unknown type name ‘bit’
1 year 5 months ago #328967 by Z3rni3
Hey Guys
I'm trying to write a function at the moment but it does'nt accept me using a bit.
Probably jsut missing something small.
I get following Error with following function;
CODE:
pos_latch.c:29:5: error: unknown type name ‘bit’
   29 | bit last_Tin;
make: *** [/usr/share/linuxcnc/Makefile.modinc:117: pos_latch.o] Error 1
FUNCTION:
component pos_latch;
license "GPL";
pin in float Pin;
pin in bit Tin;
pin out float out;
variable bit last_Tin = FALSE;
function _;
FUNCTION(_) {
    if (Tin && !last_Tin) {
        out = Pin;
    last_Tin = Tin;
1 year 5 months ago #328968 by Hakan
Replied by Hakan on topic unknown type name ‘bit’
Name the file pos_latch.comp, the comp thing makes it go through the preprocessor.
1 year 5 months ago - 1 year 5 months ago #328970 by Z3rni3
Replied by Z3rni3 on topic unknown type name ‘bit’
I acctually name it pos_latch.comp when creating the document.
I've created working functions before but those only used floats.
Follwing File installs no problem...:
component Test; license "GPL"; pin in float in; pin out float out1; pin out bit out2; function _ nofp; ;; FUNCTION(_) { out1 = in * 3; if (out1 == 3.0)    { out2 = true; } else    { out2 = false; } }
Last edit: 1 year 5 months ago by Z3rni3.
1 year 5 months ago #328971 by cmorley
Replied by cmorley on topic unknown type name ‘bit’
try:
variable int last_Tin = 0;
1 year 5 months ago #328972 by Z3rni3
I was able to install it now, thank you!
Will update if it works as planed.
Time to create page: 0.161 seconds
