Working on a animated home setup helper tool
29 Oct 2025 08:21 #337397 by meister
i'm working on a animated home setup helper tool, because the documentation is not always entirely clear.
At the moment, I'm not entirely sure if everything fits properly, so I'll have to test it again properly.
The source code is here:
raw.githubusercontent.com/multigcs/rioco...e/gui/home_helper.py
It can be started individually with
python3 home_helper.py
but is actually part of my Rio setup tool.
I would appreciate any suggestions for improvement.
Best regards, Olli
The following user(s) said Thank You: tommylight, pommen, Aciera, JT, rdtsc
29 Oct 2025 09:22 #337399 by Aciera
Nice. Might be an idea to show the the DRO value when homing is done as it is not necessarily always '0.00' depending on the setup values.
