Voron Life , for anyone going into 3D printing !
1 year 2 months ago - 1 year 2 months ago #332729 by my1987toyota
Replied by my1987toyota on topic Voron Life , for anyone going into 3D printing !
Good point tommylight Though I may modify the models for CNC machining .
Last edit: 1 year 2 months ago by my1987toyota. Reason: Failure is not an option it's part of the process
1 year 2 months ago #333827 by my1987toyota
I just came across this today, very tempting. Albeit it needs some work.
[url]
[/url]
The following user(s) said Thank You: tommylight, besriworld
1 year 2 months ago #333831 by tommylight
Replied by tommylight on topic Voron Life , for anyone going into 3D printing !
Seen that a while back, it is a version of Voron 2.4 but bigger.
I have a bigger Voron with 10mm belts all over and i think i linked to files probably twice till now, they ar eon printables.com under the toma.3d name, just in case.
1 year 2 months ago #333854 by my1987toyota
Appreciated as always tommylight. I put the response there to show that there are kits now available
when before there were none.
[url] www.fysetc.com/products/venture-xl [/url]
1 year 2 months ago #333855 by tommylight
You might want to wait a bit till the hysteria settles down and the price will also settle down with it.
Or some China shop will come up with a much cheaper kit, as they did with Voron 0.1.
At the risk of repeating myself, if you have no parts for 3D printers already, it is much better to buy a kit than to source parts yourself, saves a lot of time and even more frustration. Also, after you finally source everything and build the damn thing, you have plenty of parts that don't fit that you payed for so the only reasonable thing is to buy more parts and build another one... :) That is how i ended up with 5 of Voron 2.4 !!!
The following user(s) said Thank You: my1987toyota
1 year 2 months ago - 1 year 2 months ago #333857 by my1987toyota
Hilariously the XL is open source [url] github.com/FYSETC/Venture_XL [/url]
I am also curious tommylight , have you used other toolheads with the voron 2.4 like the DragonBurner or
RapidBurner? if so what is your opinion of them?
Time to create page: 0.216 seconds
