496
06 Nov 2021 00:23 #225454
Replied by tommylight on topic 3D printed stuff, showcase it here
Nice !
Leme grab the Titanic ...
The following user(s) said Thank You: shpatb
06 Nov 2021 00:29 #225456
The following user(s) said Thank You: RotarySMP, elovalvo, besriworld, shpatb, my1987toyota
- snowgoer540
- Thank you received: 907
06 Nov 2021 10:29 #225488
by snowgoer540
Replied by snowgoer540 on topic 3D printed stuff, showcase it here
That's awesome Tommy! This takes Benchy to a whole new level!
The following user(s) said Thank You: RotarySMP, tommylight
06 Nov 2021 13:06 #225498
This was 30 cm long, now i have to do one at 60cm on a CR-10 Max, thinking of doing it at half the speed, should be even more detailed.That's awesome Tommy! This takes Benchy to a whole new level!
08 Nov 2021 23:37 #225733
The following user(s) said Thank You: elovalvo, anfänger, shpatb, my1987toyota
- shpatb
- Thank you received: 62
03 Dec 2021 09:58 #228271
by shpatb
Replied by shpatb on topic 3D printed stuff, showcase it here
this is some next level stuff
freaking Germans man...
- Bari
- Thank you received: 234
12 Dec 2021 20:42 #228947
by Bari
Replied by Bari on topic 3D printed stuff, showcase it here
You may build a similar machine using LCNC to control it all.
Older analog laser galvos may use the 7i77 for control or make of use of XY2-100 in Mesa hm2 on your Mesa FPGA board of choice. forum.linuxcnc.org/27-driver-boards/3985...ot2-firmware?start=0
The powder spreader and build platform are easily controlled via servo or stepper.
The inert gas valves and build chamber heater using GPIO.
The following user(s) said Thank You: tommylight, shpatb
07 Apr 2022 22:27 #239604
Another Voron Legacy ( vorondesign.com ) being built, by now this has gotten out of hands, badly, since i have over 10 3D printers that rarely get used but i am still building others:
This is more "normal" state of mind stuff, parts for the new cnc plasma machines being built, i forgot when i started building these 3 ...
The following user(s) said Thank You: phillc54, my1987toyota
- anfänger
- Thank you received: 269
16 May 2022 10:12 #243075
by anfänger
Replied by anfänger on topic 3D printed stuff, showcase it here
Printing stuff to print stuff:
I was not really happy with my printer when printing soft materials and when I needed to change or work on the hot end.
So I took the better designed Print head of the FLSUN Super Racer and printed a custom effector (will be milled out of Aluminium If I am happy with it) to get it in my qq printer. Then printed a mount of the Sherpa mini Extruder.
Bow I have to see if the old printer is strong and stiff enough for fast printing with this setup.
The following user(s) said Thank You: tommylight, frede7
17 May 2022 13:07 - 17 May 2022 14:06 #243154
Replied by andypugh on topic 3D printed stuff, showcase it here
A foundry pattern for the travelling steady of my lathe. 3D printing makes it relatively easy to make a follow-board
The embed link works perfectly in the editor preview, but not here on the page.
lh3.googleusercontent.com/kN26ChlpMPruHh...Z1GYdVKDvc7im3acjmVo
https://lh3.googleusercontent.com/kN26ChlpMPruHhNQUyRcbHxmHZImKn5jqsfGo3q2BkQGIQdTseR3XgkdZAwKZsT1aekMrcLxqoE9KsY1bnPpFgTsnVq5ZAOUIwPgzcXRBPmdMqv3VEfBrpLZ1GYdVKDvc7im3acjmVo
Last edit: 17 May 2022 14:06 by andypugh.
The following user(s) said Thank You: tommylight, anfänger
Time to create page: 1.792 seconds
