Mesa Config Tool 7i96s MPG Firmware Flash Error
- Trevy3
2 years 1 month ago #309176
by Trevy3
Replied by Trevy3 on topic Mesa Config Tool 7i96s MPG Firmware Flash Error
- JT
- Thank you received: 599
2 years 1 month ago #309348
by JT
Replied by JT on topic Mesa Config Tool 7i96s MPG Firmware Flash Error
That is odd for sure.
JT
JT
- AirRacer
- Thank you received: 3
2 years 1 month ago #309375
by AirRacer
Replied by AirRacer on topic Mesa Config Tool 7i96s MPG Firmware Flash Error
I see the exact same issue with 7I97T+7I76: I've flashed and verified the firmware using mesaflash, and I also copied those firmware files to local/lib/libmesact .
When I use MesaCT and select the firmware and click "VERIFY" I receive a similar message to the one the OP posted.
Skylor
Skylor
- Thank you received: 5334
2 years 1 month ago #309379
Replied by PCW on topic Mesa Config Tool 7i96s MPG Firmware Flash Error
Might be helpful for mesaflash to echo the file name when
verifying, in case there is an issue there.
- JT
2 years 1 month ago #309412
by JT
JT
That error message is what mesaflash returns, mesact just prints the result of the command.I see the exact same issue with 7I97T+7I76: I've flashed and verified the firmware using mesaflash, and I also copied those firmware files to local/lib/libmesact .
Skylor
JT
2 years 1 month ago #309458
I wonder if there is a file name error of some kind?
Time to create page: 0.898 seconds
