Mesact 2 Setup
02 Nov 2024 11:26 #313653 by JT
Replied by JT on topic Mesact 2 Setup
I tested in Debian 13 and got debian so I'm a bit confused and waiting for your test.
JT
02 Nov 2024 15:17 #313659 by JT
I just ran the live cd from Linuxcnc and they chose to not have the python3-distro package installed by default... you can install python3-distro from a terminal with
sudo apt install python3-distro
I'll add that to the requirements...
JT
02 Nov 2024 15:19 #313660 by JT
Well if python3-distro is a required package and also in the readme so not sure where you went wrong... did you download and install the deb with gdebi?
JT
03 Nov 2024 00:32 #313684 by tray
Replied by tray on topic Mesact 2 Setup
Hi JT,
Thanks for replying.
>>> distro.id()
'linuxmint'
Your application was looking for 'debian' ;)
03 Nov 2024 00:34 #313685 by tray
"Well if python3-distro is a required package and also in the readme so not sure where you went wrong... did you download and install the deb with gdebi?"
Yup, I used gdebi from the terminal
03 Nov 2024 05:41 #313698 by tray
Yup, new version mesact_2.1.7_amd64_1 reports as linuxmint also
03 Nov 2024 09:10 #313701 by JT
I've added linuxmint to the list of distros, thanks for the feedback.
JT
04 Nov 2024 05:14 #313742 by tray
Hi JT, more feedback.
Yup, the latest mesact version runs on linuxmint.
Thank you sir. Now on to the proper hard stuff, software & hardware
Have a good day. Thanks.
07 Jan 2025 17:51 #318316 by gbsd86
Replied by gbsd86 on topic Mesact 2 Setup
Using LinuxCNC Bookworm. Have downloaded file from packages.debian.org/sid/python3-distro. Not sure what to do with it.
Also tried adding linuxmint to Synaptic repositories. Not doing it correctly.
Some guidance would be appreciated.
Thanks.
07 Jan 2025 18:18 #318320 by JT
Thanks.
What are you trying to do? Mesact is not in debian packages.
JT
Time to create page: 0.287 seconds
