Cancelling extruder thermistor input.
  • mary22
  • mary22's Avatar Topic Author
  • Visitor
  • Visitor
19 Mar 2024 03:56 - 23 Dec 2024 07:32 #296293 by mary22
I have a SKR Pro 1.2 board with Marlin code. Setup from MP CNC firmware. This is set for a 3D printer and the touch screen works for all movements. I have added a paste applicator that uses the extruder stepper motor to apply the paste. The firmware is checking for a signal for the hot end temperatures. I want the extruder to run without checking for temperature. I am not experienced in writing the Marlin code and reflashing the firmware. Can I add a resistor to fool the thermistor or a code that stops the firmware checking?[/url]
Last edit: 23 Dec 2024 07:32 by Aciera. Reason: remove spam link and ban user
19 Mar 2024 05:02 #296298 by tommylight
Replied by tommylight on topic Cancelling extruder thermistor input.
Moved to "additive manufacturing".
There should be a setting with "minimum extrusion temperature" in marlin.
And yes, you can do it with a resistor or a potentiometer.
19 Mar 2024 06:47 #296314 by andypugh
Replied by andypugh on topic Cancelling extruder thermistor input.
This really isn't a LinuxCNC question, it is a Marlin question.
Removing M109 (and maybe M104) from the G-code (and if that works, from the preprocessor that generates the G-code) will probably do what you need.
marlinfw.org/docs/gcode/M109.html
Time to create page: 0.142 seconds
