MesCT For Analog Servos
- AirRacer
- Thank you received: 3
13 Jul 2024 21:21 #305108
by AirRacer
MesCT For Analog Servos was created by AirRacer
I'm using MesaCT to build a new configuration for a 3 axis mill with DMM servos in Analog mode.
I get the message that "Drive x Scale must not be blank". Since scale is defined as "the number of pules to move one user unit", should this value be 0 for analog servos?
Thanks,
Skylor
Thanks,
Skylor
- Thank you received: 7484
13 Jul 2024 22:40 #305112
Replied by tommylight on topic MesCT For Analog Servos
Sorry to be the barer of bad news, but there are several topics here discussing the DMM servos inability to run in analog mode due to very high latency of encoder feedback.
Use them in Position mode (step/dir) as this seems to work a bit better from what i read, although i never used them and after seeing how they handled the issue, i never will.
- AirRacer
14 Jul 2024 01:19 #305116
by AirRacer
Replied by AirRacer on topic MesCT For Analog Servos
So if I were to use a different brand of analog servo, what value should the Drive scale be set to?
14 Jul 2024 13:47 #305151
There is no "drive.x.scale" that i know of, so what scale are you talking about?
Either way, please do not assume stuff and set values at random, that is always painful and long winded resulting in frustration.
PncConf does a very good job of having reasonable default values.
- JT
- Thank you received: 593
19 Jul 2024 10:04 #305630
by JT
Replied by JT on topic MesCT For Analog Servos
Which board did you select?
JT
JT
Time to create page: 0.291 seconds
