galvo head - protocol xy2-100
- greg23_78
- Thank you received: 7
14 Jan 2026 09:51 #341362
by greg23_78
galvo head - protocol xy2-100 was created by greg23_78
Hello everyone,
I am currently considering building a metal fused bed printer.
I currently have a 500W fiber laser with a wavelength of 1064nm.
I am looking for a galvo head for printing.
I would like a printing range of 300x300, so I am considering a laser beam expander to output 18–22 mm and an SL-1064-300-420 type F-Theta lens.
As far as I understand, the ideal solution for the head would be to find one with an xy2-100 protocol to use xy2mod.
And I am aware that I need to find a computer with very low latency.
I have a Mesa 7i97t, but I assume that it is not compatible because the protocol expects a PWM. What is the best card for galvo heads?
One last thing, is it possible to calibrate the galvo head? If so, how?
- Thank you received: 4148
14 Jan 2026 11:45 #341364
Replied by rodw on topic galvo head - protocol xy2-100
These guys got it working with mesa and it seems the pktuart so your 7i97 should do it..
forum.linuxcnc.org/27-driver-boards/3985...ot2-firmware?start=0
- greg23_78
14 Jan 2026 14:17 #341366
by greg23_78
Replied by greg23_78 on topic galvo head - protocol xy2-100
Thanks for the link. I had already looked through the thread and stopped at mesa 7i96.
However, I didn't see anything about optical correction. Is it possible to calibrate the laser with LinuxCNC, or do you have to use the manufacturer's software?
- Thank you received: 5323
14 Jan 2026 15:37 #341373
Replied by PCW on topic galvo head - protocol xy2-100
XY2-100 needs at minimum 3 differential outputs
(X data Y Data and clock) so you would likely need some
kind of daughter-card like a Mesa ENC422 that converts
single ended TTL level signals to differential signals.
in conjunction with the 7I97Ts parallel expansion port
(The converter is really just one chip (26LS31 equivalent on a small PCB)
