Error at startup
03 Aug 2024 05:29 #306829 by PCW
Replied by PCW on topic Error at startup
For the isolated inputs, assuming sourcing limit switches:
Limit switch common =  --> +24V that is, the common pin of all limit switches
Limit switch NC pins --> 7I95T inputs  (IN8,IN9, IN10,IN11 etc)
All input common pins used for limit switch inputs --> 24V COMMON  (INCOM8,9 INCOM10,11)
(I skipped inputs 0,1,2,3,4,5,6,7 in case you want to use them for MPG inputs)
Time to create page: 0.328 seconds
