Delta comunication issue
5 years 3 weeks ago #222540 by db1981
Replied by db1981 on topic Delta comunication issue
Hello,
the values are correct.
Did you checked with halscope that this behaviuer is not related by the joint.pos.cmd?
Is this signal clean? If not, it could still be an hal/ini problem. Is Trivkins used or an special kinematic?.
How did you get the etherlabmaster and linuxcnc-ethercat? ec-debianize or one of the images that i don't know?
Last way to check, would be to change the pll clock.
for that you have to install an rip version, and then apply the "add-task-pll-functions.patch" from the patches folder in linuxcnc-ethercat.
After this you can set refclocksynccycles to -1 and sync the linuxcnc task to the ethercat clock.
The following user(s) said Thank You: fehim
5 years 1 week ago #223632 by serdigi
Replied by serdigi on topic Delta comunication issue
Merhaba Fehim.İyi çalışmalar dilerim.Bende aynı dertten müzdaribim.PLL yaması vs hepsini yaptım.Anlatıldığı gibi -1 de'yaptım.Sorunu çözmedim.Senden ricam çözdüysen tecrübeni paylaşman.Teşekkür ederim.
4 years 11 months ago #226071 by fehim
Replied by fehim on topic Delta comunication issue
Hello
I was used generic driver before. Then I decided to change as delta driver called "deASDA". You can easily reach on the internet. With PID configuration, it is running now without noise.
ayıp olmasın diye ingilizce yazdım anlayamazsan mesaj olarak yazabilirsin
4 years 11 months ago - 4 years 11 months ago #226072 by serdigi
Hello Fehim;
Thanks for taking the time to reply.
I did the pll patch and other apps. I have no issues with these.
I just wanted to know how you set the pid parameters to set the PLL properly.
So other than just setting the -1 mode...
Teşekkür ederim fehim.
Last edit: 4 years 11 months ago by serdigi.
4 years 11 months ago #226157 by 0x2102
Replied by 0x2102 on topic Delta comunication issue
Hello fehim,
would you mind sharing your final working configuration?
Thanks.
4 years 11 months ago #226572 by fehim
Hello all,
This problem still there. I was misunderstood that the problem is gone when I set the deasda xml file. Velocity controlling is not a solution. Sorry for all for the wrong alarm. If someone can help about this issue I also appreciated.
Time to create page: 0.180 seconds
